Old 01-21-2009, 03:03 AM   #436
i plan to get from a member.. so is this charger still good even tho it was updated? will it last long??
want extra money to buy RC stuff http://www.emailcashpro.com/?r=gigikayu
mr.gigi is offline   Reply With Quote
Old 01-21-2009, 05:28 AM   #437
todd8603's Avatar
Default not working
Regarding not working.. maybe confirm that none of the buttons are stuck. This may affect operation. Just a quick and easy way to check.
My orion is 2 years old and works reliably every time. NOt a ton of use. Only about 2-3 times per month since new.
As for balancing, my peak 3200, after two years of running this was subjected to a balancer for its' first time. IT took exactly 2.5 seconds to balance. The same for my backup 3200. However, my 4800 peak, that had been run to empty several times(I think), took about 20 minutes to balance. While I have not seen performance f these since blance, I am not expecting a miracle that makes them fly like the wind(more than before)
todd8603 is offline   Reply With Quote
Old 05-28-2009, 02:53 PM   #438
moxford's Avatar
Angry advantage charger not working
hi guys,
I've got a Team Orion Advantage charger, and up to today was working fine. I left some batteries on charge over night, trickling, and when I got back to the charger it was locked up, I disconnected it from my power supply, and batteries. I turnede my power supply back on, but all I get across the top of display is a row of squares. Can anyone help me?
Team C T8E, Hobbywing XE-Run 150A ESC and 2200KV sensored motor
moxford is offline   Reply With Quote
Old 12-01-2010, 08:49 AM   #439
zax's Avatar
Default My setup button not working.
Hi guys,
My charger's setup button is not working, usually when i depress the button, there will be a beep sound but now it's not functioning. I had opened up the charger and use a multimeter to test the button 'tact switch', it's working fine. Hope you guys can help me. Thank you.
zax is offline   Reply With Quote
F/S Team Orion Advantage Charger dragracer72nova R/C Items: For Sale/Trade 5 05-31-2008 11:36 AM
team orion advantage charger lorider75 Radio and Electronics 2 03-24-2008 08:19 PM
Team Orion Advantage Charger J_Longbrake R/C Items: For Sale/Trade 10 12-06-2007 07:09 PM
New Team Orion Advantage Charger Benro Electric On-Road 4 11-14-2005 10:09 AM
Team Orion Charger ( The New Advantage) BCOLEMAN R/C Items: For Sale/Trade 0 04-18-2005 12:22 AM
SEO by vBSEO 3.5.0
