Like Tree2Likes
Old 06-27-2012, 10:12 AM   #106
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by theatriks View Post
what power systems are those guys using ...is that brushless or silver cans?
21.5 Blinky
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-27-2012, 10:31 AM   #107
FMW
FMW's Avatar
21.5 is the best solution for F1 direct drive. It keeps the racing close and the speeds reasonable. Anything faster and the class will die a quick death.
FMW is offline   Reply With Quote
Old 06-27-2012, 11:44 AM   #108
What FDR did you use on that track?
addicted2blue is offline   Reply With Quote
Old 06-27-2012, 12:10 PM   #109
2.9
ReedyPower 21.5
40deg
Old 06-27-2012, 12:40 PM   #110
Here in belgium we are thinking of using a carson 16T or 18T sensorless (cause we allways use sensorless motors at the tamiyacup) for our next tamiyacup season (2013), cause we have some several outdoor tracks and they have some large straights.
I think with a 21.5T blinky it would be to slow on those large straights, especially when you allready using a FDR of 2.9 on a small indoor track.
Old 06-27-2012, 02:25 PM   #111
tudor_47's Avatar
We are running 13.5T motors this year as we after last year running 17.5T motors decided to run 13.5T as the 17.5T was slow.
We are running outdoors our straight is 50meters, total tracklenthg is 187meters
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 06-27-2012, 11:00 PM   #112
That 18.5 sensor-less is probably similar in speed to our timed 21.5's
So that makes sense
For sure the Euro Nitro tracks are large, and more motor will not be an issue
We gear as low as 2.6 on our "Big" tracks
Old 06-27-2012, 11:19 PM   #113
Pro10noob's Avatar
In holland we use 2 motors in the Tamiya cup.
The Carson cupmachine(similar to the machushi silvercan) and the Tamiya Formula Tuned 32T.
Last motor will be geared as low as 2.6 on the big tracks.
Speed is indeed a bit slow but very driveble and the wear on the tires is low.
When driving it with the 17.5 brushless, the wear on the tires and gears is a lot higher on the outdoor tracks.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-28-2012, 09:19 AM   #114
regards Roy
We are using the same 2 motors for this years tamiyacup season, the carson cupmachine is faster then a silvercan but looses much to fast it's power.
It isn't the most reliable brushed motor, for best performance you should buy each racing day or at least after 2 racing days a new carson cupmachine motor.
Otherwise you won't keep up with the rest of the field.
That's why we are thinking about brushless motors, they are more expensive but with good care they last much longer.
Old 06-28-2012, 09:21 AM   #115
[QUOTE=RedBullFiXX;10909920]First race with the VII against my bud Steve and his ExotecQUOTE]
Is the version II really that much better then the realier PRO version?
Old 06-29-2012, 07:58 AM   #116
Default Need help on the setup
Guys...
I just bought f104 v2, need some help on the setup....
I will be using 17.5 brushless motor and running tamiya rubber on carpet...
The track is 30meter straight with technical infield...what fdr should I use...
Thanks for the help
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 06-29-2012, 10:40 AM   #117
I run my F104 Sybrand Scythe with 17.5T Team powers with 93/30 ratio asphalt outdoors with foam tyres an itīs just ok, much better than using rubbers. Maybe rubbers is the option for small "parking lots" with 21.5 motors as you do in USA, but for "medium" and "big" nitro tracks 17.5 +foams is much better for me.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 06-29-2012, 11:02 AM   #118
[QUOTE=addicted2blue;10914199]
Yes !
Originally Posted by k4mp4q View Post
Guys...
Thanks for the help
You are going to need more hope, than help if attempting to run the "current" Tamiya rubber on carpet
Old 06-29-2012, 11:44 AM   #119
Foams are better pretty much everywhere...we like rubber tires because they last longer and look more scale than foams. With foam tires you end up with some people cutting them down really small so they look pretty ridiculous on the car.
Old 06-29-2012, 12:32 PM   #120
wiggindude6969's Avatar
Default Rear Carbon Wing mount
Anyone seen the new rear wing mount, the hop up carbon fiber piece? Seems a bit weak, i ordered one before i actually saw it on the car... the other thing is, i can believe it didnt come with an aluminum moutor mount...
I would be super if they could come out with some type of rear diffuser for this car.... We run Rubber and 21.5T motors...
wiggindude6969 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
