what can you do to stop a twitchy front end on carpet
what can u do to stop a twitchy front end when driving on carpet the car felt like i could not drive it this past week end at the birds i tried dual rate,camber,turn dwn steering expo just felt skatey for the tc4/pro4 plse help need to be a better carpet driver
set up ...
please post your set up and you might get a better response .. :D
Re: set up ...
Originally posted by mb racer please post your set up and you might get a better response .. :D |
rubber tires or foam tires?
-Korey |
he said he was at the birds.. i'd guess foams...
i had that problem, playing around with the upper shock mounting positions helped some, as well as going from purple to magenta on the rear. |
Are you running any toe in the front? I try to keep mine close to zero as possible too much toe out makes my car twitchy too. Maybe soften up the front a little too. If there is too much body roll try a swaybar.
Glue?
Did you try super glue on the sidewalls of the tires?
What tire size were you running? When the traction is high (Snowbirds, Cleveland, Novak, etc...) it is to your advantage to run your tires as small as you can. At Cleveland this past year, we were starting them at 2.24" and letting them wear down from there. |
If you've an adjustable handset, turn the steering down a bit :nod:
Chazz |
Re: Glue?
Originally posted by brianrice Did you try super glue on the sidewalls of the tires? What tire size were you running? When the traction is high (Snowbirds, Cleveland, Novak, etc...) it is to your advantage to run your tires as small as you can. At Cleveland this past year, we were starting them at 2.24" and letting them wear down from there. |
If you tried all of the above you can always turn down your steering speed in the radio...A lot of times in high bite I will do this to smooth out the steering and make the car easier to drive...
Just a thought... Good luck! Kevin |
What body???
You can also try running a little toe out.... |
