Old 03-10-2013, 07:37 PM   #1066
Originally Posted by sobiski racer View Post
I am building a kit and havene no experience, any answers will be appreciated. First i plan on running rubber tyre where should i set the rear axel, i put the 3 adjuster making the car the lowest. Second question is the spur gear, the car comes with a 93 is that what most people run?
The "S3" is stamped 2 which will give you the lowest chasis height. (The S is the parts tree that the 0, 1, and 2 are on).
We race on carpet and there is a wide range of spurs from 72 to 100+.
AreCee is offline   Reply With Quote
Old 03-11-2013, 06:20 AM   #1067
sixace's Avatar
Originally Posted by Jerz616 View Post
Hey Dan, it was in the for sale section
Awesome. Thanks Ryan.
sixace is offline   Reply With Quote
Old 03-11-2013, 01:55 PM   #1068
Trader Rating: 29 (100%+)
I'm looking at getting into F1. How does the F104 X1 compare to the F104 ver 2? Is the X1 still competitive with the Ver 2?
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 03-11-2013, 02:19 PM   #1069
whitrzac's Avatar
Trader Rating: 93 (100%+)
Depends...
From what I've seen the v2 has an advantage on asphalt.
On carpet they are close...
whitrzac is offline   Reply With Quote
Old 03-11-2013, 03:12 PM   #1070
Csaari77's Avatar
Trader Rating: 34 (100%+)
Need a bit of setup help with my V2. I'm running a low grip bumpy asphalt track and I'm basically searching for more rear end stability on power. When I come out of a low speed corner the car is looping the rear end no matter how gentle I am with the throttle. It's almost like the car is getting locked in a turn and just keeps going once the wheels are straight. Yet once I'm out of the corner I can be more aggressive with the throttle and the car will track correctly
My current setup is:
Rear ride height - 5 mm
Pod droop - 3mm
side springs - pink
TC Rear Shock - 25wt. and gold (mini) spring
Rear tires - Tamiya TCS (rebadged Pits)
Diff slips for 1-2ft from stand still
Front ride height - 5.5 mm
Gold springs
2 deg camber
front axels in the offset position
Front tires - Tamiya TCS (rebadged Pits)
Using a Shorty pack
Battery all the way forward, electronics behind battery
Thanks for the help!
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-11-2013, 03:18 PM   #1071
Originally Posted by whitrzac View Post
Depends...
The local track that I would race it on is carpet. So I'm leaning toward a X1 and if I like F1 I can always grab a Ver 2.
Old 03-11-2013, 03:28 PM   #1072
Mechintosh's Avatar
What is the best way to eliminate "Torque Steer" when coming out of a corner? Sometimes the car will steer right sometimes left, never predictable. I have softened the punch of the ESC as much as I can. It sounds and feels like the diff is slipping and then grabbing and jerking the car. Suggestions?
LRP SXXV2 ESC, Revtech 21.5. 4.5mm Ride Height, 1.5 mm droop front and rear.
TRF Shock with 30 weight. Red CRC side springs.
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 03-11-2013, 08:54 PM   #1073
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default PS3 F-1 2012 Champ Invite
Pacific F1 PS3 Championship
We are a bunch of F-1 aficionados, some newcomers some intermediate gamers of Codemasters Formula-1 2012 game (Sony Play Station 3 (PS3).
We like to invite you to join us online in our own Pacific Standard Time (PST) F-1 World Championship, which will take place every Thursday night prior to the F-1 GP racing weekend.
Online via the Formula-1 2012 Codmaster PS3 game platform.
RCTECH Forum: Formula-1 PS3 Online Champioship
The simulation options are as follows:
When and where?
1. Race calendar = every Thursday before the F-1 weekend start / First race March 14, 2013... Etc.
2. Race start: All racers should be logged inn and in their cyber garage at PST 8:00PM we will start at 8:05PM (Lobby is open at 7:45 PST)
3. Race venues = F-1 calendar (first race: Australia... etc)
Simulation:
4. Race length: 25% = 15 Lapps 1 pit stop
5. Damage: realistic
6. Tire ware: realistic
7. Climate: dynamic
8. AI (if needed): amateur
9. Car performance: equal
10. Points scoring: Same as F-1
• I will be keeping scores and posting them either on Codemasters or/and on line forum (TBA)
• Final results screen shots will be kept for each race.
• There may be trough offs but Bernie still thinking about it (TBA)
11. Maximum competitors: 16 per race (register early to secure your spot)
Car set up
12. Gear: manual/suggested
13. ABS : OK
14. Traction control: Medium OK
15. Pit assistance: Off
Extras:
16. We encourage everyone to were head phones so we can communicate during the race.
Official language: English – Driver swearing or using foul language will be black flagged (0 tolerance)
17. Gentleman racing conduct will be observed and enforced in Alonsos own words -You must’a leave the space'a to pass’e-
18. Pre registration are very welcome and will secure you a spot in the PST F1 PS3 2013 Championship
• Email to F1register@WhatBrakes.com:
• Full name,
• PS3 ID
• City/Country
• Team request (if we can provide fix teams maybe will do so)
If we need to cover positions for a race A.I. will be used and their best result scored.
We must not let A.I. win the PST F-1 PS3 Championship!
See you online 7:45 PM PST Thursday March 14, 2013 for the Australia GP
Cordially,
Mr. What-Brakes
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 03-12-2013, 07:18 AM   #1074
2xs
Pod droop - 3mm
side springs - pink
Gold springs
2 deg camber
Using a Shorty pack
How much front droop? Because it sounds like you don't have any weight transfer to the rear.
Also I would move the battery back and moving the RX all the way in front.
2xs is offline   Reply With Quote
Old 03-12-2013, 07:34 AM   #1075
Csaari77's Avatar
1.5mm spacer under the screw in the front.
Old 03-12-2013, 10:47 AM   #1076
Trader Rating: 23 (100%+)
Pod droop - 3mm
side springs - pink
Gold springs
2 deg camber
Using a Shorty pack
There are a few things I can think of that may help.
- Run the steel axle over the carbon
- Run some dampening fluid on the front pins. 60k seems to work well.
- Put the battery in the rear of the car. I know it reduces the weight transfer, but it creates more static weight.
- Run heavier shock fluid in the center. I would go to at least 45 or 50 with a 3 hole 1.2mm piston
Use this to start and see what happens.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 03-12-2013, 10:52 AM   #1077
Trader Rating: 104 (100%+)
Default For Sale: F104x1 carpet car
I will be listing a carpet only used F104x1 for sale shortly. My season is winding down and the car has become only a back up. It won the F1 class at two TCS races last year (Omaha and Winthrop Harbor). PM or email if interested, or just keep an eye out on the "For Sale" forum. I hope to have it prepped for sale by the weekend.
Also, will have a Novak Edge ESC and 17.5 Ballistic motor, both lightly used, for sale as well.
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 03-12-2013, 03:06 PM   #1078
robk's Avatar
Trader Rating: 22 (100%+)
Have you tweaked the car?
Have you made sure the links and "football" pivot have been set correctly? They should allow the pod to easily and smoothly move in all directions. You must remove the motor mount and spring perch cross brace to test this.
Old 03-12-2013, 03:10 PM   #1079
robk's Avatar
Pod droop - 3mm
side springs - pink
Gold springs
2 deg camber
Using a Shorty pack
As it was mentioned battery back....
Preload the springs a turn to start, more preload will stabilize the car
Lower the rear ride height as much as you can, understanding it's a bumpy track
raise the pod side of the shock, a least 1mm, and don't be afraid to add more
what are you using in the side damper?
Old 03-12-2013, 03:30 PM   #1080
Do you have any preload on the side springs? Easy to overlook, I had similar problems with my CRC 1/12th and thought I had a problem with my servo. Changed it for a new one and the same. Discovered that when dialling out tweak I had compressed both springs slightly so when the chassis centred out of a corner the springs worked against each other to upset the chassis.
Adjust the springs so they are only just touching the rear plate and when you adjust for tweak you wind one out when you wind the other in to make sure you don't put any spring pressure on the plate when centred.
terry.sc is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
SEO by vBSEO 3.5.0
