Like Tree1Likes
Old 02-08-2013, 08:49 AM   #931
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by scr8pn4205 View Post
thanks for the help. Ran car again last night. Absolute blast to drive. got the steering alot better now just need to learn not to blister tires coming out of turns. Always use to foam tire 1/12 and touring car so this is my first crack at rubber tire. My question is when saucing the tire how long do you let it set on there and then how long do you let it air dry after you wipe them down to run.
With the VII
We have found, on high grip carpet
Black or Gold Tamiya springs are best
No side spring pre-load is best
Pre-load causes diffing on accel out of corners, this will make the rear feel loose
A proper VII carpet setup, on the right tires, will never be loose, and will not chatter
Heavier side damping will have a stabilizing effect, and additional steering response, however, if too heavy, can cause traction roll
On lower grip out-door tracks, softer springs, pre-loaded helps with stability
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-08-2013, 09:00 AM   #932
scr8pn4205's Avatar
alright, when setting side spring tension. Do you do it with the chassis and rear pod level or when the car is at ride height? I switched to asc side spring and center spring. Between a blue and gold center and using 3.75lb side spring. 60k on damper tube.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 02-08-2013, 09:02 AM   #933
edhchoe's Avatar
Trader Rating: 41 (100%+)
I clean the tires with the sauce after the race+corner marshaling. And I put sauce on when the race before mine starts.
edhchoe is offline   Reply With Quote
Old 02-08-2013, 01:53 PM   #934
AE side springs are too soft for the VII on carpet, imo
AE Gold (Heaviest of AE springs) is similar to Tamiya Silver (Soft)
Set springs to just barely touching, with car placed on tires, ready to run
Lift front wheels, alternating sides to see, and adjust side spring setting
If diffing still occurs, back off more on the side springs, as much as necessary
60k side damper is on the heavy side, but if it's not traction rolling with that, then it's not a problem
We are using Tamiya TC center shock with AE TC springs
Old 02-08-2013, 03:56 PM   #935
How about on lower traction carpet. Side springs and fluids?
Huskerfan1212 is offline   Reply With Quote
Old 02-10-2013, 08:27 PM   #936
edhchoe's Avatar
Has anyone done what I have done? The droop setting post shaved right off in a crash.
Old 02-10-2013, 08:52 PM   #937
Jerz616's Avatar
Trader Rating: 49 (100%+)
Our track in dallas is considered low to med grip. I am running 30wt for pitch, and I think 50 for roll and I am using black AE side springs. My car had tons of grip on saturday and was at one point an the verge of traction rolling. I am running
1* camber
4.5mm ride height front to rear with 1.5mm droop
Pit 574 front 572 rear.
I had plenty of turning and more then enough rear traction. I couldn't get my car spinout if I tried. That is until I broke a side link and had rear wheel steering.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-11-2013, 04:21 AM   #938
celt's Avatar
Yup...two weeks ago, same side to.
Happened once and not since. Pretty violent crash though. Tangled wheels down the straight and got punted off the track.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 02-11-2013, 08:40 AM   #939
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
Is this the right spot to be for the Tamiya F104w GP? Just picked one up this weekend and Love it. Even though I didn't finish first I was turning some really good times.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 02-11-2013, 09:03 AM   #940
Ed:
The same thing happened to my car and I have been running it without droop posts for over two months with minimal ill effects.
Bill
Bill Jeric is offline   Reply With Quote
Old 02-11-2013, 09:49 AM   #941
JayL's Avatar
I had it happen, droop post, when I don't run a big washer on the post. When I run a big washer, like stock, have never had it happen.
Sometimes with small or no washer the top arm gets stuck on the bottom arm in a crash as well, seen that many many times. The top arm slides behind the droop post and gets stuck
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 02-11-2013, 11:50 AM   #942
edhchoe's Avatar
I see. It is not as unusual as I thought.
Old 02-11-2013, 12:03 PM   #943
Trader Rating: 18 (100%+)
Best place to pick up an F104 Pro v2 nowadays??
viet is offline   Reply With Quote
Old 02-11-2013, 01:26 PM   #944
edhchoe's Avatar
Did you check TQ RC racing? Order the tires and body at the same time. They have most items in stock.
Old 02-11-2013, 03:00 PM   #945
I did. I don't think they have the Pro kit in stock.
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
