Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-15-2009, 04:21 AM   #15046
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by STLNLST View Post
In what? The car or the plate or both
Car mainly - but if the deal is "right" both
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 01-15-2009, 05:48 AM   #15047
Lonestar's Avatar
Originally Posted by artwork View Post
Yep typed those backwards...I will update. Thanks for catching that
np - good to have someone keeping me on my toes
Paul
When the drops, the BS stops.
"Ma Grand'Mere est enfermee/Dans une boite de Chicoree/Quand la boite s'ouvrira/Ma Grand'Mere sortira"
Lonestar is offline   Reply With Quote
Old 01-15-2009, 06:12 AM   #15048
Anemic_SluG's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Lonestar View Post
Funny - I always thought the opposite? longer links = less camber intake = less roll (all other things being equal, esp angling)... additionnally, longer links mean less IC changes with compression changes, so the IC remains higher, wich means even less roll... or am I mistaken?
thanks
Paul
From my understanding it is the angle of the link that affect camber gain, rather than the link width. The link width affects how the car rolls or negotiates the corner, if the chassis is soft and you have a short link the car will setup the corner and start to roll then come to the end rather quickly causing it to traction roll, bottom out, slide out etc. Due to the lack of side bite. See below from one of the many setup guides I have....
C
AMBER LINK
more PARALLEL - lower roll center and increase roll of the car. More traction at that end of the car. Less camber change.
more ANGLED - raise roll center and less roll of the car. Less traction at that end of the car. Can use softer shock settings. More camber change.
SHORTER - less traction. Car rolls less. Reacts quicker initially and less overall.
REAR
: more steering (but can cause rear to lift)
FRONT
: less steering
LONGER - more traction. Car rolls more to outer edge of tire and gives you more side bite. Reacts slower initially but will react more.
REAR
: less steering - need more camber
FRONT
: more steering
Schumacher USA - TurtleMaster Racing
Speed Passion - Core-RC
www.racing-cars.com
Anemic_SluG is offline   Reply With Quote
Old 01-15-2009, 08:13 AM   #15049
Lonestar's Avatar
it's both - actually, from a purely geometric standpoint, the length of the upper link has an even higher effect of camber intake on the wheel than its angle vs. the lower A-arm. Take a piece of paper, draw it with a circle drawer and you will figure it out easily
Now, when it comes to figuring out how camber intake affects the car, it's a completely different question... regarding this one, it depends on the rest of the car setup and the tires you use. "it depends"
Paul
Old 01-15-2009, 09:09 AM   #15050
Lonestar's Avatar
guys - on a sidenote, just wanted to point out i received OUTSTANDING service from rcmarket, whose folks regularly hang around this thread. They deserve credit for what they do and the way the treat customers.
Paul
Old 01-15-2009, 09:46 AM   #15051
Korey Harbke's Avatar
Send a message via AIM to Korey Harbke
Lonestar has the right idea. The closer the upper arm (camber link in our case) gets to being equal length with the lower arm, the less camber regression (going more negative) there will be. When the upper and lower arms are of equal length it gives pretty much zero camber change. When you go shorter, it increases camber change (it goes more negative) as the suspension is compressed.
How does this effect the car? Longer will typically create more overall traction in the middle and exit of the corner, but it makes the car react slower intially. When you make the links shorter it increases initial grip and has less traction in the middle and exit of a corner. Higher traction tracks with a twisty layout will favor shorter camber links and lower traction tracks with a longer sweeping layout will favor longer links.
It does depend a little on where you are making the change though. What I just outlined is specifically when you change the camber link length from the bulkhead. The outer mounting position will have some different overall results when changed. On the HB Cyclone we have two different camber link mounting positions on the rear hub carrier. The inner one will make the rear end react really quick initially and have more overall grip through the turn. The outer mounting position makes the rear end of the car react a little slower, but it also reduces grip in the middle and exit of the corner. I use the inner position in most conditions, but with my foam tire carpet racing I've been testing a lot of, I have been liking the outer position a lot.
The angle of camber links also messes with camber change as well. Flatter links will give less overall camber change. They produce a little bit more initial grip, but for the most part they produce less overall grip through the middle and exit of a corner. More angled links will produce slightly less initial grip, but more grip in the middle and exit of a corner.
Hope that helps!!!
-Korey
Hot Bodies USA - HPI Racing - Atsushi Hara Racing Products - Team ORCA USA - Thunder Power R/C - Parma PSE - Ko Propo America - PPD Billet - Slapmaster Tools - Turtlemaster Racing - Remote Control Hobbies - Timezone Raceway - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-15-2009, 09:51 AM   #15052
STLNLST's Avatar
I will PM you once I take all my electrics out and get the parts together.
STLNLST is offline   Reply With Quote
Old 01-15-2009, 10:07 AM   #15053
RaceAce701's Avatar
Trader Rating: 30 (100%+)
ok gusy iv got a TC coming i was womdering id there is anythin i shud watch 4 as i build it
the last cyclone i built was the Original black car and i know there were a few minor sports that needed attention just wondering it there is anythin dramatic 2 watch 4
"Go for broke or go home broke"
"If it ant broke your not trying"
eXpress Motorsports -- Team Driver
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-15-2009, 10:47 AM   #15054
Originally Posted by Korey Harbke View Post
Hope that helps!!!
-Korey
Yes....... Thank you Korey it did help !!!
Lazer Guy is offline   Reply With Quote
Old 01-15-2009, 12:35 PM   #15055
Set up posted at www.gearchart.com Take a look and let me know what you think. It's posted under Sean Williams.
Hi STLNLST ,
Do you have a picture of the track you ran on , because the setup is under a open track and im running on a meduim-tight track , and also , was the rear end of your car sliding a bit trough chicanes or at the exit of the corner , thanks if you could answer me , i appreciate , thank you.
cyclone speed is offline   Reply With Quote
Old 01-15-2009, 12:39 PM   #15056
STLNLST's Avatar
Originally Posted by cyclone speed View Post
Hi STLNLST ,
Car was planted. No sliding. You can find pics of the track at www.amainhobbies.com click on the track portion of the website. The pics on there are not of the current layout though.
Old 01-15-2009, 01:30 PM   #15057
So i might try the setup at the track on sunday but ive been told that less shims under the pivot blocks will produce more grip , is it true , because if it is the track must have been really really really high grip , and also what is the effect of more shims under the pivot blocks ?
Old 01-15-2009, 02:21 PM   #15058
STLNLST's Avatar
The track was high grip. Try the set up out first before you make changes.
Old 01-15-2009, 05:27 PM   #15059
Team STPN's Avatar
No...Got me a blue car now.
What are you prejudice against black cars???
Team STPN is offline   Reply With Quote
Old 01-15-2009, 05:29 PM   #15060
Team STPN's Avatar
There's going to be a black cyclone with hop up's and spares for sale by the weekend. If anyone is interested in a PPD tweak plate I'll have that for sale as well.
Will it fit a TC5??
Forum Jump
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
