Old 09-26-2013, 07:08 AM   #616
Originally Posted by WarWest View Post
Hey Marv
What ESC do you recommend?
I want one that will give me NO problems
There really is no easy answer to this, everyone has a different need and requirement, as well as what they expect from an esc within their budget.
I see a lot of sensorless systems in my area for the general use crowd on a budget, and with the smaller size of some, it makes it easier for some to fit the small space that is available.
The voltage you are going to want to run is also a factor for ESC selection as well as motor. Not all ESC's can handle high KV motors at high voltage. Some will also be brand specific in the sensored motor category due to motor temperature sensors and feedback conflicts from the sensors.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 09-26-2013, 08:13 AM   #617
Thanks!
I guess it will have to be a trial and error sort of thing LoL
It's better to burn out than to fade away
WarWest is offline   Reply With Quote
Old 09-26-2013, 08:22 AM   #618
Also can anyone explain this "castle link" more in detail?
Old 09-26-2013, 09:18 AM   #619
Castle Link is a program you download and a cable you buy that allows you to plug your Castle brand (virtually any model) ESC into your computer and make tons of adjustments. You can change total power output, brake force, drag brake etc. in 1% increments as well as set custom throttle and brake curves and setup LiPo cutoff among many other things. It's the best investment you can make if you're running Castle brand ESC and motor.
wareagle84 is offline   Reply With Quote
Old 09-26-2013, 09:20 AM   #620
This will only work (as far as I know) with Castle electronics, including the re-badged Castle electronics like you see come stock with HPI RTR's.
Old 09-26-2013, 11:03 AM   #621
Thanks!
It doesn't have to be.
How much would you like to spend on a system and are you planning on 2s or 3s lipo?
How much adjustability would you like to have?
Waterproof/resistant or doesn't matter?
Old 09-27-2013, 08:54 PM   #622
Marv's Avatar
Hey Marv
Thanks eric!
Marv is offline   Reply With Quote
Old 09-27-2013, 09:38 PM   #623
Money doesn't matter, 2s
As much as I can get
Doesn't matter
Thanks for any help
Old 09-29-2013, 02:59 PM   #624
mrjudd77's Avatar
I have just put a new motor and esc into my car. They both come from HobbyKing. ESC is the 60a sensored type US$26.32 (XCAR) which is the same as the HobbyWing one (it uses the HobbyWing USB v3.3 for programming). Also the motor is a 10.5T Trackstar US$30.63 plus postage of a few dollars.
HobbyKing is usually very good for price and you will be hard pressed to find better. Each product has reviews and you also collect loyalty rewards based on the number of orders that you make over time.
Hope this helps
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 10-04-2013, 09:43 AM   #625
So I just got my sprint 2 flux yesterday and so far I love just wondering if they sell a kevlar rear belt or a stronger belt than the stock one and if so where can I get one?
Hpi vorza
e-revo bl
slash 4x4
salabarria is offline   Reply With Quote
Old 10-04-2013, 11:00 AM   #626
not sure if it's Kevlar, but they sell some reinforced belts for the S2 on eBay and asiatees.
Old 10-04-2013, 08:01 PM   #627
Front:
http://www.toughracing.com/zc126d/in...oducts_id=2037
Rear:
http://www.toughracing.com/zc126d/in...oducts_id=2036
Both kevlar
Old 10-04-2013, 08:02 PM   #628
Any recommendations for servos on the Sprint 2 flux?
Old 10-04-2013, 10:25 PM   #629
Marv's Avatar
I'm using the Savox 1257 MG -
But make sure you use capacitor / aka glitch buster -
There are several options in an earlier post on this thread -
Old 10-05-2013, 08:44 AM   #630
Tactic now has some pretty reliable and affordable servo's as well. The spline is the same as Futaba.
http://www.tacticrc.com/servos/index.html
Tags
hpi, sprint 2
