Like Tree1Likes
Old 02-22-2013, 03:39 PM   #991
B00t13g's Avatar
For anyone running the trf shock, what are you using for limiters, or how are you shortening droop?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-22-2013, 03:42 PM   #992
I'm using those black O-rings or alu spacers for the desired droop.
addicted2blue is offline   Reply With Quote
Old 02-22-2013, 04:52 PM   #993
B00t13g's Avatar
If anyone has mounted an orion r10 pro in the f104 can you post a picture?
Mackenzie Meyercord
Old 02-22-2013, 04:58 PM   #994
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by AreCee View Post
I normally would agree with you but I had some minor delamination at the rear pivot area right at the countersunk screw holes. I had to use CA to seal the area.
A friend of mine had that happen also
I'm just not sure a tiny film of ca on the edge would have prevented it ?
I guess it can't hurt anything though
And if done right, a glassy glued edge does look tight
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-22-2013, 08:22 PM   #995
Jerz616's Avatar
Trader Rating: 49 (100%+)
Take a look at mine tomorrow. Thats what I am using.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-22-2013, 08:39 PM   #996
B00t13g's Avatar
Perfect! Thanks Ryan!
Mackenzie Meyercord
Old 02-23-2013, 07:50 PM   #997
can anybody give some tips on how to lighten my car up??was thinkin along lines of plastic mount non motor side,carbon axle,no counter weight any ideas???i am on rubber tyres by the way
tamiya-2012nz is offline   Reply With Quote
Old 02-23-2013, 07:54 PM   #998
B00t13g's Avatar
Evidently I'm not capable of figuring out how to get my trf damper mounted properly. My issue is I have the droop set where I would like it, but there's too much tension on the spring and I end up with a 5mm ride height where as the rear pod is at 4 and the front is at 4. I was using the long ball end with around 4mm of limiting mounted on the far holes of the middle shock mount. What am I doing wrong?
Mackenzie Meyercord
Old 02-23-2013, 08:06 PM   #999
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default Los Angeles/SFV F-1 Test & Race Day
Winter Outdoor F-1 Track Test & Race
March 3, 2013
Classes: UF1 and Le Mans
We are all invited to test and race at Marvin's URC V Raceway (in the SFV!)
Great opportunity to start testing set-ups in a low grip, long - fast layout track
This first race is for Free!
For all of us so we get to know the venue.
Formula 1 and Le Mans
Sunday March 3
URC V Raceway
Metro Link Parking Lot
8775 Wilbur Ave. SF Valley CA 91324
Track set up 9:00 11:00
Practice 11:00
Racing 12:00 5:00 or Sunset
You will need your own power supply
To register please send me a PM with your name and transponder numbers.
So they can be race ready and not spend time loading our data on race day.
Cordially,
Marcos Wanless
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 02-23-2013, 08:25 PM   #1000
B00t13g's Avatar
That is how it is currently setup. Obviously the wiring isn't done.
Mackenzie Meyercord
Old 02-23-2013, 09:00 PM   #1001
Jerz616's Avatar
Your making me jealous Mackie. All these pics of your new car with the TRF shock, and I cant find one.
Ryan Gracey
XRAY XB8'14
Old 02-23-2013, 10:26 PM   #1002
B00t13g's Avatar
At least yours is running and driving and I'm sitting at home thinking about how to make a shock work. Lol
Mackenzie Meyercord
Old 02-24-2013, 05:39 AM   #1003
I'm not sure what you mean about droop and ride height. You adjust the ride height with the spacers and bearing holders in the rear.
You adjust the droop by moving the shock to achieve the droop you desire in the rear. From your picture it looks like you have the shock mounted in the stock position and not in the rearward position shown in the manual (page 13), this can account for your droop problem. Measure the stock shock and the TRF and if the TRF is shorter then use the manual's alternate position.
AreCee is offline   Reply With Quote
Old 02-24-2013, 05:53 AM   #1004
Jerz616's Avatar
Looks like you need a shorter ball cup to let the spring retainer come down just about 1mmor more to give you some adjustability.
Ryan Gracey
XRAY XB8'14
Old 02-24-2013, 06:19 AM   #1005
golgi's Avatar
Trader Rating: 14 (100%+)
I'm still fairly new to this car and using the stock oil dampeners. What is the benefit of upgrading to the TRF ones?
golgi is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
