Old 02-20-2013, 03:55 PM   #376
Hi for those of you who runs on asphault circuits with the sprint 2, how do you have your differential setup? Does anyone mess with it or just keeps it in stock form. Or does anyone have a writeup on running thicker weight oils or grease or whatever it is. Sorry I have the RTR version and Im trying my best to be able to keep up with the big boys. I figured this would be the best place for me to ask for setup tips.
ninjlao is offline   Reply With Quote
Old 02-20-2013, 05:08 PM   #377
Marv's Avatar
All of my diffs (except the last purchase) have been rebuilt and shimmed per
HPI Sprint 2 Mods - Making a silk purse from a sow's ear.
I'm currently running on textured and cushioned vinyl flooring
Soon to be on carpet for the Scale Nats
Asphalt won't be until the weather breaks around the end of April most likely, unless we have another false spring like last year
Mr Whiteside from the Track @ Harbor Hobbies and I discussed diff oils briefly a few months back
I believe he mentioned that some drivers use 300,000 to 500,000 wt oil in the fronts
I don't recall what he said for the rears
My S2 =
I have a silver diff tuning spring in the front to stiffen it up a bit
The rear is stock
I tried a one way diff for one night (2 qualifiers + 5 races) =
On a small track with an uber technical course - not a lot of free running room =
I didn't care for it =
I took it out
Maybe at a larger track it might have a purpose, but for now =
Not for me at my current skill level
Here's a good read = http://radiocontrolzone.com/showthread.php?t=267694
Set up Tips For Asphalt...:
Balance the car - This is going to be a challenge because the S2 is ass heavy
The battery needs to be moved forward =
This is a mod I am currently working on (more to come soon)
My car pushes big time - lacking decent front traction...
Balance the shocks - all equal lengths
Chassis protector - or a chassis that you don't mind getting scratched to hell
The OEM chassis are CRAP out of the box =
All warped =
If you want to be competitive =
(IMAO) Go carbon fiber or aluminum for accuracy
Or just stick with the OEM POS chassis
Not sure which upgrades or fixes you have done yet - if any - now's the time to tackle the ones you like that will work for you
Marv is offline   Reply With Quote
Old 02-21-2013, 04:57 AM   #378
MaxThrottle's Avatar
i noticed on mine the other day after a parking lot run my rear diff spins super free when you spin the tire by hand and my front diff does'nt spin free, it feels tight when you spin the tire by hand
Diffs are stock and i am wondering which is the one with the problem? loose or stiff?
Sprint 2 Flux w/ 2010 camaro body
41 willys Parma body, 68 primer gray Camaro beater body
65 Mustang coupe body, GT40 body
67 Vette kyosho body
MaxThrottle is offline   Reply With Quote
Old 02-21-2013, 08:35 AM   #379
Marv's Avatar
With a brand new S2 both diffs will be a bit stiff =
The grease that HPI uses is covering the gears
As you use the car the grease displaces some and the diff spins easier
HOLDING THE SPUR SO IT DOESN'T TURN
My front is stiffer because I have a tuning spring in it -
Possibly, your front had more grease than the rear (?)
Someone else with more knowledge can chime in at any time...
Old 02-21-2013, 11:20 AM   #380
Originally Posted by Marv View Post
With a brand new S2 both diff will be a bit stiff =
Do you have a picture or a part number of this spring? And what is the difference between tightening up the diff with the spring and tightening it up with the oil?
Old 02-21-2013, 03:31 PM   #381
Marv's Avatar
Sad day... as I watched the background graphics change =
No Sprint 2 Sport...
Sad day indeed...
http://www.hpiracing.com/news/2013021501/
Or maybe they just forgot...
HPI Sprint 2 Mods - Making a silk purse from a sow's ear.-untitled-2-copy.jpg
Old 02-21-2013, 05:10 PM   #382
MT, do they make funny noises or anything?
He posted it like 3 posts up.
2013 HPI Mini Recon
2012 HPI Sprint 2 Sport
1983 Marui Samurai
Slobalt7 is offline   Reply With Quote
Old 02-21-2013, 06:04 PM   #383
Marv's Avatar
I have both types - But this one is very hard to find =
HPI72215 =
This came as a diff tuning kit for the RS4 Nitro line (same diff back them as electric)
I back the spring ends with HPI72111 SHIM(S) =
This increasesspring preload
Brit Site has a bunch in stock = http://www.hpirchobby.com/hpi-gear-d...15-p-5004.html
This one is available on the net
The spring itself is different in wire thickness an overall length
I think I have a diff with one of these in it as well
I have a number of diffs....
HPI87023
I'm not the expert -
For now, I prefer using the spring method =
Less mess...
The spring is constant = won't be affected by heat/cold as much a diff oil is (IMAO)
Old 02-21-2013, 06:25 PM   #384
Marv's Avatar
Just a headzup =
Swapping out a diff on the S2 is not a walk in the park
Carefull planning and keen attention to shit that flies that ain't suppose to fly and then the follow up noises = sproing ---zoooom---clack and more...
And if you don't intend on buying replacement E clips then
A)Don't lose any and
B) Give each a squeeze to snug it up some before you reinstall it...
Old 02-23-2013, 05:44 PM   #385
Exclamation
Just a headzup =
And if don't intend on buying replacement E clips then
Excellent work on the noises Marv! I adjusted the settings on my hearing aid....just in case. lol
Nitro Ace is offline   Reply With Quote
Old 02-24-2013, 12:44 AM   #386
Gotta love taking things apart.....then while you're not looking...SPROINGO!
Old 02-24-2013, 12:49 AM   #387
Marv's Avatar
Yeah and if you have a cat it gets even better...
Old 02-24-2013, 05:50 AM   #388
No noises just that the rear spins super easy, may have to take it apart and check the lube in it i guess.
Old 02-24-2013, 05:54 AM   #389
Sad day indeed...
i only saw the E-10 Drift
Old 02-24-2013, 09:52 AM   #390
Marv's Avatar
Are you spinning wheels with the diff stationery?
Some lube will STICK to the gears even when displaced by rotational forces, some will stick..
The stuff they use (green in my diffs) is sticky....
Tags
hpi, sprint 2
