Old 02-08-2005, 12:32 AM   #1
Default TC4 tire
Hi, just got back from the track running my TC4 for the first time didn't have a body on just couldn't wait anyway i only went around the track about four laps, and then the car seemed to handle a little funny,took it back to the pits, and when i turned it over the two front tie were crack. these are brand-new jaco first time on the car everything is brand-new when i bought them at the hobby shop he said they would fit, when i got home i read the manual it said 24mm and the ones he sold me were 28mm first question.since i like the wider tire is there anyway running 28mm on TC4 also do they make 26mm would they work. appreciate any help. thank you
rc10bob is offline   Reply With Quote
Old 02-08-2005, 06:33 AM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
Everyone I know runs Jaco 28mm tires front and rear and have had no problems. If they are rubbing on the ballcups you just need to space them out a couple millimeters and you will be fine.
If they are cracked(you are talking about the tires and not the ballcups) and you did not hit anything talk to korgae. He will take care of it. He is the rep for Jaco I believe.
CRASH is offline   Reply With Quote
Old 02-08-2005, 06:41 AM   #3
I have the same problem with mine rubbing the ball cups, what do you use to space them out with??
caleracer45 is offline   Reply With Quote
Old 02-08-2005, 06:57 AM   #4
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Even if youDID hit somthing and they are cracked...send them back to jaco and they will replace them
Team Tekin
ChrisP is offline   Reply With Quote
Old 02-08-2005, 12:04 PM   #5
Hi, thanks for the comeback but didn't understand the part about shims or do I ground down the graphite on at the ball joint thank you
MaxMod Tire Truer (large AC version w/adjustment for cutting camber into the tire) Danny-The-Dude R/C Items: For Sale/Trade 3 02-26-2007 02:10 PM
Yokomo Tire Sander / Touring Car Tire Arbor v0rtex Australia Wanted to Buy 0 03-20-2006 06:25 PM
:tire: Which is faster, 1/8th buggie or a 1/10th electric 4wd :tire: :batman: :nod: Losi boy Electric Off-Road 1 10-11-2005 06:53 PM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 02:39 PM
Integy Tire truer, Arbors 1/10 and 1/12 plus carbide tire file evostyle R/C Items: For Sale/Trade 11 03-22-2005 10:58 PM
SEO by vBSEO 3.5.0
