Old 02-23-2009, 01:38 PM   #15376
bozla's Avatar
Just got round to rebuilding my cyclone - bought it second hand a few months back. I've been trying to return it to factory spec until I came across something really odd in the manual. The previous owner had a spool arangement on the spur gear shaft, but when built to the manual, there is a one way bearing. I built it as the manual but I couldn't understand why the bearing was rotating the wrong way. But then I looked at the exploded diagram at the back, which shows the spur the other way!
bozla is offline   Reply With Quote
Old 02-23-2009, 08:45 PM   #15377
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by ShaunMac View Post
Can you imagine the cost of manufactering a True CVD down to size for our Touring cars. You thought the XRAY ECS driveshafts were expensive!
But talk about "LUXURY"
Not only that, but the amount of added rotating mass. I prefer (in rc terms) universals to "cvds" because they seem to last longer, and in offroad, do not collect dirt and grime to wear down the components.
I think the difference you are seeing is due to manufacturing tolerances most likely with the 2 pics you shared.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 02-23-2009, 10:55 PM   #15378
deanomgwhiteguy's Avatar
Send a message via MSN to deanomgwhiteguy
When you rebuild the diff check all bearings. Including the 5x10's in the hubs and the 10x15's in the bulkheads. Make sure that they spin freely and aren't binding. Bad bearings can cause uneven power delivery and excess wear on the drivetrain.
The cvd and universal assemblies are sorta opposites of one another. See picture below.
-The WCE CVD's use the MIP design. The driveshaft captures (goes around) the axle assembly. This does offer more efficiency at extreme turning angles. Not a huge difference.
-The TC comes with universals. The axle assembly captures the driveshaft.
To this date all Cyclones share the same basic geometry. Each new version just adds new tuning features that are compatible with ALL Cyclones. No major changes have been made in 4 years. The HB Team got the design right to begin with way back in 2005. Well... all except for the diff design. It took a few years to address that issue.
ok thankz for that i have just lost another pin so cvds are at the top of my to get list now
thankz for that
Dean Mellor
Xray T2'007/KO/ORION
AE SC10
deanomgwhiteguy is offline   Reply With Quote
Old 02-24-2009, 08:37 AM   #15379
ShaunMac's Avatar
thankz for that
That's odd that you keep losing pins. Are they coming out right after an impact? Is it the same universal that loses a pin or is it random? Did you loctite the set screws?
ShaunMac is offline   Reply With Quote
Old 02-24-2009, 09:11 AM   #15380
Korey Harbke's Avatar
I agree... that is really odd. Are you using a good quality 1.5mm driver to tighten down the set screws, or a simple L type allen wrench? Try to get a hold of a quality allen driver where you can tighten the setscrew down really well without the fear of stripping the screw out.
Also, when you are building your universals, its very important to make sure the threads in the couple stay EXTREMELY clean. Any grease/oil that is in there will prevent the thread lock from ahearing the screw and coupler together, allowing it to back out fairly easily.
One last tip... If you have a dremel or a small file you can griind a flat spot on the pin itself for the setscrew to tighten onto. This allows the setscrew to have a little more grip on the pin, and also if the setscrew backs otu a tiny bit, the edges of the flatspot could possibly help retain the pin as well.
Give those a shot and see how that goes. I personally didn't see a big enough performance difference with the MIP CVD's over the stock universals. The stock universals have been great so far and I plan to continue to use them.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-24-2009, 09:13 AM   #15381
I'm pretty sure you want a Cyclone Justin
"I got two words for ya... Come onnnn!!! Come ooooonnnnn!!!!!" -Peter Griffin
Old 02-24-2009, 09:15 AM   #15382
STLNLST's Avatar
Trader Rating: 21 (100%+)
YGM
STLNLST is offline   Reply With Quote
Old 02-24-2009, 09:16 AM   #15383
STLNLST's Avatar
racenut loves me.......see ya sometime soon bro. It's going to be a great season.
Old 02-24-2009, 09:26 AM   #15384
Scott B's Avatar
Trader Rating: 43 (100%+)
No one loves you, and it would have been a great season for you if you would have kept your Cyclone.
Now go back to replacing your bearings in that tamiya, you have a B main to get ready for!!!
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 02-24-2009, 09:27 AM   #15385
Trader Rating: 18 (100%+)
HAHAHAHAAAA...he don't love me!!! HAHAHAHAHAHAAAA
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-24-2009, 09:35 AM   #15386
Trader Rating: 28 (100%+)
Wow.Whats with all the clutter on this thread?I will have to get Richard Pedro to come and regulate here too.
Should have kept the Cyclone.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 02-24-2009, 09:38 AM   #15387
Man, I go to type a few PMs and come back to see all these shenanigans going on.
Old 02-24-2009, 10:00 AM   #15388
You NEED to get another one...
I need company lapping STLNLST and his blue car.
Old 02-24-2009, 10:01 AM   #15389
Shenanigans...wait 'til the Reedy! I'm sure you haven't seen anything yet...LOL
Old 02-24-2009, 10:19 AM   #15390
I was at the 06 carpet nats in stockton... I know some of the shenanigans that go on LMAO.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
