Like Tree2Likes
Old 04-09-2013, 12:37 PM   #1141
Vyger's Avatar
Originally Posted by RedBullFiXX View Post
F-104 v2 for sale
Sweet ride, needs a home
Tamiya F-104 vII
NOOO.....
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 04-10-2013, 04:40 PM   #1142
What is the smallest spur that can be used on the V2?
capt waffles
sobiski racer is offline   Reply With Quote
Old 04-10-2013, 07:05 PM   #1143
RCformula1's Avatar
Not sure what the smallest is but I regularly use a 65t spur (48 pitch) which is pretty small. Great for getting those low FDR's such as 2.4:1 (with a 27t pinion) and larger pinions would definitely fit if you want to go lower.
More info: A-Z of Gearing for F1's
www.rcformula1.com.au - F1 car tips, news, reviews and setup articles
We publish RC F1 news and articles regularly. To see them in your Facebook news feed Like us on Facebook here - www.facebook.com/rcformula1
RCformula1 is offline   Reply With Quote
Old 04-10-2013, 10:28 PM   #1144
cmy55s's Avatar
I recently purchased a f104. I have a 69t spur on it and am planning on running 21.5 blinky. Should i aim for 2.4:1. Or go a little higher say 3.1:1 or so. Thanks pat
cmy55s is offline   Reply With Quote
Old 04-10-2013, 11:37 PM   #1145
RCformula1's Avatar
Hi Pat
I would start at 2.9:1
To quote from my A-Z of Gearing with F1's article (linked above) - where you go from there depends on:
"- the motor (see table above)
- the track (open with long straight = lower, or short and tight = higher)
- whether you have advanced the end bell motor timing (see below)
- the air temperature (see Motor Temperature below)"
Check out the article for all the info.
Cheers
Old 04-11-2013, 07:01 PM   #1146
SourDieselX's Avatar
one more up for sale
http://www.rctech.net/forum/r-c-item...l#post12036596
---Sponsor: Remote Control Hobbies---
http://www.facebook.com/pages/Remote-Control-Hobbies/156985487744758
Go big or go home!!
SourDieselX is offline   Reply With Quote
Old 04-13-2013, 04:16 PM   #1147
BigRon's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to BigRon
Is there a plastic/carbon version of the rear diffuser available yet?
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 04-14-2013, 10:59 PM   #1148
Default problem
hello I have a problem with my 104 v2. in tight corners at low speed, she moves well, but when the pace quickens, it tends to expand the trajectory curve. any idea what could cause that?
pol59 is offline   Reply With Quote
Old 04-14-2013, 11:39 PM   #1149
edhchoe's Avatar
Trader Rating: 41 (100%+)
It is understeering. There are many things that could cause it.
Try to find a set up in this thread and reset your car.
Tires, camber, front springs, center shock oil weight/spring, side pod springs, and riding height front and rear.
edhchoe is offline   Reply With Quote
Old 04-15-2013, 05:10 AM   #1150
I've been trying to setup my Ver.II with the wide and foam tires setup on an outdoor asphalt track and the car is uncontrollable.
Another guy with also the Ver.II has the same problem.
I've been trying several things but nothing helps to have anough traction on the rear tires.
The car even spins arround on the straight line when i go from half throttle ingreasing to maximum throttle.
I will transform my X1 to a wide setup as all the guys in front of me had a T-Bar F104 model and they were able to control the car.
I guess the Ver.II isn't the best choice for outdoor tracks with foam tires.
addicted2blue is offline   Reply With Quote
Old 04-15-2013, 05:17 AM   #1151
edhchoe, ok, I'll try. I mounted the front spring drives, hard side springs and also as pre-stressed damper tanguage, nothing happens.
addicted2blue, I roll on carpet indoors. I tried foam and rubber tires, the problem is still there.
thank you for responding.
Old 04-15-2013, 09:05 AM   #1152
Csaari77's Avatar
Trader Rating: 34 (100%+)
My setup on our bumpy low-grip asphalt track is getting closer. I still need to be very smooth on the throttle, but it has stopped spinning out when coming out of low speed corners.
What I have found is that the stiffer I make the rear end, the more it is locking it down. When I had it set very soft the car wanted to stay rolled over and not square up after the corner. This lead to the car almost diffing out on the inside tire and just looping around.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 04-15-2013, 09:48 AM   #1153
sorry, I can not understand what you mean, even using translation software online
Old 04-15-2013, 10:06 AM   #1154
On an indoor track i have no problem with rear traction, only when the surface is very cold.
Infact when the grip is ok then it's the best car on the track but outdoors it's a very bad car to drive with foam tires.
Perhaps with another drastic setup change it could work, but so far it doesn't work for me.
Old 04-15-2013, 10:12 AM   #1155
That's what i've been thinking about the setup for the ver.II, the car is to soft in the rear for foam tires on an outdoor track with low traction.
With rubber tires it went rather good, but we are using the tamiya 18T brushless motor and that's a very powerful motor.
To much torque for low grip outdoor tracks, and that in combination with a rear that's to soft makes the car uncontrollable.
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
