Like Tree2Likes
Old 04-04-2013, 05:32 AM   #1126
No I donīt have a F104 V2 but this:
http://www.area52.cc/news/1491-scyth...rsion-kit.html
And I broke one of the FRP links.
Sent message to banzaihobby, the webshop where i bought it nearly 2 years ago. Maybe is time to change to a SP-1?
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 04-04-2013, 05:41 AM   #1127
By now I am using this solution:
Original T-Bar from F104X1:
Uploaded with ImageShack.us
Old 04-05-2013, 12:30 AM   #1128
rbarciko's Avatar
Has anyone tried the new F104 tires from Sweep?
Would be interested in comparing these to Pit Shimizu for traction:
http://www.sweepracingusa.com/110-F1_c_32.html
Sweep Racing’s F1 tires are designed to fit F104 style chassis.
Unlike others, Sweep's F1 tires were designed with both Asphalt and Carpet surfaces in mind!
Tires are the most important item on any race vehicle; without the right tire for the track conditions changing elements on the setup may waste valuable pit time! Start with the right tires, Sweep Tires for your machine!
For carpet racing testing has show the Super Soft rear and medium-hard front to be a good starting point.
For asphalt racing start with following recommendation: Choose the rear compound first (by track temperature rating) then use the front compound to fine tune to your preference. Typically we start with the front tires one or two step harder than the rear.
Hot Weather (Track temp 95F+)
Front: Hard~Medium. Rear: Medium
Warm Weather (Track temp 70F-90F)
Front: Hard. Rear: Soft
Cooler weather (Track temp 50F-70F)
Front: Medium~Hard. Rear: Super Soft~Soft
Cold weather(Track temp below 50F)
Front: Soft~Medium. Rear: Super Soft
Assembly tips:
Peel the paper off the included inserts, stick adhesive side on the wheel (please do not mix front to rear inserts), flip the tires inside out to covered the wheel with rubber tire. be sure to gluing bids sits right on wheel. (please assemble with Sweep Logo placed outside of the wheel)
Place small drops of Sweep CA glue as shown image below, placing the bidding area back on the wheel, place a rubber band over to secure the gluing job and hold tire in place.
Tuning tips:
prepare a run with Sweep X2 compounds on rear of Sweep F1 tires first then start runs compound on front tires too inside half first, increase the amount of compounds until you have just right amount of steering for you.
-== Robert Barcikowski ==-
TFTR TC6 F104v2 RC Parts Search
rbarciko is offline   Reply With Quote
Old 04-05-2013, 06:33 AM   #1129
Trader Rating: 31 (100%+)
There is a forum started here on RCtech for those tires. I saw at one point they were having some manufacturing problems with the inserts not being correct, but it looks like that has been taken care of. Sweep product in general is really good and I imagine their F1 tire will also be.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 04-06-2013, 06:30 AM   #1130
Default problem Ride R1/F104 v2
hello
I tried to mount the sets R1 Ride (26022 and 26023) on my F104 Pro II.
no problem for the rear, but the front wheels can not be mounted.
bearings inside the rim (original Tamiya) seem to be too broad and difficult to enter into the slots wheels Ride. I can set them up, but forcing too. and when I tighten the nuts of the wheels and I'm running them, they rub somewhere to not be able to rotate freely.
I searched, but I did not find any solutions. can you help me?
thank you in advance.
pol59 is offline   Reply With Quote
Old 04-06-2013, 08:00 AM   #1131
pettyeagles's Avatar
Trader Rating: 81 (99%+)
For some reason the Ride wheels have a smaller inside diameter and will rub the kingpins.
A bad day racing beats a good day at work. My RC fleet:
SC5M(x2), B5M, SC10.2, FT SC10, FT TC5, FT TC4, 12R5, AE Rival MT, RC10 Classic, RC10 Worlds, CW Pro Comp Outlaw, F104 pro v2, RJ Speed Legend, Traxxas Slash(x2), 4x4 Slash VXL, Vendetta ST, Axial SCX10, Yeti, Smt10, G-Made/AX10, Tamiya Super Clodbuster
pettyeagles is offline   Reply With Quote
Old 04-06-2013, 02:42 PM   #1132
I had to make the bearings able to fit in a little more depth in their bores. I am disappointed that here has not mounted without rectification.
Old 04-06-2013, 02:58 PM   #1133
wtcc's Avatar
I had the problem too. The bearings fitted but the kingpin rubbed on the wheel. If you put 2.5mm shims under and above the steering hub you will clear the wheel with the kingpin and have 5mm of ride height.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 04-08-2013, 04:29 AM   #1134
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Default Dark Titanium edition
In case you were wondering...
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 04-08-2013, 05:10 AM   #1135
Hi all, I just ordered the dark titanium version of the v2.
I would like to get setup help for med/high grip carpet .
21.5t blinky,shorty lipo, pit 571 and 572 tires.
Next race is on a bit bumpy carpet, one long straight otherwise tight(90-180deg) corners.
I have driven the X1 for about a year now(I have won all the races here with it) and wanted to try something new.
This is my first non t-bar car and need assistance.
-Pate
fastvee is offline   Reply With Quote
Old 04-09-2013, 02:05 AM   #1136
rbarciko's Avatar
you can find setups and videos here for F104 v2:
http://www.rcformula1.com.au/index.p...resource-index
Old 04-09-2013, 02:08 AM   #1137
sosidge's Avatar
TRF101 F1 car coming at Shizuoka according to Tamiyablog.
Old 04-09-2013, 03:24 AM   #1138
tudor_47's Avatar
Looks like teh TRF101 has a new front end...
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 04-09-2013, 03:45 AM   #1139
wtcc's Avatar
Looks like a complete new car
I just hope the new front end is interchangeable.
Old 04-09-2013, 11:29 AM   #1140
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Tamiya F-104 VII
F-104 v2 for sale
Sweet ride, needs a home
Tamiya F-104 vII
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
