Fire In My House! From a cooling fan
#31
Originally posted by futureal
Those Radio Shack fans look like DC fans as well, there is most likely an AC->DC transformer (one of those "wall bricks") that does the conversion.
#32
You should let the Poodle plug the 12V fan into the wall!! That is a sure way of killing it or yourself!! Don't mess with that stuff, just buy one from Walmart!!
#33
dude.... first you plug a 12v dc fan into a 110v ac and wonder wuts wrong, then you think the pos/neg dont matter. god! think you should stick to buying ready-to-use fans? all i did was find a 12v fan and wired that up to a converter. like the little black things that you use to charge a cd player. see if i can post a crude pic of it. you'll know what im talking about when you see it.
#34
and with sum numberson converter
transforms an input of 120vac 60hz to a 9v. sure the fan wont be blowing at full potential but this fan is big enought to do the job easily. and this fan eats a whopping 4.3watts. and this adapter only takes .25A. since i dont own a power source this is the cheapest most reliable way for me. fan. freebie. adapter. freebie. cutting, stripping and soldering and heatshrinking 2 wires . 10 min.
#35
and on fan. this is a bigger fan than the ones most of you guys would use i think
#36
WOW
He is obviously very young or intellectually challenged. If you can not afford a fan, hold off on anymore wiring as you ARE going to kill yourself or burn your house down. And remeber to turn your soldering iron off when you are done............................... You should be supervised when doing anything dangerous. You are one lucky guy..
#37
Re: WOW
in any case he deserves one of these,
http://www.darwinawards.com/
#38
lol i know i would much rather buy a fan thats safe than rig up some fan and risk my life while using it
#39
I was at my local electrical supply house and i ask for a fan just like you. and my buddy behind the counter said 12v or 110 ... duhhhhh i was dumb founded for a sec. Then i thought a 110 fan should cool a whole thit load of stuff. So i bought , after all was said and done like fan guards and wire, a fan at walmart would of been cheeper . And to be honest in the summer that fan cools me off rather then and of my motors or r/c car stuff
#40
http://www.digikey.com/ or http://www.allelectronics.com
You will find whatever fan you are looking for. AC, DC, ball bearing, axial...
If they don't have it, it probably isn't worth looking for.
#41
BSchorr - please promise you never pit next to me... I don't want my RC life to go up in a ball of flames!
Seriously, I don't think you should mess with anything electrical. That photo of the fan and the power cord is just scary. You don't have a clue and you're going to kill yourself.
#42
Welcome to Jackass, I'm Johnny Knoxville!!!
#44
Originally posted by BSchorr
lol i only did it cause the guy at the track has the exact same fan, and all he did is put an extension cord on it.
Go buy yourself a small oscilating fan or pay the guy next to you to buy and wire the same fan he has....
Whatever you do... Please don't attempt to wire anything using AC current ever again....
#45
LOL - This is kinda humorous.. Funny, but scary. And what does dogs have to do with fans? Stick the poodles tail in the 110VAC outlet and see if air comes out of it to cool down your motors and cells.
Please let me know where you race, so I'm not at the same race as the building might burn down.
