Old 02-09-2005, 05:10 AM   #1
Trader Rating: 12 (93%+)
Default cdc charger - charging transmitter batteries - help!
i am having problems charging my transmitter batteries with my cdc charger
futaba 2pl with 8 x energizer 2300mah nimh batteries
the batteries get really warm, the last time i charged them they got pretty hot that it slightly melted one of the corners of the battery holder
i have the charger set to 3mv charging at 2.0a
what am i doing wrong ?
mrgsr is offline   Reply With Quote
Old 02-09-2005, 05:48 AM   #2
Matt Howard's Avatar
you're probably charging them at too high an amperage. Try .5 amps, 1 amp at the most.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-09-2005, 05:52 AM   #3
If you are charging them directly in the battery holder, that could be a problem as well. The contacts in the holder were not meant to take a 2 amp current, and could be heating up a lot. Besides, AA nimh batteries shouldn't be charged that quickly. Go with what Matt suggested, .5 amp to be on the safer side
TPJ International
071crazy is offline   Reply With Quote
Old 02-09-2005, 06:15 AM   #4
Cole Trickle's Avatar
I'm charging 8 NiMh AA 1100 mAh at 1 amp and 3 mV cut off. Works well. These are Varta AccuPlus.
However, I have some no-name cells, and if I charge them as single cells, the CDC sometimes dont cut off. Same setting as above.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-09-2005, 08:12 AM   #5
purplepro3's Avatar
I have the new Energizer 2500 mAh and charge them at 0.5A. I also use an 8 AA battery holder from Radio Shack. Pack temp is just warm, not hot. Only problem is it takes several hours to charge them at 0.5A
purplepro3 is offline   Reply With Quote
Charging AA rechargables for transmitter sloopy Rookie Zone 10 10-06-2007 06:53 AM
Charging transmitter Batteries?? aus jd 2703 Electric On-Road 18 07-29-2006 04:40 AM
Charging transmitter packs - cutoff? AngryAsian Electric On-Road 4 06-02-2006 05:25 PM
fast charging transmitter pack whilst still in transmitter Xrayskid Electric On-Road 2 02-06-2006 03:16 PM
Charging a Transmitter LEM Rookie Zone 3 05-05-2003 04:18 PM
SEO by vBSEO 3.5.0
