Trinity duo3.5 new motor
#526
Just got qty 2 D3.5s to be used with my tekin rs speedos in 1s 1/10 pan oval classes. A 17.5 that will be run in open boosted speedo class, what amp draw or motor timing setting and what boost and rpm settings will be a good start? the other motor is the D3.5 13.5 i will use in the blinky class, what amp draw or motor timing setting is a good start in blinky? These will be 100-150 ft size carpet ovals both motors
How do you measure for the sensor voltage problem with tekins so I can make sure I wont have day of race problems?
#527
QUOTE=marcomarino35;11462059]I want more stright speed...[/QUOTE]
Please.. Some advice...
#528
Some of this is true. If you have an esc that is only providing 3.5v with a properly charged receiver pack OR a properly functioning booster you have a failure in the sensor port.
It has nothing to do with the age of it.
It occurs when a voltage spike back feeds through the system, blows a component and increases the resistance of the circuit. This is where the voltage drop occurs. We only see this failure on 1s setups.
#529
Please.. Some advice...[/QUOTE]
Your timing is way high. These motors are only meant to go to 25* max. Did you dremel the endbell to turn it further? If you need more speed lower your FDR to around 3.8-3.9 and drop your timing to around 20*. You should never need to go higher the 25* on this motor.
#530
No, i didn't dremel the endbell... The zero in the endbell it's 30* effective, i use 15* in the endbell, right 45 effective
#531
Get a dvom, power up the car, battery negative to the first pin on the sensor harness of the motor, should be 5v or more...if you're running some boosters it maybe a touch lower, say 4.8v.
#532
#533
DVOM= Digital Volt Ohm Meter...yeah.
#535
ever tried cranking the endbell all the way? When I used to run a 1705 duo3 I was at 3.8fdr timing all the way to the 4th line.
#536
Hello Marco,
they gave you the correct answer, longer fdr and lower timing to 20/25. Try this! Radaelli was running in this config and he was satisfied.
Tell me if you need more help.
Ciao, Ruggero
Hello Marco,
Ciao, Ruggero
