Old 02-27-2005, 09:39 PM   #61
picco007's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Then, I am getting the integy discharge trays by the end of this week. I will put the cells on in the morning and then finish them up on the ics.......I hope to get some good mah's in....
EA Motorsports
picco007 is offline   Reply With Quote
Old 03-01-2005, 10:29 AM   #62
Rocky V.'s Avatar
If you are charging with an old Millinium, you must be charging in the NiCd linear profile. You can adjust the delta peak down if your packs are getting too hot. I have had good luck and duribility charging at 5a with 48 dp. They come off warm take 4200-4300 after comming off the tray...
Rocky V. is offline   Reply With Quote
How many cycles before equalizing down to 0.7v?? Loverc Electric On-Road 5 02-12-2008 09:38 AM
WTB Equalizing Tray Shawner85 R/C Items: Wanted to Buy 2 04-10-2007 11:38 AM
Equalizing To 0.7Volts Tpg racer Electric On-Road 10 12-07-2006 11:04 AM
Equalizing/Discharge Trays? JPPatterson Rookie Zone 2 12-09-2004 04:26 AM
Equalizing tray Brandon Melton R/C Items: Wanted to Buy 2 03-19-2004 08:08 PM
SEO by vBSEO 3.5.0
