Like Tree1Likes
Old 04-24-2013, 05:17 AM   #1186
Trader Rating: 57 (100%+)
Assuming the wire is all the same size, the spring with the tighter coil (2nd in that photo) would be the softest and the looser coil is the hardest.
PROMODVETTE is offline   Reply With Quote
Old 04-24-2013, 06:41 AM   #1187
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
You could also use CRC springs.
http://www.amainhobbies.com/product_...ide-Spring-Set
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 04-24-2013, 08:54 AM   #1188
Hi. Tamiya side springs (firmest to softest) are:
Black, Gold, Silver, Pink. I agree with a subsequent post that recommends CRC springs as well, I have found them to work very well too. Enjoy your car!
Bill
Bill Jeric is offline   Reply With Quote
Old 04-24-2013, 03:22 PM   #1189
RCformula1's Avatar
Originally Posted by idbdoug View Post
I picked up used F104V2 with the Tamiya Roll Spring set
http://www.tqrcracing.com/shop/produ....asp?p_id=3306
Does someone know which springs correspond from Supersoft to Hard?
idbdoug
Check out our article on F104 v2 spring rates.
www.rcformula1.com.au - F1 car tips, news, reviews and setup articles
We publish RC F1 news and articles regularly. To see them in your Facebook news feed Like us on Facebook here - www.facebook.com/rcformula1
RCformula1 is offline   Reply With Quote
Old 04-24-2013, 03:44 PM   #1190
idbdoug's Avatar
Trader Rating: 33 (100%+)
Thanks everybody
idbdoug
idbdoug is offline   Reply With Quote
Old 04-25-2013, 08:52 AM   #1191
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I'm new to f1 but I have raced pan cars before. My problem is my car pulls to the right on acceleration out of slow corners! I have checked for tweak and, the isn't tweaked! I have loosen the diff it made the pull to the right worse, and it gave the car push mid corner. What can I do to fix this?
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 04-25-2013, 09:54 AM   #1192
what is your car?
pol59 is offline   Reply With Quote
Old 04-25-2013, 10:09 AM   #1193
robk's Avatar
Trader Rating: 22 (100%+)
Did you make sure the center pivot is correctly set up with no binding of the pod ? This must be tested with the pod plate only, no motor mount, and the springs and crossbrace off too.
Old 04-25-2013, 11:20 AM   #1194
thanks I will check the pivot ball but,when I was assembling the car it was free both directions! I will take the motor out an see. Has anyone used the TRG dual damper system an will it work on a F104V2
Old 04-25-2013, 01:07 PM   #1195
robk's Avatar
It has to be free in all directions, up down left right. You should not have anything on the pod plate- no motor mounts or any other parts, just the plate. If you feel any tight spots at all, keep adjusting.
Also, if you take a decent hit, it can throw the car out of whack. What you did on assembly may not be the car's current condition.
Old 04-25-2013, 04:47 PM   #1196
john watkins's Avatar
Trader Rating: 17 (100%+)
Hey guys, What do you guys do to reduce the weight of these things? is there a light weight chassis available?
XB2, XB4 '15, XB8 T5, B5m, Keilor off road RC car club.
Proudly Sponsored by:
Xray racing, Nosram, Proline AUS, B-Fast RC ,Much More , Hudy, JAD racing shells , Xray Racing Australia, Misfit RC Design Group, BFast RC .
john watkins is offline   Reply With Quote
Old 04-25-2013, 04:51 PM   #1197
edhchoe's Avatar
Trader Rating: 41 (100%+)
No. The car is already underweight for roar standard. I had to add 50 grams.
edhchoe is offline   Reply With Quote
Old 04-25-2013, 04:54 PM   #1198
Sweet, thats what i wanted to hear. Thanks for all the awesome help.
Does anyone know where to find a reasonable carpet setup?
Old 04-26-2013, 08:54 PM   #1199
Anyone know if the tamiya f104v2 titanium version 93033 comes with aluminum hex screws or does it just include Phillips head screws like the regular v2?
[RC10TC] is offline   Reply With Quote
Old 04-26-2013, 10:04 PM   #1200
phillips head steel (ish) screws.
For some reason the Japanese prefer this type.
I used proper hex hardware on my build and suggest you do the same.
-Pate
fastvee is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9352 04-22-2017 06:01 AM
