Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-02-2009, 10:01 AM   #15226
Hello everyone. Just wondering if any of you had heard clicking noises coming from the center pulleys when you put tension on the belts.
Realtek is offline   Reply With Quote
Old 02-02-2009, 12:08 PM   #15227
[quote=STLNLST;5376280]I believe that the only way that you are going to be able to hit that gear ratio is to run a 110 or 112 spur. Both of those will have the spur hanging out of the bottom of the chassis unless you have the brushless motor mount. What motor are you running that you want a gear ratio in the 11's? Is it a brushless 4.5 motor? I use to run mine at 11.1
I am running a nosram 3.5 and ive been told to run up to 12 FDR on a tigh twity track .
Are you running the BL motor mount , and is their another way to get up to 12 without the BL mount , or do i need the motor mount ?
cyclone speed is offline   Reply With Quote
Old 02-02-2009, 12:33 PM   #15228
Originally Posted by STLNLST View Post
I like men.
TRAITOR!!!!!
Guys, he drank the BLUE KOOL AID! and ate the biscuit in the toilet
SMC, HB, BN Racing
"THE ALMIGHTY DEMENTED ADVIL"
"Moist"
Advil is offline   Reply With Quote
Old 02-02-2009, 03:39 PM   #15229
STLNLST's Avatar
[quote=cyclone speed;5377113]
If you hope to get those final drive ratio's without having your spur gear stick through the bottom of you cahssis you will have to get the brushless motor mount. This bigger spurs allow for the 11-12 FDR.
STLNLST is offline   Reply With Quote
Old 02-02-2009, 03:44 PM   #15230
STLNLST's Avatar
Originally Posted by Advil View Post
I THINK AY IS CUTE
Two can play that game.
Old 02-02-2009, 03:49 PM   #15231
Rommel's Avatar
For anyone interested I will have an application available of my "Custom Cut Urethane Chassis Protector" for the Cyclone #HB70728 chassis soon. PM me or check out link in my signature.
Rommel is offline   Reply With Quote
Old 02-02-2009, 03:49 PM   #15232
[quote=STLNLST;5378005]
AY IS SEXY IN MY EYESQUOTE]
Get it right...ROOKIE!!!!
SMC, HB, BN Racing
"Moist"
Old 02-02-2009, 04:15 PM   #15233
KustomRCGraphic's Avatar
Originally Posted by KustomRCGraphic View Post
Cyclone TC for sale, 2 weeks old, built and raced at the Snowbird Nationals on carpet, it is as new. Has the aluminum front steering knuckles, extra of each belt new in package, 2 packages of extra arms, 1 package of front c hubs, and extra hinge pins, plus loose, new parts. Asking $325 delivered in the US. I will ship internationally, for cost. Also will consider reasonable offers. Please email me at kustomrcgraphics@aol.com
Sold.
www.KustomRCGraphics.com, JConcepts, Epic/Trinity, XFactory, RCSignup
KustomRCGraphic is offline   Reply With Quote
Old 02-02-2009, 05:10 PM   #15234
artwork's Avatar
Originally Posted by kentech View Post
Ronald Völker's Cyclone at the Indoor Euros this weekend...
Looks like a Tamiya style steering system...Lots of changes on this car. This looks like the direction that Hara was talking about at worlds.
Let your racing speak for your skills!
artwork is online now   Reply With Quote
Old 02-02-2009, 11:18 PM   #15235
I had the same problem. Turns out that the pulley attached to the front belt moved and dissengaged from the pin because of the excessive play. I replaced the stock spacer with a traxxas revo part. Problem solved.
jay272 is offline   Reply With Quote
Old 02-03-2009, 12:32 AM   #15236
Ok , thanks for the info , i think il get the bl mount.
Old 02-03-2009, 02:47 AM   #15237
Lonestar's Avatar
At the old carpet track we had out here what we did in the morning was just run our basic set up's and not really change it. In the morning the track didn't have too much grip and the car had a push. If we made adjustments to get more steering we would spin ourselves into the ground once the traction came up. In the mornings we would just basically learn the track layout and get ready for the 1st round of qualifying. Small adjustments were made during qualifying when the bite would come up but the set up pretty much stayed the same. This would be the case at every club race so you already knew what to do. Learning the layout is all that morning practice was for.
ours is a bit trickier
doors open at 8
track opens at 8:15 for free practice with encouraged "turnover" to make sure everyone gets a chance
briefing 8:45
controlled practice (10 heats x1 4mn run) from 9
qualifiers from 10 to say 1:30 - 3 quals
then mains - 2 mains
then from 5:30 or so on pack up the track (not permanent)
you'd better learn the track during the 10mns that don't count cuz otherwise you end up missing the A
The only way to survive in such environments is to start with a basic setup that prevents the car from behaving erratically (read: one that has lots of rear-end grip) and progressively move grip back to the front end the whole day (I use droop and camber intake mostly, sometimes roll-centers) otherwise you end up with a car that's way too easy to drive on the pacman-like layouts we run on.
Conversely, isolating the effects of setup-changes from those of "natural" grip take-in from the track is virtually impossible, hence the need to understand setup changes impact before the due time.
Thanks all for the help,
Paul
When the drops, the BS stops.
"Ma Grand'Mere est enfermee/Dans une boite de Chicoree/Quand la boite s'ouvrira/Ma Grand'Mere sortira"
Lonestar is offline   Reply With Quote
Old 02-03-2009, 02:48 AM   #15238
Lonestar's Avatar
Thumbs down
edited
Paul
Old 02-03-2009, 09:31 PM   #15239
MauiBuilt Racer's Avatar
MauiBuilt Racer is offline   Reply With Quote
Old 02-04-2009, 11:48 AM   #15240
Has anyone run a Lipo pack in the Cyclone TC? I'm sorry if this question has been asked before....I'm new to on-road.
Brian Givens - Tamiya USA - Tamiya 801X-
Panther Tires - LRH Hobbies-
Bogi is offline   Reply With Quote
Forum Jump
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
