Old 03-30-2009, 03:37 AM   #15751
tomracing's Avatar
well last weekend was really good. sometimes when you drive some elses car you find out what is wrong with your own. in my case the cyclone had serious understeer problems both in and out of corners.
so remembering hara's setup I thought to create more steering that way so I moved the front arms backwards which helped a bit. then i changed to silver front springs and taadaa!! the car was a lot better!
now i still suffer in certain places of the track where there is a dirrectional change from a left hand hairpin (at the end of the straight) directly into a right hand hairpin and also on a fast 90deg right hand turn into a left hand sweeper. the car just doesn't change over quick enough.
what would you look into first shock rebound or roll centres?
here's the setup i ran
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 03-30-2009, 04:19 AM   #15752
Lrp Masters 2009 Ronald Volker use new upper deck an front rear bulkhead !!!!!
Photos : http://tcm2009.lrp.cc/en/gallery/
grooveman is offline   Reply With Quote
Old 03-30-2009, 06:54 AM   #15753
Lonestar's Avatar
ok guys, i dont get many opportunities to toot my own horn, so let me do it for once
That 2-season old Cyclone Hara of mine still has it. It won the 10.5/lipo class at the Geneva Touring Car Masters saturday, it's a 10.5/CS27 carpet indoor spec class. I used Andy Moore 11/06 (2+ yrs old setup for a 2+ yrs old car) CRF setup (which basically is a variation of Hara's famous "1.5" setup that works almost everywhere) with 40WT oil all around (I only run a 10.5 when this guy was on a 7x1) and 1.0 sweep at the front (as I don't have Andy's fingers ) and the car was an absolute dream. The car was absolutely fantastic, and people came up to me spontaneously to talk about how incredibly efficient it was on the track, both easy to drive, while still carrying impressive corner speed. It ran the only 29-lapper of the day in that class, while the "open" guys would run 29 or 28 lappers.
Car still has a lot of life in it perfect way to close the indoors season!
About one of the posts above: I think Hara puts a washer below the piston for 2 reasons:
1- prevent damaging the shock body with the e-clip if the car bottoms out (shouldn't be the case unless you have the droop setup really wrong vs. shock length but you never know)
2- keep some oil below the piston at all times to prevent a "succion" effect (which would generate extra, unexpected pack due to the turbulent flow) should the suspension get squashed right after it got fully extended.
Now, a good car cleanup, rebuild, then on the shelf, and off to the outdoors, 8th scale off road season with the MBX-6!!!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-31-2009, 05:09 AM   #15754
Coldn's Avatar
Send a message via MSN to Coldn
nobody know why exist this hole??
Originally Posted by Coldn View Post
in upper deck of cyclone TC.
wy it have a 2 holes in servo safer??
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-31-2009, 07:22 AM   #15755
Lonestar's Avatar
2 reasons I can think of
- REALLY different ackerman settings
- 5th body mount
To get a proper answer, ask the guy who built it
Paul
Old 03-31-2009, 07:59 AM   #15756
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
My guess would be another spot to put your attena
King of B Main is offline   Reply With Quote
Old 04-01-2009, 02:14 AM   #15757
TheCoolCanFanMan's Avatar
You may want to try 2mm under the wishbone retainers instead of the 1.3 your using, and put the foam above the bladder in the shock, and build it with full rebound, that way you car will transition quicker through the corners.
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-01-2009, 02:15 AM   #15758
Any one got a link to an active setup page for the TC Clone please.
Cheers Malc
Old 04-01-2009, 02:19 AM   #15759
tomracing's Avatar
thanks for the comments malc
Korey any thoughts?
for setups mostly petit seems to combine setups for cyclone and TC on the same page:
http://www.petitrc.com/view_news.php?id=4553
Tom van den Brink
Old 04-01-2009, 12:03 PM   #15760
tomracing's Avatar
well i just finished my very first interactive pdf document a setup sheet for the cyclone TC.
i didn't know how to do the fill in for the tires like was on the wce version but i think i got most other things working okay.
if any one has any improvements your welcome and i will see if i can fit it in.
interactive HB TC pdf[1.7mb]
Tom van den Brink
Old 04-01-2009, 12:12 PM   #15761
Can you put a link to the interactive pdf document
Cheers Malc
Old 04-01-2009, 12:22 PM   #15762
Hello,I would firstly like to thank the help they gave me read this posts, for sharing your experiencies, and especial thanks for STLNLST, for your setup.
The last weekend i race the LRP TCM, i donīt have any experiencie in carpet, and i donīt know a good base setup for this surface, and for my style of driving.
In the free training i tried several things, and the car passed to driveable, but very dificult and inconsistent.At night everything changed the setup, and put STLNLST setup, the car now are very consistent and more easy to drive, but traction roll constantly , and i broke the car.
Finally, i make some modifications to the setup, and the car is fast, consistent and not traction roll, but the driver skills are not than good
From the setup, i changed Rear springs, blue to silver, Rear droop, 5 to 4, and stabilizers to 1.4, F and R, and put spacers in front hex.
This work for me, diferent track, carpet or driver is possible not work the same way, but I wanted to share it with your, and thanks.
The results are not important, i have really enjoyed this race and I have fun, I hope to return next year.
For Volkerd car, are the same he is use in Italy, with Tamiya steering, and a large top deck, it seem very flex, the car are very fast, i think that the more, Ronald have a very good driving style, and is very fast and consistent, but not have a good luck,the final results do not reflect how well he did on the track, the Tamiya drivers did a very good job, of course.
If this is a new HB Carpet car desing, i think is a very good way, very fast and i can see, very strong.
Thanks again, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-01-2009, 02:16 PM   #15763
Korey Harbke's Avatar
I would try running more spacers under the suspension blocks. I think you will benefit from 1.5mm of shims rather than 1.25. It will wake up the car and a bit and keep it flatter through some of the corners.
Your shock oil is fairly light, so you should probably keep that the same.
You can also try standing up the rear shock a bit, but going to a blue spring. The combination of a softer spring and moving it out on the shock tower should let it transfer weight quicker without sacrificing too much grip.
Maybe try running the foams in the shocks as well. It will create a little more rebound in the shock.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-01-2009, 09:03 PM   #15764
STLNLST's Avatar
Trader Rating: 21 (100%+)
Glad to hear that worked for you. However......I'm just the guy that posted the set up. Sean Williams is the guy that gave me the set up.
STLNLST is offline   Reply With Quote
Old 04-01-2009, 09:27 PM   #15765
the one and only STLNLST
HEWITT is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
