Like Tree2Likes
Old 04-17-2013, 01:27 PM   #1171
policeman0077's Avatar
Originally Posted by bribtb View Post
Check your rear tires to make sure there still glued. I had a problem with that any hard throttle it would vear to the left or right.
Brian
Good point! I will check my rear tires.
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 04-17-2013, 01:29 PM   #1172
Originally Posted by fastvee View Post
Just received the Dark Titanium kit 6 hours ago, here it is all ready for electronics. (after this seasons last race on saturday I will retire my X1 that won every race over here and swap electronics to new car)
Exactly same color alloy like X1, nice!
I have a question about the hop-up carbon damper mount that I installed with few other bits: (ceramic balls,thrust bearing, carbon shaft,tit.king pins,12.9 hex hardware)
It is a lot thinner then the plastic stock part, do I add spacers to make the setup same height as the stock or just same spacers then stock?
-Pate
make the damper lower would give your car more steering while raise it will give you more traction at rear
多情自古伤离别。更那堪、冷落清秋节。
Old 04-17-2013, 06:03 PM   #1173
Thanks.
Any thoughts what would be good starting setup using 21.5t ,pit 571 / 572 combo on med/high grip carpet.
What shock oil? -springs ? (stock shocks)
I have been racing my X1 for a while now but this is my first link car and would like to test some basic setup b4 the seasons last race on saturday.
I am the points leader, but next race can still change that..
(still thinking I should ust the X1 on that race but if this could be faster ...)
-Pate
fastvee is offline   Reply With Quote
Old 04-18-2013, 08:53 PM   #1174
Thanks.
-Pate
silver spring front with ride height 3.5mm
400 oil in pitch damper with the stiffest sprint
rear ride height 4mm
1.5mm t-bar
add some weight in pod if you feel slippery
多情自古伤离别。更那堪、冷落清秋节。
Old 04-20-2013, 10:21 AM   #1175
Mr. MR4's Avatar
Default F104 Lower Front Suspension Arm #51381
Does anyone else make stronger lower front suspension arms for the F104?
The Tamiya ones (#51381) seem to break quite easily where the droop screw is attached.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 04-20-2013, 10:30 AM   #1176
edhchoe's Avatar
Trader Rating: 41 (100%+)
Try wider front wing. It will take the hit instead of the front tire when you hit something. The tierod won't hit the droop post any more in crashes.
edhchoe is offline   Reply With Quote
Old 04-20-2013, 02:37 PM   #1177
That type of breakage is usually the result of the steering knuckle being jammed into the droop posts. I've seen that type of break when someone smacks into the wall really hard, fast and often.
I'm not the best driver out there and haven't broken either the lower or upper arms although I've bent the uppers a few times.
AreCee is offline   Reply With Quote
Old 04-20-2013, 05:21 PM   #1178
Also the result of someone having their steering travel too high. Turn it down on your radio to the point it just isn't touching the post.
J-PaP is offline   Reply With Quote
Old 04-20-2013, 09:37 PM   #1179
Mr. MR4's Avatar
Thanks for the suggestions
Old 04-21-2013, 09:54 PM   #1180
1.5mm t-bar
need more information on the setup you gave...
400 oil in pitch damper... what does it do to the car when using lighter oil vs heavier oil? does it give more traction using lighter oil or it does not nothing to do with the traction?
What about the spring stiffness? is softer spring better on high grip carpet track? if yes then why? What the function of this spring on the traction, etc.
sorry to ask you this question.... since i want to know more on how to set up the car properly so when i find trouble on the car i can fix it quickly instead of using someone setup without knowing the change that i make...
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 04-22-2013, 08:44 AM   #1181
I found that originally the main frame is horizontal. so I mounted the spacers rear axle bearings "0". Now I have 4.5 mm at the front and 5.5 just before the pod. I also mounted the black side springs (prestressed 0.5 mm), one of tanguage black (prestressed 2 mm) and silver front. I replaced 3mm below the strut damper tanguage fixing by a 1 mm, the open front end of about 1 , the wedge mounted camber limited to 2 and the front droop (2 wedges mm under the screw heads).
I won the directivity, with foam tires untreated.
I intend to try soon, without spacers under damper tanguage setting, set the droop front as behind, filling the damper roll with 400 oil and gold side spring.
when I find what suits me, I will apply the treatment on the tires.
The purpose of these amendments is to get more weight transfer to the front when I let go of the throttle lever.P
P.S: I also set the drag brake 75% drag brake
pol59 is offline   Reply With Quote
Old 04-22-2013, 02:09 PM   #1182
john watkins's Avatar
Trader Rating: 17 (100%+)
Does anyone have a part number for the Alloy Tourning Car shock used to replace/Upgrade the original V2 shock? and a part Number for the optional spring kit too would be awesome.
Cheers
John
XB2, XB4 '15, XB8 T5, B5m, Keilor off road RC car club.
Proudly Sponsored by:
Xray racing, Nosram, Proline AUS, B-Fast RC ,Much More , Hudy, JAD racing shells , Xray Racing Australia, Misfit RC Design Group, BFast RC .
john watkins is offline   Reply With Quote
Old 04-22-2013, 02:17 PM   #1183
edhchoe's Avatar
TQ RC racing has the trf for f1.
Old 04-22-2013, 04:49 PM   #1184
your a legend ! cheers
Old 04-24-2013, 04:46 AM   #1185
idbdoug's Avatar
Trader Rating: 33 (100%+)
I picked up used F104V2 with the Tamiya Roll Spring set
http://www.tqrcracing.com/shop/produ....asp?p_id=3306
Does someone know which springs correspond from Supersoft to Hard?
idbdoug
idbdoug is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
