Old 04-06-2009, 08:51 AM   #15781
Trader Rating: 17 (100%+)
Originally Posted by Tony Vega View Post
Dude - is that Duo motor really that much faster than the rest? Your motor was on a different level than everyone elses.
It is much better but he could also carry some speed onto the straight. Some of the other HB cars there could not....agony....blarg.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-06-2009, 08:53 AM   #15782
Originally Posted by racenut123 View Post
Try this setup,but I changed oil to 40 front and 35 rear.I also took a spare rear frp plate and cut it in the middle.I ran on a really dirty parking lot track today.I have only run on a track this bad once before and the oil and plate mod helped a ton.Car was unbelievably good for such crap conditions.I was also running rp30's instead of Sorex.
http://www.hotbodiesonline.com/pdfs/...ting_Setup.pdf
Hope this helps.
Thanks racenut. This is what you're running at NorCal?
Old 04-06-2009, 09:22 AM   #15783
STLNLST's Avatar
Trader Rating: 19 (100%+)
Hope this helps.
I heard the track conditions were really bad. I would've saved the Sorex tire's for a bttter surface as well.
STLNLST is offline   Reply With Quote
Old 04-06-2009, 09:27 AM   #15784
STLNLST's Avatar
F A I L U R E ! ! ! ! ! ! ! ! !
I doubt you'll ever have to run that set up at Norcal
Old 04-06-2009, 09:36 AM   #15785
Trader Rating: 28 (100%+)
Originally Posted by tomracing View Post
oh you have tried this setup to work??
the spring difference is huge (gold-blue)
I forgot I also changed the front spring to Silver.
Yes the Duo motor is legit for onroad.Most that are running this same combo are similar in speed.
Yup.Also the front spring is a silver.I also play with sweep in front like we talked about.
Hell yeah,I was not strapping my Sorex tires on yesterday.I actually watched others do so{use Sorex} with no benefit so I watched others who were running RP and the cars were much more planted.So I pulled out the most worn out set of old RP and commenced to drift racing!Actually the car was really good in the main.I think next month the track should be 10x better so I will wip out the sorex then.I was also using a sauce I have never tried before that gowens let me try.I bet he wishes he didnt now.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-06-2009, 09:42 AM   #15786
STLNLST's Avatar
Maybe you should do the spraying next time
Old 04-06-2009, 09:49 AM   #15787
Naw,it was just an oversight.They sprayed quite a bit but the surface is so green right now,they almost needed to power wash it.The next race should be good to go.Man I wish I could make next weeks warm up.
Team I'm Over It
Old 04-06-2009, 09:58 AM   #15788
STLNLST's Avatar
It should be pretty fun. I just hope to have the speed on the straight of some of the SPX's. Other than that I should be okay. I should hopefully have the KO with the new 1.5 software to try out. If not I have a couple of other options. If the tire is ever announced then true testing can begin......until then bring your Sorex's
Old 04-06-2009, 10:01 AM   #15789
Hicks - what Duo was that? You know I really have a hard time thinking that Trinity puts out a decent product these days.
Tony Vega is offline   Reply With Quote
Old 04-06-2009, 10:13 AM   #15790
Trinty Duo 13.5-Trinity has always tried to be the leader in SPEC motors and they luckily got it right with the Duo for onroad applications.The Pulse motors suck.Express Motorsports sells the Duo's for a great price compared to the trinity built versions.
Team I'm Over It
Old 04-06-2009, 11:23 AM   #15791
Hicks- are you running the BL motor mount in your TC? Who makes the spur in your car?
Old 04-06-2009, 11:28 AM   #15792
No need for it if running 13.5.Mod is what the BL motor mount was made for.I run the stock Spur{100t Xenon Spur/48t RPS pinion} and stock mount.
Team I'm Over It
Old 04-06-2009, 11:32 AM   #15793
can I run the BL mount in mod, and 13.5? Will it fit?
Old 04-06-2009, 11:37 AM   #15794
jarkkom's Avatar
Send a message via MSN to jarkkom
Yes. The brushless mount is how it should have been in all the kits as they have not only raised the spur axle for 2mm but they also made the motor to have a little more room.
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 04-06-2009, 12:27 PM   #15795
what he said.
Team I'm Over It
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
