Like Tree2Likes
Old 09-16-2013, 10:16 AM   #1441
Cadman1981's Avatar
Hey guys
I had a successful weekend with my F1, came in second, could had won, but my car flipped trying to pass a back marker!
I noticed something this weekend now that i got my car running well, with the Ride R1 rear wheels and 571 in the front, the car was lifting the inner rear wheels in a turn. I went to the hard rear side springs - up from the kit stock, and medium front tamiya springs, up from the Tamiya softs, and i didn't see a change.
I noticed with the Pits 571 & 575, the rear of the car would tend to want to spin around in a turn under braking or accelerating a little. I tried to shift the balance around, added weight in the rear, and then in the front, it helpped, but not by much.
Any ideas? tips? Really considering the exotek F104v2 Flex Chassis Set 2.5mm set with the F1 Adjustable Arm Set For F104, but at that price, i could get the Yokomo F1 and have 2 cars...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 09-16-2013, 12:24 PM   #1442
edhchoe's Avatar
Trader Rating: 41 (100%+)
I have 45g under rear axle and no extra weight in the front.
Is your throttle curve on exponential? And weaken the braking also. When the traction is not so high I give up accel and brake for more control.
edhchoe is offline   Reply With Quote
Old 09-16-2013, 12:49 PM   #1443
Cadman1981's Avatar
Yeah, i have the Trottle curved really soft, and my brakes are at 35%, with ABS, it's fine in a straight line, it's really when i'm into the turn.
I started reading this
http://www.thercracer.com/2013/09/ta...ew-part-3.html
The car has the same basic suspension, i wonder how much applies, as he basically had the same issue as me "he car had decided it wanted to spin whenever I lifted off the throttle completely for a tight corner."
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-16-2013, 02:02 PM   #1444
Ph3nyx's Avatar
Do you have adjust the tweak of your chassis with the lateral springs ? it's a crucial setup when you car doesn't go straight under braking or accellerating.
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 09-16-2013, 04:56 PM   #1445
Cadman1981's Avatar
I made sure to check the tweak between runs all the time, the rear pod was straight and aligned with the chassis, and the side spings were also just barely touching the pod
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-16-2013, 06:04 PM   #1446
mtveten's Avatar
Trader Rating: 27 (100%+)
shorthen your center shock so that the rear of the pod only dips 1mm below the chassis plate on blocks. Adding weight under the rear axle along with using the heavy stock axle will also help.
mtveten is offline   Reply With Quote
Old 09-17-2013, 09:27 AM   #1447
Cadman1981's Avatar
Hey guys, i am not sure if this was already posted
http://rcf1blog.blogspot.ca/2013/07/...sion-sp-1.html
What does moving the links at an angle do to make it "feel more planted"?
Note, i know that is not a F104V2
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-17-2013, 11:55 AM   #1448
edhchoe's Avatar
From looking at the photo, my physical analysis is that ...
It has to do with leverage = distance from the center of mass.
the closely spaced attachment on the main chassis cannot prevent the rear pod from moving as effectively as in the case where the attachments are farther apart from each other on the main chassis.
If a friend of yours was holding a wheel end of the wheel barrow and you were holding the handle bars and tried twisting against each other, you would have a big advantage.
Therefore, the main chassis won't have as much command over the rear pod. It will have to let it be. And the rear pod will have more traction.
By the same principle, if the pitch shock attachment on the rear pod is raised, the rear of the car will be calmer.
Old 09-18-2013, 06:37 PM   #1449
Cadman1981's Avatar
There is room on the F104v2 to move the rear links out, and put the spring ontop of the ball, like the TRF101, and exotek frame
i'm going to drill my rear stock pod and test it out
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-18-2013, 07:27 PM   #1450
edhchoe's Avatar
If you put the springs on top of the links the springs will be compressed/pre-loaded a lot. I think you will have to move the middle deck up using spacers or something.
Old 09-18-2013, 07:48 PM   #1451
Cadman1981's Avatar
Of course, 4-5mm i think, i would have to measure to be sure. Like this
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-19-2013, 07:59 AM   #1452
What are you guys using for lipos? Im just getting into F1 and picked up a sweet used F104v2 will an Exotech setup and D3. I was checking out the Revtech Double Duce shorty. Could I get some recommendations. Price is not a consideration just performance and quality. Thanks.
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 09-19-2013, 08:27 AM   #1453
JayL's Avatar
SMC
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 09-23-2013, 12:27 PM   #1454
Cadman1981's Avatar
Does any one make Carbon lower front arms for the F104?
I know that TECH racing make a top carbon arm, similar to the TRF101, i've only see some CAD drawings, no idea if anyone sells it though
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 09-23-2013, 12:58 PM   #1455
Tech Racing make a matching lower arm, part number is FCP020
It has been available for some time, but like most Tech Racing parts you will have to get it from Japan. I would suggest contacting Banzai Hobby to see if they can order it for you.
terry.sc is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
