Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-14-2009, 11:33 AM   #15031
RaceAce701's Avatar
Trader Rating: 30 (100%+)
thanks that was wat i was looking 4 ill prob use ae springs as that all i got right now till i can fund a deal on some x rax one
just trying 2 get everything straing as im going 2 b swiching bank 2 my belovid cyclone after takin a another maufactures car thru the paces for a few months but i miss my cyclone
"Go for broke or go home broke"
"If it ant broke your not trying"
eXpress Motorsports -- Team Driver
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-14-2009, 01:06 PM   #15032
rc pete's Avatar
Originally Posted by STLNLST View Post
Set up posted at www.gearchart.com Take a look and let me know what you think. It's posted under Sean Williams.
Wow, definitely a different way to get the balance:
- Higher roll centers (3 vs. my 1 to 1.5 shims) and geometry (inboard toe 0 front and 2 rear vs. my 1.5-2.5 front and 3 rear) should make the car a little more twitchy and corner flatter
- Slower damping (5-10W higher than mine), 1 rate softer springs, longer rear upper link and ackerman (3mm vs my 4) should then smoothen out the car and give back some mid corner roll.
In the end, it might balance out to something similar to what I'm running. But it's the first setup that's quite different from everything else I've seen.
Hot Bodies USA - HPI Racing - Atsushi Hara Racing Products - PM Hobbycraft - Raceway Hobbies - carcar.ca - www.virtualrc.com
rc pete is offline   Reply With Quote
Old 01-14-2009, 02:02 PM   #15033
STLNLST's Avatar
I was thinking the exact same thing when the set up was given to me. I questioned it even while putting it on my car It never felt twitchy IMO. The car was planted. The only different thing I'm going to try the next time out is switching to the 3 hole pistons but leave everything else the same. I'm curious to see if the laptimes are slower, faster, the same. If you get the time try it out and see how it handles compared to your current set up.
STLNLST is offline   Reply With Quote
Old 01-14-2009, 03:04 PM   #15034
rc pete's Avatar
Yes, the time might be an issue at the event, with pretty limited practice. But I'll see how it goes. Worth trying, I think.
Old 01-14-2009, 03:23 PM   #15035
m8commando's Avatar
They list the pinks at 17.9 and the blue's at 15.3 As far as actual I have no clue. If you don't have the exact springs try using something close in what ever brand you choose. Me personally I like the Xray springs because they are fully colored and not just the ends where they can flake off. If i decide to run my Xray springs on this set up I would go white front (17.5) and blue/green rear (15)
Here is a spring chart that I made, please take a look! Hope this helps
JAF RACING / TEAM ASSOCIATED / LRP / REEDY / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-14-2009, 03:50 PM   #15036
STLNLST's Avatar
The rear hub is a mistake. It's the inner hole not the outter. I'm going to go change that right now.
Correction made. www.gearchart.com
Old 01-14-2009, 06:08 PM   #15037
trickd122's Avatar
Default Shims
What is the difference between addind shims on the outer part of the camber links as opposed to the inside? Also makinf the rear part of the hinge pin higher than the front does this give mor traction, please explain as detailed as possible.
-Thanks
trickd122 is offline   Reply With Quote
Old 01-14-2009, 06:10 PM   #15038
Hebiki's Avatar
-Thanks
where's Korey Harbke when you need him?
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
Hebiki is offline   Reply With Quote
Old 01-14-2009, 06:25 PM   #15039
artwork's Avatar
-Thanks
I adjust the links on either the inside or the out side based on what I am trying to accomplish with the links. If I want them to be flat then I will add shims on the inside (because the hub sits a lot higher the the inside ball stud). If I want more angle (outside ball stud sits higher then the inside ballstud) then you can add them to the outside.
...If I want the chassis to roll more I will make sure the links are angled (outside sits higher then the inside). If I want to reduce roll then I make sure they are flat. Obviously there is a lot of in between options.
I almost never add shims above the c-hub. There seems to be enough difference to accommodate any links changes on the inside.
Length of the link also matters...Short links makes the chassis rolls deeper into a corner thus increasing grip. Long the car rolls less.
Let your racing speak for your skills!
artwork is online now   Reply With Quote
Old 01-14-2009, 08:38 PM   #15040
STLNLST's Avatar
There's going to be a black cyclone with hop up's and spares for sale by the weekend. If anyone is interested in a PPD tweak plate I'll have that for sale as well.
Old 01-14-2009, 09:55 PM   #15041
Team STPN's Avatar
Giving up???
Team STPN is offline   Reply With Quote
Old 01-14-2009, 10:03 PM   #15042
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
oh?!?!
I'm interested
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 01-15-2009, 12:12 AM   #15043
STLNLST's Avatar
Originally Posted by Team STPN View Post
Giving up???
No...Got me a blue car now.
Originally Posted by k_bojar View Post
oh?!?!
I'm interested
In what? The car or the plate or both
Old 01-15-2009, 12:46 AM   #15044
Lonestar's Avatar
Originally Posted by artwork View Post
Length of the link also matters...long links makes the chassis rolls deeper into a corner thus increasing grip. Short the car rolls less (not as much camber gain).
Funny - I always thought the opposite? longer links = less camber intake = less roll (all other things being equal, esp angling)... additionnally, longer links mean less IC changes with compression changes, so the IC remains higher, wich means even less roll... or am I mistaken?
thanks
Paul
When the drops, the BS stops.
"Ma Grand'Mere est enfermee/Dans une boite de Chicoree/Quand la boite s'ouvrira/Ma Grand'Mere sortira"
Lonestar is offline   Reply With Quote
Old 01-15-2009, 03:13 AM   #15045
artwork's Avatar
thanks
Paul
Yep typed those backwards...I will update. Thanks for catching that
Forum Jump
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
