Like Tree1Likes
Old 07-20-2013, 09:57 AM   #1321
edhchoe's Avatar
Trader Rating: 41 (100%+)
Thanks!
It is tamiya light blue.
I did light blue and white but light blue and yellow would have looked good also, IMO.
edhchoe is offline   Reply With Quote
Old 07-20-2013, 10:26 AM   #1322
thank you. but yellow / blue is more common and I do not like this color combination. while the blue there precisely associated with the white is nice. I have to paint my body F104 (F60), I chose blue / white and also orange. but I think that choose blue.
pol59 is offline   Reply With Quote
Old 07-20-2013, 10:38 AM   #1323
Originally Posted by RCformula1 View Post
As Terry.Sc rightly said. Ride R1's cause significant understeer out of the box. I do have a successful F104v2 Ride R1 Asphalt Summer setup which gives good steering. If you're interested reply and I'll post it here.
Your avatar says you're in Montreal. I wouldn't be running PS 575 or 579 rears on summer asphalt. Too hot for them and you won't get the grip.
Ride R1 rears can be successfully run with Pit Shimizu fronts. The R1 will give you the rear grip you need and I'd suggest PS 573 front's for air temps in the mid 25 degrees C. As you have them already try the PS 571's on the front with the Ride R1 rears. I personally really like this combo but some find it gives too much steering compared to the 573's.
PS. putting a harder spring on is not going to fix it unfortunately.
I'm interested in your setup!
I run R1 and 571 combination in kansas, where its often times hot in the summer. I even feel the R1 571 combo has not enough steering. The car is really unresponsive to setup changes and keeps pushing through the corners. The car is fast (less than a second off the fast 17.5 TC times) but I still lose a couple of tenths to the fast guy (i'm second fastest) which I feel is due to a lack of steering. I'm about to try Sweep fronts and see if it adds more steering.
napoleon1981 is offline   Reply With Quote
Old 07-20-2013, 11:35 AM   #1324
Are you using those tires on asphalt? I'm thinking of trying them myself.
Phat Skeemz Paint
disaac is offline   Reply With Quote
Old 07-20-2013, 05:46 PM   #1325
Yeah I run on asphalt. Im not sure what you mean with trying them myself.....
The Ride R1, shimizu or sweep?
The sweep front + rear combo is total garbage. Rear is sooooo lose, way to much steering.
The shimizu combo is good!
The ride combo is easy to drive, but very pushy
The ride, shimizu 571 combo feels very fast, but lacks a bit of steering compared to shimizu 571, 572 in my hands.
So now I want to try sweep medium front with Ride R1 rear. I will let you know my findings.
Old 07-20-2013, 07:15 PM   #1326
I currently run the 571/572 and they'er very very good, but I will give the the R1/571 combo a try.
Phat Skeemz Paint
Old 07-22-2013, 02:17 AM   #1327
RCformula1's Avatar
Originally Posted by cadman1981
RCformula1 - I am always interested! What will putting a harder spring? won't it loosen the rear? If i think about, it would make the rear slip, but won't it help the weight transfer to the front?
Last weekend the track got as high as 60 degrees (c) but was average 50-55 degrees, the Pits worked well, but the Rides worked better over the course of a race, the Pits tended to skid a little (actually sounded cool though)
Wow - that's a hot track. In Melbourne I've run up to about 55C track temp and I ran Ride R1 rears and PS fronts. The Ride R1's are a fantastic hot weather tyre but I only recently invested the time to make the front's turn in. Attached is the setup which had good rear grip and good steering.
The changes I made are listed in the notes field with the changes listed in the order of biggest impact to the smallest impact (which is the order I recommend you try the changes).
While this testing was done on a relatively cold 20C track I am hoping that they will still work as well on a hot track. The hotter track should give more grip for the R1's. If the front has more grip relative to the rear because of the track temp then you might not need to completely remove the spacer under the rear of the Pitch Damper but start by doing that and if you have too much steering try adding some spacers back.
PDF setup sheet issues - When I PDF'd the setup sheet it changed ticks in boxes to a "4" in the box. Also there is a number "3" on the right hand side of the chassis and a "1.5" on the left hand side. Ignore it - a bug in the setup sheet PDF.
Cheers
www.rcformula1.com.au - F1 car tips, news, reviews and setup articles
We publish RC F1 news and articles regularly. To see them in your Facebook news feed Like us on Facebook here - www.facebook.com/rcformula1
RCformula1 is offline   Reply With Quote
Old 07-22-2013, 04:50 AM   #1328
Cadman1981's Avatar
What does changing the angle of the shock do to the car? i'm using the TRF damper, i can't find the piece/part to make it longer like the stock shock.
Is it like on a 4wd touring? the more angle for more traction?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-22-2013, 09:32 AM   #1329
Cheers
Thanks, what do you exactly mean with forward upright position? The middle hole (of the 3) or the totally forward one?
Old 07-22-2013, 04:39 PM   #1330
Cadman1981's Avatar
I think he means this,
Notice the shock is "extended" on the forward holes, like the original kit shock
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 07-22-2013, 05:27 PM   #1331
The way I read the setup form he means a different position on the steering knuckle, but lets see what it is
Old 07-22-2013, 10:21 PM   #1332
edhchoe would you have the exact number on the cap of the spray paint, give me the blue (Tamiya PS ...)?
Old 07-22-2013, 10:33 PM   #1333
edhchoe's Avatar
Here you go.
I gave it a yellow helmet.
My four bodies..
Old 07-22-2013, 10:40 PM   #1334
thank you! and you "backé" black or white? I would say white, but I prefer to have confirmation from you.
nice bodies.
Old 07-22-2013, 10:46 PM   #1335
edhchoe's Avatar
backed with white.
I did the bottom first because it is the darkest. I didn't have black so I used left over gun metal from the Sauber project. Then I think i put 4-5 coats of blue and then did about 3 coats of white.
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
