beginners question re: car tuning and motor tuning!
Hi,
I am currently runing a team orion rush 23 turn motor, with a novak super rooster, on a tamiya TT-01 chasis. I race with a coupple of friends of mine who all have stock Tamiya's with tamiya sport tuned stock motors and manual speed controllers.
My car doesn't seem to perform any better then the stock cars and so I was wondering if there are any tricks to set up the car better (already running bb, aluminium propeller shaft).
Do I need to change the timing on the motor? If so, how much do I turn the end bell???
How do I true the comm, will this help?
Thanks heaps for your help!
Captjono
Captjono
do the ff:
1- cut the comm
2- make sure you have decent packs
3- get a better esc
1- cut the comm
3- get a better esc
The Rush motors aren't particularly good quality, so that may be part of the reason.
You can get a faster wind motor (15/17 turns shouldn't be too much for a TT01) of a better quality (for example, from Orions range, get a Pro BB or the new V2 version) and that should make a difference.
As the others said, cleaning the motor, and getting it rebuilt with a comm cut and new brushes should help too.
Thanks heaps!
*by the way* - I thought that the super rooster was a good esc!!!!???
try upgrading your kit....the one your using has limited tuning options.....also, try to lathe the comm of ur motor. havnet tried using the motor the your using but most 23t motors have fixed timing.
