Old 03-09-2009, 06:08 PM   #15571
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Originally Posted by maxrcp View Post
Rc market..
RCMARKET do you have estimated date for receive cyclone tc kits?? ( i am just waiting to your restock)
TC SPEC owners or rc market:
i Am planning to change the frot driveshafts, lannyn to change the aluminium originals for steel ones
does 3 racing 3r-cy-14 driveshaft fits on tcspec?
and HB61398 44mmHD universal driveshaft ver.2 fits on the originals universal axles?
for a good repalcement of the front driveshafts to steel ones... replace them with the Cyclone S version.. i installed steel in the front for sometime now and rarely have problems.. yes aluminum is lighter.. but for longevity, i now run the steel. Hardly an wear, especially at the joint. Been running mine for 2 months now, and only see a small bend in it..... As for aluminum, they bend too fast on our track, and the wear is too fast at the joint.
Original driveshafts $8 each.
Cyclone S steel shafts $10 for 2.
Have Fun!!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 03-09-2009, 06:14 PM   #15572
balistic's Avatar
Trader Rating: 113 (100%+)
Have Fun!!!
is that carpet or pavment that kills the aluminum CVDs? Or both?
balistic is offline   Reply With Quote
Old 03-09-2009, 07:42 PM   #15573
Send a message via MSN to maxrcp
thanks RCFREAK... I gonna search cyclone s driveshaft...
I think both, carpet and asphalt broke dogbones. but carpet more than asphalt..
specially when u use much brakes...
best ragards guys
maxrcp is offline   Reply With Quote
Old 03-09-2009, 09:55 PM   #15574
bmmer701's Avatar
anyone have a setup of hara in TITC 09?
bmmer701 is offline   Reply With Quote
Old 03-09-2009, 10:12 PM   #15575
RCFREAK's Avatar
its just the track material we use... and also i guess running a spool. tapping boards here and there take a toll on the driveshafts.... actually eventually makes a chattering type noise exiting tight corners.... sounds like a tire peeling off the rim, but more metal type sounds..
Have Fun!!!
Arv.
Old 03-09-2009, 10:47 PM   #15576
STLNLST's Avatar
Originally Posted by mwoods View Post
ive just seen a setup that someone is using tamyia rear hubs on the cyclone wats the difference over the wce cyclone if there is any?
link below
http://www.gearchart.com/setup/setup...20SET%20UP.pdf
thanks
It gives "TRUE" rear toe settings and it gives you an inbetween camber location compared to the stock rear hub.
STLNLST is offline   Reply With Quote
Old 03-10-2009, 12:24 AM   #15577
Hi-LowBlow is offline   Reply With Quote
Old 03-10-2009, 06:14 AM   #15578
Lonestar's Avatar
Originally Posted by trickd122 View Post
... compared to our 2,16....
Or my 2.43
Keep in mind if you're running stock classes with 1.7 idr's you'd better have a wiiiiiide set or pinions (big) and pulleys (small) to toy with...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-10-2009, 08:51 AM   #15579
Little_Mike's Avatar
Proud to announce the cyclone has won and TQ'ed the stock rubber (17.5) class ate the ROAR region 11 carpet regionals. Swept triple a's with 2 wins in first two mains.
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 03-10-2009, 09:22 AM   #15580
Trader Rating: 16 (100%+)
Originally Posted by Hi-LowBlow View Post
He had some bad hubs back when there was an issue with them.
STLNLST, don't cry when you're lapped traffic with that blue car....
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 03-10-2009, 09:44 AM   #15581
Trader Rating: 28 (100%+)
Hey,give me those bad hubs.I will run them and still put the blue car a lap down!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 03-10-2009, 09:45 AM   #15582
Great job man!Holding it down for the purple people eaters!
Team I'm Over It
Old 03-10-2009, 10:26 AM   #15583
ShaunMac's Avatar
First of all, good job Mike.
Second, you know everyone is curious about your set-up. Care to share?
ShaunMac is offline   Reply With Quote
Old 03-10-2009, 11:26 AM   #15584
yeah ill post when iget home from school, i cant remember what weight oil was in the shocks tho! I also ran my BMI/Surikarn foam edition in stock foam class, just missed podium, was tied for points but other guy had better time That is one hella stiff chassis tho, even by the xray guys standards! i should post some pics of my car and the race, my foam car is like a frankencar with the blue aluminum, but purple CVD's .
One thing i did notice while prepping the car before the regionals during teardown was that the BMI chassis does not use the same hinge pins (at least in the rear) because it hase the screw holes for the toe blocks drilled a different distance than the reg. chassis. So i couldnt put Ti-Ni pins in. and I had to use the pins that were with it, they are so worn (but not bent luckily) that on the front ends the pin is worn to a black and gold/brown color. the kind of color of a perfectly roasted marshmellow. I would like to know what pins they are if they are from an xray or something, oh and they have a flat end (sorta half circle) on one end (also the worn end) like they fit into a slot or something.
Did I mention i played the Rick roll song in my pits after i won?
Old 03-10-2009, 12:28 PM   #15585
Rubber A1
http://www.timezoneracing.com/suppor...ng_A1-Main.pdf
Rubber A2
http://www.timezoneracing.com/suppor...ng_A2-Main.pdf
Rubber A3
http://www.timezoneracing.com/suppor...ng_A3-Main.pdf
Foam A1
http://www.timezoneracing.com/suppor...Ca_A1-Main.pdf
Foam A2
http://www.timezoneracing.com/suppor...Ca_A2-Main.pdf
Foam A3
http://www.timezoneracing.com/suppor...Ca_A3-Main.pdf
check out how close the foam A3 finish was! my nose was even with his quarterpanel!!!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
