Like Tree1Likes
Old 04-15-2013, 10:00 AM   #1156
so I should just harden the rear of the car?
pol59 is offline   Reply With Quote
Old 04-15-2013, 02:28 PM   #1157
From what i've been reading is that harder side springs will give you better steering respons.
If you mean that you have an understeer problem.
addicted2blue is offline   Reply With Quote
Old 04-15-2013, 09:42 PM   #1158
especially when it is at the end of the straight, I turned in a 180 curve, the car was mainly to expand its trajectory in the corner and finds himself propelled outward from its path. it is really a very big understeer. while in the 180 at low speed, no problem, the car rolls well.
Old 04-15-2013, 10:30 PM   #1159
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
When driving rubber tire on pan car like F1
Braking from high speed is necessary
And remember, Tires are 90% of the setup as most of this type chassis have so few adjustments
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-15-2013, 10:38 PM   #1160
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
+1
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 04-16-2013, 03:46 AM   #1161
yes, work on the tire processing is required. and to be honest, I never use the brake, I anticipate by releasing the accelerator when approaching turns
Old 04-16-2013, 02:40 PM   #1162
policeman0077's Avatar
I am newbie of RC stuff. Currently I am running a f104 x1 in my club. I always feel very stressful when driving my car. It's not very predictable and can not go straight especially at
acceleration and braking. Is my car tweaked ? How can I properly disassemble and reassemble my car to release the tweak? Any other aspects would affect the car to make it preform unpredictable?
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 04-16-2013, 04:49 PM   #1163
edhchoe's Avatar
Trader Rating: 41 (100%+)
Asphalt? What tires? Front wheels pointing pretty straight +/- 1?
We cannot accelerate hard unless there is a good amount of grip. Sudden acceleration on loose asphalt will unsettle any car. Trim down brake to <80%.
edhchoe is offline   Reply With Quote
Old 04-16-2013, 11:13 PM   #1164
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
The T-bar can tweak over time or bend/snap in a really bad crash, especially the softer white T-bar that comes stock on the X1. That would be the first thing I would check. Also check your front upper arms. They can bend easily too in a big crash.
Last, you can check if your chassis is tweaked but I really doubt so. Its pretty thick and very rare that it will be out of shape.
Dan is offline   Reply With Quote
Old 04-17-2013, 07:41 AM   #1165
carpet with shimizu 0571/0572, I think front wheels are straight, but I haven't tool to measure only by eyes.
Some it's not the harsh acceleration causes off tracking, but when I was on straight with certain speed and accelerated relatively gentle, the car just not go straight.
Brake is less than 30%, maybe 20--25%
多情自古伤离别。更那堪、冷落清秋节。
Old 04-17-2013, 07:47 AM   #1166
I use 1.5mm 3racing one-piece tbar, loosing some traction but more stable and durable than the high traction one within the box of 104 x1. My upper arms are hot glued with carbon fiber rods, so it's difficult to bend....
多情自古伤离别。更那堪、冷落清秋节。
Old 04-17-2013, 08:21 AM   #1167
Make sure you check your diff. I always run ceramic diff balls on my cars, especially on my F1. They make the diff action silky smooth, and they last a lot longer than steel balls. Next, check the tightness of your diff. If it's too tight, you will have a very hard time keeping the car from spinning out on a loose track. If it's too loose, you can damage the diff and spur gear. When the diff is set right, it should not slip. I usually set mine just tight enough to keep from slipping.
Old 04-17-2013, 08:55 AM   #1168
Check your rear tires to make sure there still glued. I had a problem with that any hard throttle it would vear to the left or right.
Brian
bribtb is offline   Reply With Quote
Old 04-17-2013, 10:39 AM   #1169
Just received the Dark Titanium kit 6 hours ago, here it is all ready for electronics. (after this seasons last race on saturday I will retire my X1 that won every race over here and swap electronics to new car)
Exactly same color alloy like X1, nice!
I have a question about the hop-up carbon damper mount that I installed with few other bits: (ceramic balls,thrust bearing, carbon shaft,tit.king pins,12.9 hex hardware)
It is a lot thinner then the plastic stock part, do I add spacers to make the setup same height as the stock or just same spacers then stock?
-Pate
fastvee is offline   Reply With Quote
Old 04-17-2013, 01:26 PM   #1170
My diff is newly built and I built it as you said make it as loose as possible while do not slip when you hold the spur and a wheel and turn another wheel.
Anyway I will try ceramic balls, should be smoother any recommendation?
多情自古伤离别。更那堪、冷落清秋节。
Tamiya F104 Pro! NT Electric On-Road 9352 04-22-2017 06:01 AM
