Hot Bodies Cyclone
ok gotta 4.5
ok i ordered and just got in a tekin 4.5/any guesses for a starting fdr for lipo,and what spur gives you the most options for gearing up or down i put a 108 witch is the bigest i can fit with the stock motor mount,i have the brushless motor mount for taller spurs,whats the tallest spur you can run with the optional brushless mount?smallest pinion i can put on the 108 is a 27t witch puts fdt @ 8.67 or lower,hhhmmmm the tallest spur i have now is a 110,seems like i need maybe a 112 or 114 so i can run bigger than a 22t and go between 8.4-11.0 fdr range.am i close guys,need to get this figured out to test next club race getting ready for reedy race,thanks
My mad scientist took over last night. I am still having a hard time finding parts locally so I decided to make my own, kind of. BY the way i have an "S" but i plan on upgrading it as i can. Anyway i got some Traxxas slipper pegs and drilled out the standard front pulley and made it into a slipper spool. As much as i hit stuff i like the idea of having a little give. I dont know how well it will work but i ill let you know. Also nee to grind some flat spots on the lay shaft so i can mount up the better pulleys and spur gear mount. I guess i should have went to engineering school. I think i like to work on these things more than drive them.
Trader Rating: 20 (100%+)
I do see a trend here, most leaking complaints are on the TC version. With the excpetion of KOREY!!! he is the MAN!!!!!!!!!!!!!!!!!!
nice man, the WCE shock bodies are the same that came on the black, surikarn, and Hara cyclones.
I'll avoid the TC shock bodies as they are unique and wicked $hitty. However these "Low friction bodies" are different than the shock bodies that came stock ont he TC.
However they look similar, so i dunno if i can take that chance!
are you saying your had leaking WCE shocks with the P3 #6820 O rings?
Because I used the #6820 O ring on my WCE's and never had 1 leak.
You read it right.
Weird as I have had the TC for a bit now and have rebuilt the shocks 4-5 times trying new oil combos recently and have had no leaking issues that I need to worry about.Seepage happens to all shocks,but leaking....none yet.I have used the original TC bodies and the low frictions now.
what shock bodies do you prefer? original? TC? or Low friction? What O-ring do you use with each body set?
Slipper spool seems to be working. Tried in front of the house which is very abrasive blacktop and it does not slip under power, although i can turn the wheels by hand in the car. Now i just have to see how well it holds up! By the way this is the first spool i have ever run, we cant run one ways in the series e are doing for RCGT. what should i expect steering wise? I think i read it will have less turn in than a one way and a diff but more exit steering than a diff? Is this correct? Thats kind if what i have been feeling but its hard to tell with out being on the track.
diff screw?
Will the pro-spec diff screw fit in the standard diff and if so is it stronger than the standard diff screw? I would buy a pro-spec diff, but everywhere I looked is out of stock.
Call Billy at Speedworld, he had 3-4 pro diffs hanging on the wall.
http://www.speedworldraceway.com/Con...tore_Hours.cfm
Thanks, I'll call tuesday as I see there closed on monday.
found on the lrp.cc website ronald volker worlds setup:
http://www.lrp.cc/de/service/setup-sheets/?file=2266
but blue rear, RED front spring????
Looks like Volker took the German Indoor race with what everyone is assuming is the new car. Trying to find better pics, but so far only one.
the current set up
a friend was telling me i should mess with the camber settings so i did and it improved the handling a lot using these cheap 35 shore foam tires
and this is the body i use, i don't think it's legal to use in the mod class races?
so i might have to get a legal sedan body
