Old 02-19-2009, 08:59 AM   #15346
rc pete's Avatar
Originally Posted by bradwant2gofast View Post
I just bought a cyclone s rtr a couple of months ago. this is my first touring car. I am running in a class where we run sidewinder 4600 and lipos 7.4v 5000mAh packs. my interal is 2.4375 and i run a 42 pinon and 96 tooth 64 pitch. We are racing on a tri-oval. What I wonder is what spur and pinion combinations are you all running. wide open people are pulling away from me. any info would be appriciated.
You should be getting enough power with 4600 NiMHs and 5000 lipos, if they're in good shape. Are you running the included closed end-bell 27turn motor? The power package in most RTRs is great to get you started, and usually low maintenance, but it won't be as competitive as aftermarket stock motors out there. Check to see what the quicker guys are running at the track, and also where they gear them at. Stock motors have different powerbands (either torque based or RPM based) and to get them to run properly they'll need anywhere from 7.5 to 3.5 FDR (Final Drive Ratio).
Also, whatever the quick guys run for gearing, start a tooth or two lower, check your temperature and work your way up from there if the motor is running cool. I gave my FDR out to someone with 'ham-hands' and they cooked their motor in 5 minutes.
The other thing you'll get with a quicker motor (brushed) is more maintenance. With agressive brushes you'll be rebuilding it every two runs. With less agressive brushes you may get a few runs.
That's the beauty of a brushless system... no maintenance.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 02-19-2009, 09:09 AM   #15347
RC MARKET's Avatar
Originally Posted by grapejuice View Post
Anyone got an extra set of shocks or a diff???????
Diff instock !
RC MARKET is offline   Reply With Quote
Old 02-19-2009, 10:56 AM   #15348
ShaunMac's Avatar
Originally Posted by RC MARKET View Post
Diff instock !
He is looking for something used at a lower price.
But if you do end up having to buy a new diff. Be sure to get the Pro-Spec diff. It will save you a lot of headache.
You say the old diff was junk. Perhaps just replacing the rings and balls would revive that old craptastic diff. That would help save some money.
ShaunMac is offline   Reply With Quote
Old 02-19-2009, 12:01 PM   #15349
Korey Harbke's Avatar
I know this probably isn't 100% ok, but I figured I'd give you guys a shot at this as well since you're all cool . I'm selling some Much More Racing stuff like a CTX-D2, Marc Reinhard Cell Master, Black Battery Heatsink, and Black Battery Warmer. Here's a link, just send me a PM.
http://www.rctech.net/forum/5435899-post4496.html
Thanks guys. The starving college student needs to eat LMAO.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-19-2009, 12:22 PM   #15350
grapejuice's Avatar
Trader Rating: 126 (100%+)
Yeah the diff is done, the holes in the gear for the diff balls are all wollow'd out, outdrives are done, about the only good thing are the rings (I got screwed on a trade for this car ). But, yeah if I do buy something new it will be the Pro-Spec. I still can't find someone that has a complete set of shocks, speedtech has one pair in stock
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 02-19-2009, 12:46 PM   #15351
ShaunMac's Avatar
Sorry to hear about your trade. Sometimes trades work out great and sometimes.......well you know.
Try calling Billy at Speedworld in CA. He's got a lot of HB parts IN STOCK.
916-783-8864 or email - SPEEDDOG@MINDSYNC.COM
Old 02-19-2009, 01:11 PM   #15352
grapejuice's Avatar
Thanks, just sent him an email!
Old 02-19-2009, 01:37 PM   #15353
will the tc chassis fit on the moore cyclone without any mods? need a new chassis and wud rather have the tc one instead...
thanks
mwoods is offline   Reply With Quote
Old 02-19-2009, 01:47 PM   #15354
ShaunMac's Avatar
thanks
Yes. The screw pattern is the same on both chassis'. All the older bulkheads will bolt right on to the new TC chassis.
Old 02-19-2009, 02:49 PM   #15355
i thought it was just wanted to make sure b4 i order one
thanks..
Old 02-19-2009, 09:43 PM   #15356
gentleman81's Avatar
Default elec comparison
out of the models that are out for this car, what is the one that is proving to be the most bang for the buck. comparing this car against all the elec big dogs
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 02-20-2009, 09:46 AM   #15357
ShaunMac's Avatar
The TC is the current production model available in the Cyclone lineup. You can still find the older versions if you look around. Best "bang for your buck" in the world of competition touring cars has to be either the Cyclone TC or AE TC5.
TC Improvements over previous Cyclones - from Hotbodiesonline.com
Pro Spec Ball Diff in rear - IMO the biggest improvement.
HB Two-Way front one-way/spool
Larger 18T center pulleys
FRP middle block deck for increased rear traction
Revised main chassis for improved weight distribution
Altered upper deck with provisions for HB ATC (Adjustable Torsion Control) posts
Stronger upper bulkheads for improved crash protection
Thicker low-mount shock towers to fit extra-low bodyshells
New reversible suspension arms with more suspension mount options
Easy-adjust sway bar holders for fast fine-tuning
Moulded battery tray for easy fitting of batteries
Extra-efficient universal dogbones
Fantastic lower price
Old 02-21-2009, 08:34 PM   #15358
deanomgwhiteguy's Avatar
Send a message via MSN to deanomgwhiteguy
hey guys
wat would be the difference if you removed the rear pro diff and put in another one way diff because im having a problem with them having a even output im not sure wether i should just but some locktite on the screw that holds it together or just put in a one way.
also in my front drive shaft wear u put the pin in for the axle, my pin sometimes comes loose and snaps, its only hapend 3 times but it is still very anoying if anyone has ideas that could help me they would be apreciated thankz
Dean Mellor
Xray T2'007/KO/ORION
AE SC10
deanomgwhiteguy is offline   Reply With Quote
Old 02-22-2009, 05:04 AM   #15359
sparksy's Avatar
Trader Rating: 14 (94%+)
Originally Posted by deanomgwhiteguy View Post
hey guys
If you put a oneway in the rear you will have no brakes. And I'm pretty sure your belts will not line up with the pully. Take your time and re-build the diff correctly. Take it in to HERC and get Kieth to help you.
As for your front pin. They usually break if your steering lock is too much. Check to see that your end points are set correctly, and limit the steering throw if needed.
sparksy is offline   Reply With Quote
Old 02-22-2009, 07:57 AM   #15360
RC MARKET's Avatar
TITC 09
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
