Old 03-04-2009, 03:52 PM   #15526
Trader Rating: 14 (100%+)
So does anyone have any input on what to run in he front for asphalt? Diff, one way or spool? Again this is for RCGT.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-04-2009, 05:07 PM   #15527
ShaunMac's Avatar
Spool for rubber tires. Asphalt or carpet. Just set it and forget it.
If you decide to go with a spool. The HB Ver. 3 spool is the best spool out there for the Cyclone. It's very durable. And it's much lighter than the newer TC Spool/One-way combo.
ShaunMac is offline   Reply With Quote
Old 03-04-2009, 05:26 PM   #15528
ShaunMac's Avatar
Originally Posted by LOSI123 View Post
Anyone had a problem with thier WCE Cyclone Swaybar holders (the bit that clips onto the A-Arm is tight/Binding. I have all original HB Parts and they are not the tc arms.
You mean the ball cups? If they seem tight you can use a lighter to heat the ball cups then pop them on the arms. This will stretch the ball cups out slightly allowing them to move more freely on the arm mounts.
Old 03-04-2009, 08:47 PM   #15529
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RC MARKET View Post
TITC 09
What speedo was Hara using at this race???
STLNLST is offline   Reply With Quote
Old 03-04-2009, 09:01 PM   #15530
Korey Harbke's Avatar
For some reason I remember seeing a pic that he was running a Nosram. The pic wasnt close up enough to tell if he was running the new Nosram that they ran at worlds, or just the normal one.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-04-2009, 09:09 PM   #15531
Cool. Thanks for the input.
Old 03-04-2009, 09:12 PM   #15532
Team STPN's Avatar
Still working on that Speedo, when are you going to give up
Team STPN is offline   Reply With Quote
Old 03-04-2009, 09:30 PM   #15533
BY the way where are you guys finding parts? To say i am having a hard time finding stuff would be a huge understatement
Old 03-04-2009, 09:32 PM   #15534
STLNLST's Avatar
It's getting sent back to check for blown fets. I was just curious to see what Hara was running. You already know what I've been through
Old 03-04-2009, 09:33 PM   #15535
STLNLST's Avatar
rcmarket when all else fails.
Old 03-05-2009, 07:03 AM   #15536
grapejuice's Avatar
Trader Rating: 133 (100%+)
Originally Posted by racenut123 View Post
This will work for drifting,not for Onroad racing.I had the same setup on my ta05,and I imagine it would work equally as well if not a little better with the cyclone.
Thanks what I was figuring and yeah, the cyclone is a great drift car!
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 03-05-2009, 07:19 AM   #15537
ShaunMac's Avatar
Hara ran the NOSRAM ISTC.
The sister speedo to the LRP TC Spec.
I haven't seen anyone using the NOSRAM Pearl/LRP SXX since the worlds.
Old 03-05-2009, 07:32 AM   #15538
ShaunMac's Avatar
SpeedworldRaceway.com - 916-783-8864
RCMarket
StormerHobbies.com
Hotbodiesonline.com
What parts are you trying to find?
Old 03-05-2009, 07:58 AM   #15539
Default Rollcenter
Now I'm confused: even on low-med traction set up, I see most driver like to use 1.5mm shim under suspension blocks...what? I thought that adding shims under the suspension blocks gives you higher roll center, which in turn gives you less over all roll and traction? Is this right? Can some one pleas esplain this again...sorry for the truble
Adis is offline   Reply With Quote
Old 03-05-2009, 08:21 AM   #15540
4 degree uprights and the version 3 spool mostly. I did see RCmarket had most of the stuff i wanted but i have always been a little leary ordering from overseas.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
