Old 04-30-2013, 04:58 PM   #511
Originally Posted by Marv View Post
Thanks WaftyCrank -
Scionara05 = Do you have some part numbers?
Max = GLAD you're up & running again!
See if HPI will warranty that ESC for you.
Sorry i used my 4tec as a donar and it seems really good its about a good 85% gone becuz theres no play in the rod ends the same 1 u get for the 4tec are the ones u need with the screws there 440 thread they fit perfect no forcing the screw
Felix v.
Ae sc10.2, xray t4 2015 usgt, x-ray t4 2016 tc,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 05-01-2013, 04:19 AM   #512
MaxThrottle's Avatar
Thanks WaftyCrank -
gonna have to try for the warranty, the car was slow and sometimes cut off last night *bummer*
Sprint 2 Flux w/ 2010 camaro body
41 willys Parma body, 68 primer gray Camaro beater body
65 Mustang coupe body, GT40 body
67 Vette kyosho body
MaxThrottle is offline   Reply With Quote
Old 05-01-2013, 06:37 PM   #513
Marv's Avatar
Recalibrate ESC, etc...
You might consider installing a capacitor (glitch buster) -
Marv is offline   Reply With Quote
Old 05-04-2013, 09:52 AM   #514
Slyskiller's Avatar
Does anyone know if the Tamiya GTR R35 LED Light buckets will work with HPI's GTR R35 body?
Slyskiller is offline   Reply With Quote
Old 05-04-2013, 12:31 PM   #515
Marv's Avatar
Good question.
The latest HPI GTR R35 body comes with buckets = http://www.hpiracing.com/press/17538.html
Old 05-04-2013, 09:46 PM   #516
Slyskiller's Avatar
Do you know where I can get those buckets alone? I already have the body.
Old 05-06-2013, 05:47 AM   #517
WaftyCrank's Avatar
I wonder if the GTR 35 shell that Matrixline make would fit the light buckets on the HPI too. They look a very similar shape between the two models.
WaftyCrank is offline   Reply With Quote
Old 05-06-2013, 06:00 AM   #518
WaftyCrank's Avatar
Sorry double post
Last edited by WaftyCrank; 05-06-2013 at 06:02 AM. Reason: forgot I had already posted lol
Old 05-06-2013, 11:11 AM   #519
Marv's Avatar
You might score better checking the drift threads about those buckets (?)
Or maybe the paint threads (?)
Old 05-06-2013, 03:19 PM   #520
Slyskiller's Avatar
I'll go check there and report back when I get an answer.
Old 05-10-2013, 09:24 AM   #521
Marv's Avatar
Talking Off Road S2???
Got me a set of these hoops (the center hole is already 5mm for the axle barrel nut)
I have the 13mm extenders =
HPI Sprint 2 Mods - Making a silk purse from a sow's ear.
I'm gonna see what kind of trouble I can get into...
Might go to the 19mm and my Parma 41 Willys --- (?)
ALSO:
The battery move mod coming soon (now that I'm tearing the car down for maintenance.
Old 05-10-2013, 01:20 PM   #522
Hello, I am New to R/C my Girlfriend got me the HPI sprint 2 sport and this is my first R/C I ever owned, I currently have my r/c taken apart because I am upgrading to Brushless setup. I picked up on the vektor 5900kv and a vapor esc. I saw this forum because I was searching on Lipo 2s battery to see if it fits. Thanks Marv for the post about the Lipo Battery upgrade !
khhoa is offline   Reply With Quote
Old 05-11-2013, 12:04 AM   #523
Marv's Avatar
Your GF made a wise choice (IMAO) =
The S2 is a great entry level car.
You may need this =
http://www.hpieurope.com/manuals/pdf/100424.pdf
Pay particular attention to your gearing so you don't jazz something up...
AND pay attention to detail when setting up your ESC for FAIL SAFE and LiPo use!
AND get yourself a decent charger - I use one of these =
http://www.rcplanet.com/DuraTrax_Ony...p/dtxp4245.htm
There are better and there are worse... I like it because it's affordable for me, charges 2 batteries at the same time, it will run off AC or 12v power supply or my 1:1 car battery... and it comes with the adapter wires and the balancing boards = It work's for me and my needs...
Check the threads you may find something else that you like better.
FYI = You will need about 10 (TEN) posts (and Moderator approval) before you can post pics and / or links. They are really good at being quick.
Are you going drift? Or grip race (on road at a local track)? or Street bash?
If you have a mod or something that you do differently post it up!
All voodoo is welcome here.
And thank you for thanking me.
Old 05-11-2013, 05:15 AM   #524
Marv's Avatar
Default VOODOO '57 CHEVY
This may well lead to trouble - - -
Just mocked up so far ---
I think I'd rather sacrifice the '57 than the '41 at this point...
Last edited by Marv; 05-11-2013 at 05:22 AM. Reason: "If an expert says it can't be done, get another expert." - David Ben-Gurion
Old 05-11-2013, 07:26 AM   #525
WaftyCrank's Avatar
Loving that shell, will be interested to hear how those wheels work out.
Tags
hpi, sprint 2
