Old 03-13-2009, 07:26 AM   #15646
trickd122's Avatar
Default Brushless setup
I have the TC running a pulse 13.5 motor ESC: LRP COmp Sphere TC 2007
What's the Hot setup? Profile and gearing.
trickd122 is offline   Reply With Quote
Old 03-13-2009, 08:02 AM   #15647
balistic's Avatar
Trader Rating: 113 (100%+)
Originally Posted by akura2 View Post
we're racing RC motorcycles in Vegas all next weekend as part of the NATC....
I roll in at 3pm friday and have two 13 hour days saturday and sunday, I only have Friday night to play. where are you racing?
balistic is offline   Reply With Quote
Old 03-13-2009, 03:21 PM   #15648
Trader Rating: 14 (100%+)
Send a message via Yahoo to MKO3jzgte
i used to have a cyclone,but i traded it for a yokomo
MKO3jzgte is offline   Reply With Quote
Old 03-14-2009, 08:00 AM   #15649
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi Guys
Does anyone have any good tips on building the pro spec diff ie sand the rings or balls? I just want to find out before I start building it.
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 03-14-2009, 08:35 AM   #15650
Joehwee's Avatar
Originally Posted by vazzo View Post
Hi Guys
Cheers
Adrian
The pro-diff is really smooth, just build it as per instruction, it will be good.
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec
Joehwee is offline   Reply With Quote
Old 03-14-2009, 10:26 AM   #15651
WOW thats to bad man I hope you got lots of $$ in your trade or you got screwed big time Even a Cyclone S is better than a Yokomo.
Lazer Guy is offline   Reply With Quote
Old 03-14-2009, 04:54 PM   #15652
vazzo's Avatar
Thanks Joe. Do you find the plastic outdrives hold up in modified?
Cheers
Adrian
Old 03-14-2009, 04:59 PM   #15653
Korey Harbke's Avatar
They do surprisingly well actually, but it is still recommended you try the Aluminum outdrives. They won't melt or get really funky if your diff heats up a lot from improper adjustment.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-16-2009, 01:29 AM   #15654
cyclone speed's Avatar
Hi everyone ,
I have had a probleme with my diff ( pro spec ) , it keeps losening itself during the 5 min race . I did change the nut , didnt help , rebuild it , didnt help .
I race MOD and even with the old diff i had the same probleme , could anyone help me please .
Thanks in advance .
cyclone speed is offline   Reply With Quote
Old 03-16-2009, 03:34 AM   #15655
LOSI123's Avatar
Trader Rating: 63 (100%+)
you might be running it to loose, so it loosens it self more easily, also if the thrust bearing assy it gritty or worn at all it will loosen, dont use them caged thrust bearings on the old style diff they are crap and loosen, use alum outdrives(No flex or chance of distortion when running mod)
Also try some Thread lock on the nut went assembling.
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 03-16-2009, 03:36 AM   #15656
LOSI123's Avatar
Any one know the exact weight of the Cyclone WCE in standard form with no electronics at all or wheels or body etc...
Old 03-16-2009, 10:07 AM   #15657
Lonestar's Avatar
Originally Posted by cyclone speed View Post
Hi everyone ,
Thanks in advance .
threadlock the nut.... build it slightly loose in your hands, then twiggle it by hand for a few seconds to let all the parts seat down properly, and then tighten it properly
I had some interesting issues with my diff a few weeks back (read some pages back)... but once the thrust bearing was changed (seems that the one I had in the pack was a lemon) and the thing broke in (say half a pack) this is as good as any other car's diff this side of a hudy one, even after about 30 packs. It's great to spend time setting the car up between runs now instead of rebuilding the diff
Wet-sanding the rings with motor spray is always a good idea nonetheless
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-16-2009, 10:27 AM   #15658
Little_Mike's Avatar
Hi Guys
Cheers
Adrian
use these things, they will keep your diff smooth for a long time. http://www.top-racing.jp/showProduct...&ProductID=207
Cheers,
Mike
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 03-16-2009, 10:29 AM   #15659
carpet? asphalt?
Old 03-16-2009, 11:56 AM   #15660
Thanks you for the help for the diif , il try these tipps.
By the way , if you dont mind could you give me the exat weight ?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
