Like Tree1Likes
Old 07-07-2013, 05:11 AM   #1291
Mr Weasel's Avatar
Default Rear axle bearing keeps shredding
Hello wise folks,
I have a recurring issue where the left hand side rear axle bearing keeps shredding. It happens every 2 meets or so.
Has anyone else experienced this? Or do you have any tips on what might be causing it?
Thanks in advance.
Mr Weasel is offline   Reply With Quote
Old 07-07-2013, 08:04 AM   #1292
edhchoe's Avatar
Trader Rating: 41 (100%+)
It has not happened to me but I suspect a bent shaft. Or the motor box needs rebuilding.
edhchoe is offline   Reply With Quote
Old 07-08-2013, 03:59 PM   #1293
Mechintosh's Avatar
Does anyone use the Aluminum Motor Spacer, 54129 with the VII?
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 07-08-2013, 04:00 PM   #1294
edhchoe's Avatar
I don't. Trf101 came with it and I don't have use for it.
Old 07-08-2013, 06:17 PM   #1295
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
You'll probably need a long shank pinion. I had the motor spacer come with my F104X1. Ended up not bothering with it after using it once. Plus on the V2, you will probably hit the other end of the bulkhead since there is not much room. The TRF101 has a wider pod so it can get away with it.
Dan is offline   Reply With Quote
Old 07-11-2013, 10:05 AM   #1296
Cadman1981's Avatar
Originally Posted by rokosam View Post
My Sybrand F104X1
By rokosam at 2012-09-01
This is an old post, but what is that front end?? looks like it has a damper in the middle.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-12-2013, 06:18 AM   #1297
Not surprisingly, it's a Sy Brand chassis kit.
http://www.sy-brand.com/
The manual for it can be found here.
terry.sc is offline   Reply With Quote
Old 07-12-2013, 07:26 AM   #1298
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Mr Weasel View Post
Hello wise folks,
Thanks in advance.
Does this occur after hitting something?
idbdoug
idbdoug is offline   Reply With Quote
Old 07-12-2013, 02:26 PM   #1299
Hello wise folks,
Thanks in advance.
have you got any movement from side to side with the rear axle, if you don't have a bit of play and you tighten up the left side hub hard against the bearing you are putting a lot of side pressure on the bearing.
Old 07-13-2013, 12:21 AM   #1300
small game on my own, to avoid forcing the axle holders.
pol59 is offline   Reply With Quote
Old 07-14-2013, 08:45 AM   #1301
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Default Ride height adjusters?
Just ran my vII for the first time yesterday, love the car.
Got it to run F1 at this years IIC, and since last year the contolled tire was Pardus, i got a set of those to tune on carpet.
However, the diameter of the Pardus tire is 64.2mm vs most others in the 61mm range, and so i'm as low as i can go on rear ride hight at 5mm, with the stock spacer on the bottom and the 2mm spacer up high.
Does anybody make a spacer larger than 2mm for the Tamiya car? LHS didn't have anything.
I can't imagine people ran this high of a ride hight at IIC last year, any ideas?
Thanks.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 07-15-2013, 06:17 AM   #1302
Cadman1981's Avatar
Hey guys, i had my first complete race with my F1 yesterday, went from no grip in my last meets to winning my race after reading all of the tips on here, and watching all of the videos for the rear pod.
Now i need to add front grip lol I tried Ride R1s, and Pit Shumi 577 and 573, the car would push in turns, under power, and under braking. I don't think it's my tires anymore.
my front is at 4.5mm high, rear 5.5, i tried little droop and a lot, barely any change. I went from 2 degrees of camber, to 1, the tires are wearing evenly across the surface at 1 degree. I have 2 degrees of Toe out, with the Tamiya Silver spring, and to stop the bouncing i use AW grease from tamiya.
How do the offset front axels affect? Can we adjust Caster with the stock F104 arms? should i consider the exotek arms?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 07-15-2013, 06:28 AM   #1303
Default front end
Hi, maybe you can consider the front end of the new F1 (TRF 101). I think it gives a better control of the front of the F104.
there is a subject in which we talk about on this forum.
Old 07-15-2013, 01:32 PM   #1304
On asphalt try pit 571 front, 572 rear. The 571 are softer then those you listed and should give you more steering.
Trailing front axle makes the steering less responsive/sensitive.
You can get reactive caster by putting spacers on the two top rear ballstuds. The caster will go more towards zero degrees as the suspension compresses. It's not possible with the stock setup if you just want more static caster.
Sydewynder is offline   Reply With Quote
Old 07-15-2013, 04:01 PM   #1305
robk's Avatar
Trader Rating: 22 (100%+)
Offset axles will make your car less reactive. This is good for asphalt or big open tracks. Inline is better for tight tracks and/or high traction
With the stock Tamiya front end, the less camber you run, the more caster will be in the car, as the top arm is pushed out to stand up the tire. At the same time the kingpin is pushed back. The shortest ballstud in the servo (rear) end of the top arm will also get more caster, but will reduce dynamic caster effect under roll/brakes.
Tamiya F104 Pro! NT Electric On-Road 9352 04-22-2017 06:01 AM
