Like Tree2Likes
Old 02-06-2013, 02:26 PM   #916
scr8pn4205's Avatar
Yes i sauced the tires. I changed to asc gold center spring and it seemed better. I cant get the front to bite at end of straight. I am thinkin u must run drag brake on this car. Seem to have to jab brake to set front end. Also whats best way to clean the rubber build up on rubber tires
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 02-06-2013, 04:51 PM   #917
edhchoe's Avatar
Trader Rating: 41 (100%+)
Have you tried more camber? And sauce wider on front.
Do you have plenty of droop on the center damper? It helps with weight transfer.
edhchoe is offline   Reply With Quote
Old 02-06-2013, 05:31 PM   #918
Most racers I know use brake cleaner to wash the tyres before using additive. Not a fan of putting brake cleaner all over my hands so I use baby wipes.
terry.sc is offline   Reply With Quote
Old 02-06-2013, 06:29 PM   #919
There are a number of things that work; Lighter fluid, Mineral spirits, Naptha, Denatured alcohol, etc.
AreCee is offline   Reply With Quote
Old 02-06-2013, 06:36 PM   #920
The Captain's Avatar
Nitro cleaner is what I use.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 02-06-2013, 07:14 PM   #921
xevias's Avatar
WD40. It doesn't dry the tires out like some of the above chemicals.
xevias is offline   Reply With Quote
Old 02-06-2013, 11:33 PM   #922
Dasmopar's Avatar
Send a message via AIM to Dasmopar
+1
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 02-07-2013, 03:14 AM   #923
scr8pn4205's Avatar
thanks for the replies. im at 2 on camber, a.5 toe out in front and have 2.5mm droop in the rear. I preloaded the side springs by a turn and it seemed to make the car much easier to drive aggressive but still have to use more brake than im use to at end of straight or 180 hairpins.
Airtronics M12
TSR power
Old 02-07-2013, 03:19 AM   #924
scr8pn4205's Avatar
another question is whats the most common electronic setup in the car. I have servo,tponder,receiver,battery and then esc going from front to back. I have seen a lot of pics where it goes servo,tponder,receiver,esc and then battery all the way to the back. Just looking for input to what the car might like better on carpet. thanks
Airtronics M12
TSR power
Old 02-07-2013, 11:39 AM   #925
edhchoe's Avatar
What tires are you using?
Old 02-07-2013, 11:40 AM   #926
scr8pn4205's Avatar
Pit 0571 front 0572 rear
Airtronics M12
TSR power
Old 02-07-2013, 12:03 PM   #927
shimizu 571,575,571,573,577,572 all work in new zealand
tamiya-2012nz is offline   Reply With Quote
Old 02-07-2013, 05:43 PM   #928
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
I ran my car at IIC in vegas with the rx, battery, esc --- for Snowbirds changed it to rx, esc, battery. It made my car more stable and easier to drive.
Also, I have found that I have to scrub in the fronts much, much more than the rears to get them to bite, so maybe dremel or sandpaper them down a little more to get bite.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 02-08-2013, 08:01 AM   #929
scr8pn4205's Avatar
thanks for the help. Ran car again last night. Absolute blast to drive. got the steering alot better now just need to learn not to blister tires coming out of turns. Always use to foam tire 1/12 and touring car so this is my first crack at rubber tire. My question is when saucing the tire how long do you let it set on there and then how long do you let it air dry after you wipe them down to run.
Airtronics M12
TSR power
Old 02-08-2013, 08:17 AM   #930
nikos2002's Avatar
I was saucing 10 minutes before run, wiping off fronts about 5 minutes before. Letting rears go until run, wipe off what ever left really well before run.
Nick Malato
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
