Old 02-26-2013, 02:47 PM   #1021
edhchoe's Avatar
Trader Rating: 41 (100%+)
Pillow ball joint and side links. They are in one bag. One bag includes two sets.
edhchoe is offline   Reply With Quote
Old 02-26-2013, 02:56 PM   #1022
Originally Posted by 1950detroit View Post
I just purchased a F104 pro to race in our local club (rubber tires, 21.5 blinky) I need to know what parts I should have on hand for spares. I am sure its been discussed a 1000 times. Can someone post a link to the thread that this has been covered on?
Thanks in advance
For as long as i'm driving my F104 i have never had any spare parts used except for the rear spoiler, due to impacts from behind it intends to brake much quicker then you will be needing some other spare parts.
If i would think of what kind of spares you could use then i should mention those front springs and a spare rear axle.
Incase you would be using a carbon rear axle it's better to have one in spare cause they can brake by having a heavy impact.
I've seen only one big crash from a friend and his car needed a new gear case (lower part that has the diffusor in it) but other then that i've never seen heavy impacts that a F104 couldn't handle.
Hope this helps you.
addicted2blue is offline   Reply With Quote
Old 02-26-2013, 02:58 PM   #1023
Thanks in advance
I've been racing mine pretty regular since November and have only destroyed my CF rear axle and diff joint when the brace screw from the alloy motor mount backed out and rubbed on the diff causing enough friction to actually fuse the axle into the joint.
I keep a spare set of front arms, steering knuckles, side links and screws.
AreCee is offline   Reply With Quote
Old 02-27-2013, 08:34 AM   #1024
idbdoug's Avatar
Trader Rating: 33 (100%+)
Will my body off an older F104X1 Pro fit onto F104 ver 2 without having to make new holes in the body???? I.E. are body posts in same relative position without having to cut up/drill holes in older mounted body
thanks
idbdoug
idbdoug is offline   Reply With Quote
Old 02-27-2013, 09:51 AM   #1025
thanks
idbdoug
I've fitted my old F104PRO body on the F104Ver.II, the only thing i had to do is make the rear body holes a little bit bigger and that's it.
Bodyposts from a ver.II are bigger in diameter, that's the only difference.
Hope this helps.
Old 02-27-2013, 10:40 AM   #1026
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Hope this helps.
+1
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 02-27-2013, 07:05 PM   #1027
idbdoug's Avatar
Thanks for info
idbdoug
Old 03-01-2013, 11:27 AM   #1028
Got really nice modification for ma ver 2 :-)
52mm wide corally tires :-) can't wait for testing!
SquirrelCZE is offline   Reply With Quote
Old 03-01-2013, 11:49 AM   #1029
SquirrelCZE,
what are the front tires you are using ?
Ralf is offline   Reply With Quote
Old 03-01-2013, 12:10 PM   #1030
Originally Posted by Ralf View Post
SquirrelCZE,
Xceed F1-F103 type tires :-) usually stick with hard ones
Old 03-01-2013, 12:17 PM   #1031
OK,
I thought Xceed tires do not adapt on F104 front end.
thanks
Old 03-01-2013, 12:26 PM   #1032
OK,
thanks
they do not
there some modifications on my car... (the upper car is my F104GT 235mm wide... so I like to make modifications :-) ):
- I use TRG Front Uprights
- I poped out some spacers of the TRG uprights kit, so it's lower than the original ones
- I use shorter king pins...
so I can put xceed F103 tires there... O:-)
Old 03-01-2013, 12:31 PM   #1033
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Los Angeles Sunday's winter track test:
1. If you have not PM me your name/transporter number please email it ASAP to marcos@WhatBrakes.com
Its the only thing you need to do for per-registration.
2. Bring water, food and suntan lotion (if you need to bring some grid girls that's OK too )
3. Bring your easy up (optional) and power supply
See you Sunday!
File Type: pdf Winter outdoor F1 test at Marvins flyer.pdf (279.8 KB, 58 views)
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 03-02-2013, 07:18 AM   #1034
Taffyjnr5's Avatar
Trader Rating: 30 (100%+)
Hi,
I have just started racing this chassis on asphalt with rubber tyres and im chasing a little bit more steering any ideas?
Serpent ERYX 4.0
Sworkz EVO LE/OS Speed
Sworkz EVO 2/Hobbywing
Taffyjnr5 is offline   Reply With Quote
Old 03-02-2013, 07:44 AM   #1035
Originally Posted by Taffyjnr5 View Post
Hi,
What are you using for springs, ride hight?
Huskerfan1212 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
