Like Tree2Likes
Old 09-24-2013, 06:47 AM   #1456
Cadman1981's Avatar
Exactly, that's what i was looking for, i'll ask Banzai
Here is their top arms
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 09-24-2013, 11:51 PM   #1457
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
edit
Dan is offline   Reply With Quote
Old 09-26-2013, 04:56 PM   #1458
edhchoe's Avatar
Trader Rating: 41 (100%+)
Did anyone buy the black kit? I don't see any on used market.
edhchoe is offline   Reply With Quote
Old 09-26-2013, 07:42 PM   #1459
Default New build finally underway
Finally got around to start the build of my F104 V2 titanium. What's the current thought of on a light sand & sealing the edges of the carbon fibre parts with instant cement?
My local hobby store mentioned that sealing the edges protects from delaminating but also makes the pieces stiffer with less flex.
I don't know if any of the carbon fibre parts are required to flex. The parts I was going to instant cement edge treat are the lower deck, lower brace, body mount plate, front upper deck, rear upper deck and the engine mount rear panel (C8).
Should I avoid treating any of these?
Thanks guys - No doubt more silly questions to come.
Gemec is offline   Reply With Quote
Old 09-26-2013, 07:45 PM   #1460
edhchoe's Avatar
Sealing makes the car prettier and let's it keep its good condition longer especially if you run it outside. I have had treated and non treated f1 cars and haven't noticed any difference in handling.
Old 09-28-2013, 06:19 AM   #1461
Just got my first F104. It's a V2 with the Exotech chassis and front end. I picked it up used and it's basically mint. This may be a dumb question but I can't figure out how to raise the ride height. Currently it is setup for carpet. It has the 1mm plate up front to drop the ride height. I plan to run asphault on a parking lot track. It's pretty smooth as parking lots go. I typically run my TC's 5.0/5.5 for ride height. What would be a good height setup for the F104?
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 09-28-2013, 02:05 PM   #1462
edhchoe's Avatar
rear height is adjusted by different oval inserts. there are three different ones.
front height is adjusted by the amount of space above the kingpin. more space above = more ground clearance.
Mine is set at 4.2mm f/r.
Old 09-28-2013, 02:07 PM   #1463
Thanks!
Old 09-29-2013, 12:46 PM   #1464
Cadman1981's Avatar
I have a black kit, and it's actually for sale too
http://www.rcottawa.com/forum/index....c,14587.0.html
PM me if interested
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-29-2013, 12:51 PM   #1465
edhchoe's Avatar
I found and bought a new kit for a good price. Thanks.
Old 09-29-2013, 10:11 PM   #1466
Default Spur / Pinion Gear
I now need to wait around for a new Left Diff Joint to arrive - broke it doing it up too tight
Hey guy's saw a V2 set up sheet that used a 93T spur with a 34T pinion. (producing a 2.74 FDR) Has anyone successful tried and used a bigger pinion gear on the 93T spur? How big can you go?
Old 09-29-2013, 10:33 PM   #1467
edhchoe's Avatar
It depends on the track layout but 2.7 is not that extreme. I am running 96/34 on mine currently.
Old 09-30-2013, 06:08 AM   #1468
Thanks Edhchoe. Seeing I need to get a new diff joint shipped I might as well get some pinion gears too. Some at the local track run 2.5 FDR depending on the track setup. With your setup is there much more movement adjustment to allow for larger pinion gear?
Old 09-30-2013, 09:15 AM   #1469
edhchoe's Avatar
To get 2.5 I would have to put 38t pinion. I am not 100% sure if the motor mount slots have enough room for a 38t. But I also have different size spur gears, 93 and 88t, for lower FDR.
Old 09-30-2013, 04:46 PM   #1470
Ph3nyx's Avatar
you can also use the tamiya F104 spur gear adaptor #54215 , and then use more standard spur gears
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
