Old 01-23-2009, 06:20 PM   #15106
shadow102's Avatar
Trader Rating: 21 (96%+)
Originally Posted by billythekid View Post
Hi Guys,
I have a question. I have been using NIMH batteries with my Cyclone TC, and I will be attending a major race which allows both Lipo and NIMH. I will be running the stock class.
I just purchased several packs of Orion 3800MAH 30C lipo and tested them yesterday. It seems like they had less punch and top speed than NIMH. Perhaps the overall voltage is lower than NIMH.
From your experience, is NIMH faster than Lipo (with a stock motor)?
Should I try some better lipos such as LRP or SMC 5000+ MAH packs?
Which battery should I go with?
The nimh will have alot more punch in the begining of the race but over the entire run the Lipo should be faster because it holds its voltage better than nimh
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 01-23-2009, 06:48 PM   #15107
yzf-r1's Avatar
well im currently running the moore world kit
RLM, LRP, Thunderpower, Ko propo, Checkpoint, Hacker, Muchmore, FFE
Cyclone, Sf501, KP09e, 25.5 mono, 26 mono no step, GPV-1,HOR, teamwalbern promods, 5Bss...list goes on
yzf-r1 is offline   Reply With Quote
Old 01-24-2009, 12:10 AM   #15108
Korey Harbke's Avatar
Hi Darrell and Korey,
Thanks for the info. Darrell, please let me know how it handles next week. I am hesitating whether I should shave the alum part or add some washers under the motor mount / top deck.
I think there will be some issues with adding washers under the motor mount and upper deck mount. That will actually tweak the car and put a lot of stress on the upper deck. You would need to add shims under every mounting point for the bulkheads, motor mount, and upper deck mount to prevent tweaking the chassis.
Now, at this point you are raising your center of gravity of by raising a huge chunk of weight of the car itself, including the motor. I still think your best course of action would be to grind the bulkhead a little bit. It usually doesnt take very much at all.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-24-2009, 12:13 AM   #15109
If you have the worlds kit then you have a bunch of the cool stuff anyway. You have the best spool which is what you'll mostly use, and lots of the cool purple goodies. The only things I would tell you to get are the new suspension arms for more shock positions, and the new pro spec diff.
-Korey
Old 01-24-2009, 12:21 AM   #15110
Hi Shadow, which NIMH and Lipos are you using?
billythekid is offline   Reply With Quote
Old 01-24-2009, 12:25 AM   #15111
Thanks Korey, I will take your advice.
-Korey
Old 01-24-2009, 03:10 AM   #15112
shadow102's Avatar
i am currently using the IP3800 28C Lipo packs...i gave up on NImh a long time ago. Just by their design NImh discharge alot faster than lipo do. A lipo will hold its voltage constant throughout a run.
www.nexusracing.com
www.go-rc.org
Old 01-24-2009, 09:33 AM   #15113
yzf-r1's Avatar
thanks Korey your answer was just wat i needed. much appreciated.
Old 01-24-2009, 11:33 AM   #15114
RC MARKET's Avatar
Or can try IP 35C 3800Mah
RC MARKET is offline   Reply With Quote
Old 01-24-2009, 11:49 AM   #15115
I've seen some low friction belts by Excel on RCMARKET before. I was curious if they fit the car with 16t center pulleys or 18t center pulleys??? Thanks!!!
-Korey
Old 01-24-2009, 11:52 AM   #15116
KDR
Originally Posted by m8commando View Post
Here is a spring chart that I made, please take a look! Hope this helps
M8,
Nice visual chart, very helpful.
-Steve
Steve B.
HB Team Driver*Sweep Racing Tires*Speed Passion Team Driver
hotbodiesonline.com
KDR is offline   Reply With Quote
Old 01-24-2009, 12:22 PM   #15117
cyclone speed's Avatar
Hi ,
Could anyone please give me a good gear ratio with a nosram 3.5 with 5 cell mod racing ?
The tracks are medium , and the other track is a bit tighter , so could you advice me on a good ratio please, i know i went on the tighter track and i had a FRD of 9.4 and the motor temp was quite good if i would have gone higher it would have been fine .
But when i went on the medium track , i had a FDR of 9.4 and the motor was hot . so i went to a smaller pinion ( 28 to 27) and i didnt see any difference , then i went to a bigger pinion (27 to 30 and it didnt do any difference , it even made the motor a tiny hoter .
So i dont know what i should do ?
They are both carpet tracks , and the tighter track is only a tiny different then the medium track so i dont get the temp probleme .
Im running the world kit with the 16t pulley .
thanks for any help guys .
cyclone speed is offline   Reply With Quote
Old 01-24-2009, 12:38 PM   #15118
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by cyclone speed View Post
Hi ,
We always ran a 8.2FDR with 5 cell mod.
STLNLST is offline   Reply With Quote
Old 01-24-2009, 01:06 PM   #15119
Even on a tight track or flowing track ?
Old 01-24-2009, 01:21 PM   #15120
STLNLST's Avatar
On a flowing track yes. On a tigh track I would possibly be somewhere closer to 9.0FDR
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
