Like Tree2Likes
Old 04-26-2013, 10:44 PM   #1201
edhchoe's Avatar
Trader Rating: 41 (100%+)
I buy stainless screw set from TQ racing for $12.
They are hex head and supplied by f1paintlab, iirc.
edhchoe is offline   Reply With Quote
Old 04-27-2013, 09:10 AM   #1202
Originally Posted by [RC10TC] View Post
Anyone know if the tamiya f104v2 titanium version 93033 comes with aluminum hex screws or does it just include Phillips head screws like the regular v2?
Neither.
Like all Tamiyas it uses JIS (Japanese Industrial Standard) screws which is why Phillips drivers don't fit properly and chew up the heads. Having built hundreds of Tamiya kits over the years (I used to build them for a hobby shop) having the right JIS screwdriver meant no stripped screw heads, and a JIS screwdriver is also useful for removing stripped Phillips head screws as well.
terry.sc is offline   Reply With Quote
Old 04-28-2013, 01:26 AM   #1203
rbarciko's Avatar
There is an articles on the Rc F1 website which explains the difference between Philips and JIS:
http://www.rcformula1.com.au/index.p...s-strip-easily
I
-== Robert Barcikowski ==-
TFTR TC6 F104v2 RC Parts Search
rbarciko is offline   Reply With Quote
Old 05-02-2013, 07:13 AM   #1204
question: when you look at the F104 chassis Pro II race ready with batteries, from the side, eyes height lower decks front and rear, is that the two plates should form a "V" (exaggerated) points up or down?
pol59 is offline   Reply With Quote
Old 05-02-2013, 08:28 AM   #1205
Trader Rating: 57 (100%+)
It should sit flat with no "V".
PROMODVETTE is offline   Reply With Quote
Old 05-03-2013, 07:03 AM   #1206
hey guys, my club is racing with controlled tires. they have set us to use the HPI potenza tires. my problem is the F104 mesh rims i got are too big..... the tires sort of sink in the middle of the tread.
what rims can i put the HPI tires on that will fit the F104?
brendon.matt is offline   Reply With Quote
Old 05-04-2013, 01:57 AM   #1207
Last thursday i've run the dark titanium with a cirtix stock club esc with a speedpassion 21.5T V3 motor and i was faster with this combination then when i was running with the F104X1 with a 17.5T motor.
It sure shows the potential of this chassis, very pleased with it
addicted2blue is offline   Reply With Quote
Old 05-04-2013, 09:15 AM   #1208
BadSign's Avatar
Trader Rating: 15 (100%+)
Only one real solution: pick another tire.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 05-04-2013, 03:16 PM   #1209
I'd have to agree with BadSign here.
Your club has managed to pick a tyre that no one else uses and which only fits the one car that no one runs. Even HPI F10 owners who plan to race them will replace the diff with the more standard ball diff, meaning the HPI Potenzas won't even fit on the car they were designed for. The only F1 you are really going to be able to use the Potenzas on is the FGX.
Choosing tyres designed for the F104 such as the Tamiya TCS tyres would mean you would have a tyre that works well and will fit just about every car on the market.
Old 05-04-2013, 03:42 PM   #1210
edhchoe's Avatar
Can Ride wheels be used for f104 and Bridgestone tires?
Old 05-04-2013, 04:05 PM   #1211
mtveten's Avatar
Trader Rating: 27 (100%+)
Avoid them, the dont fit the tires that work or the F104 correctly.
mtveten is offline   Reply With Quote
Old 05-04-2013, 10:20 PM   #1212
I ran HPI tires on the Ride rims on my F1R (F104 front end) just fine. The only real issue with them is if you need a low ride height for carpet. On a banked asphalt track we run 4.5mm to 5mm and I had no problem making that ride height.
Old 05-06-2013, 05:01 AM   #1213
jedx's Avatar
Hi Guys,
New F104v2 owner here (and relatively new to RC altogether).
Sorry if this has been spoken about before, I had a quick look and couldnt find anything.
But I am trying to run my 21.5T Speed Passion V3 motors in my new F104v2 (with the full blue alloy motor box) and the 3 Brushless wire connectors on that plug into the back of my motor foul on the alloy motor mount and would short.
Is this motor simply not compatible with the F104v2 or am I doing something wrong?
Is it time to get a Reedy Sonic for example that has the tabs on top of the motor to solder onto.
Thanks in advance for any help.
Regards,
Justin.
XRAY T4'17 x2 | X1 | X12'16 | XB4 '16 | XB2 CE
Xray | MuchMore | Nosram | PROTOform | Hudy | Proline
jedx is offline   Reply With Quote
Old 05-06-2013, 07:23 AM   #1214
TRG
TRG's Avatar
Default SP V3 21.5t
Originally Posted by jedx View Post
Hi Guys,
Regards,
Justin.
Hi Justin
I'm was running the same motor on the weekend. It does fit. You'll need to be tidy with your soldering, and I'm not using the motor plate (BA9 in the manual) between the motor and motor mount. I hope the pic help. Sorry I haven't cleaned the car yet.
TrevorG
OnRoad - TRF417V5; TRF417X; F104V2; M05 Pro;
OffRoad - TRF201
Drift - TRF415MS; TB Evolution III (Surikarn Limited)
TRG is offline   Reply With Quote
Old 05-07-2013, 04:03 AM   #1215
jedx's Avatar
Thanks for your help Trevor! (and pics)
All I needed was news it was possible, just invested the time doing neat solders and heat shrinking them, got it to work.... It's tight, but it fits.
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
