Old 02-09-2005, 03:50 PM   #16
Send a message via AIM to greencactus3
CA eats lexan. so im guessing the heatshirnk isnt lexan but close to it. dont use ca on hard plastics.
greencactus3 is offline   Reply With Quote
Old 02-10-2005, 11:13 AM   #17
Carbonator's Avatar
Just curious, How exactly do you polish glue on your chassis
I didnīt polish the glue itself, but the chassis where the white shade was on. It happened while I was sealing the edges of the chassis with CA. Use a high quality automotive polish people use to polish the bonnet and roof of their īrealīcars.
"Doing left-turns only, means you're missing half the fun..."
Carbonator is offline   Reply With Quote
Old 02-10-2005, 11:33 AM   #18
Soviet's Avatar
Default Re: Battery Building Question
Originally posted by M.J
Hey guys
i am building some batteries at the moment and after the glue has dried there its a white shade all over the cells.
I have tried acetone to remove it but it still leaves a faint shade?
What do i use, turps??
What do you guys do
The problem is that you used "superglue" or cyanoacrylate on or near a clear plastic.
The white "fogging" effect is known as "crazing the plastic." This is when the gas from the curing superglue literally eats away at any nearby polymers. While the crazing effect only etches the surface, it does look ugly.
This is why scale modelers use white-glue or some other "safe" glue to attach car windshields and airplane canopys.
There is nothing you can do to remove the crazing besides sanding the cells plastic wrap with 2000 grit sand paper to make it semi-transparent again.
If it were me, I'd simply cut the cells out of the crappy shrinkwrap and rebuild with shoe-goo.
"You don't get hurt racing little cars..."
Soviet is offline   Reply With Quote
Old 02-10-2005, 04:21 PM   #19
StasI's Avatar
i had the same problem get some cotton sabs or cottom ear cleaners and rub the batts were its white if that dont work
get some eye curler brush thingmegigo and wipe them it all worked for me
StasI is offline   Reply With Quote
Battery building Dragonfish Rookie Zone 6 07-26-2008 09:53 AM
battery building buffalobill989 Electric On-Road 9 04-25-2007 07:30 PM
Battery Building Nismospeed Electric On-Road 2 12-29-2001 07:03 PM
Battery Building Nismospeed Racing Forum 1 12-29-2001 05:30 PM
SEO by vBSEO 3.5.0
