Old 04-16-2009, 02:44 PM   #15916
Scott B's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Tabushi View Post
Guys
Those pinion and spur numbers and gearchart result for 13.5 are based on 48p or 64p ?
The gear size's I gave are 64p.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 04-16-2009, 02:49 PM   #15917
EJ20's Avatar
Hi Scott B, see if you know how far the difference is between tc-spec w/ Duo and stock spec w/ Duo? Thanks
EJ20 is offline   Reply With Quote
Old 04-16-2009, 02:51 PM   #15918
Riketsu's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Scott B View Post
Right now your running a 6.29 ratio. When i ran 13.5 I geared arond 4.5, but thats on a BIG track witha LRP TC. I would say you can go down to 5.2 and be safe, unless your running a LRP SPX on the higher punch profiles.
For the 5.8 ratio your looking for you need a 98/41 or a 96/40. Just check your motor temps after a couple min's.
You can go to www.gearchart.com and create a gearchart.
Did you go to 4.5 with the 16T or with the 18T???? So, I can go down to 5.8 with 16T and be safe?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-16-2009, 02:55 PM   #15919
EJ20's Avatar
Thats too safe, you should gear to around 5.0 w/ 16T center pulley, it still safe!
Old 04-16-2009, 03:10 PM   #15920
Scott B's Avatar
I ran 4.5 with the Duo and TC, I have not run my SPX in my sedan yet as it's currently in my WGT. But most have gone up to 5.1-5.2 when running the higher profiles on the SPX.
I use the 18t pulleys on my car. But you can still run the 16t pulleys and be fine, you will just have to run smaller spurs to get the same overall ratio's. I was running a 102/47 last time I think. With the 16t pulleys to get down to a 4.5 you would have to run a 88t or 90t spur. Ya a 5.8 ratio should be fine.
Old 04-16-2009, 03:25 PM   #15921
EJ20's Avatar
Thanks Scotty, I has tc-spec w/ novak 13.5 now with 4.5 fdr and I'm thinking change the motor (Duo) see if they get big difference or not much?
Old 04-17-2009, 01:45 AM   #15922
Just for info.
Currently I have WCE edition with 16T pulleys in center, for carpet races i use FDR around 4.6-4.9 and my novak GTB combo with 13.5T runs fine(don't have any coolers - using 96-97 for spur, 47-51 for pinion), for summer we have quit fast track with few chicanes and few 180 turns, but overall quite high speed track - and majority of us gear around 4.4 and all is fine as long your motor in the end isn't too hot.
Ahh, yes, our so called Stock is 13.5 with 5 cells.
Cheers,
Janis
HB Cyclone WCE :: Novak GTB :: Novak 13.5T
Spectrum DX2 :: Futaba servos
janux is offline   Reply With Quote
Old 04-17-2009, 08:59 AM   #15923
adri-13's Avatar
I drive with the Hara edition and standar pulley. I have a GM genius 95 speedo and one 13.5 team ptit'yo in LIPO 7.4V IP! This is the best for fiability.
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-17-2009, 10:53 PM   #15924
diozxlive's Avatar
will installing the high traction suspension arm set give more traction on parking lot racetrack? thanks....
RC Flight/RC Grift and Drift
GP reactor, Hacker Superzomm XXL, mini funtana, mini ultrastik, bmr-2, e-hawk 1500, trex 450v2SE black, trex 450v2SE silver, Trex 500cf, trex600nsp, Thunder tiger 1/5 Ducati Desmo, revo3.3, HB cyclone ms, cyclone black, Tamiya volkswagen beetle, Mugen MBX6, X2 CRTpro
diozxlive is offline   Reply With Quote
Old 04-17-2009, 11:13 PM   #15925
adri-13's Avatar
To have more adhesion on a track or a parcking it asphalt you put a slice of 1mm on the hold before of the rear train and kept silent is going to smell that it sticks really better! Especially there virrages
PETITrc driver
www.PETITRC.com
Old 04-17-2009, 11:22 PM   #15926
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Say What?!
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-18-2009, 02:32 AM   #15927
adri-13's Avatar
sorry im french! you play with the droop it's more important!
on asphalt you take 5 on droop
on carpet you take 6 on droop
use only Hara spring in carpet and Hara front and Surikarn rear in asphalt
This setup is the good basic in France
PETITrc driver
www.PETITRC.com
Old 04-18-2009, 05:11 AM   #15928
RC MARKET's Avatar
ball cup arrived !
RC MARKET is offline   Reply With Quote
Old 04-18-2009, 05:23 AM   #15929
zacabrandy's Avatar
Does anyone know if Hotbodies has a new car on the way?. Just thinking the TC is due for some mods with lipo and brushless.
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 04-18-2009, 08:35 AM   #15930
adri-13's Avatar
yeah this is a prototype in this time. The team was tested in a private raceway more than 2 month ago for experimentations!
PETITrc driver
www.PETITRC.com
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
