Tamiya F104 Version 2
#886
Thanks for that Roy. Will have to rebuild the diff tonite.
#888
Thanks roy.
Finally raced the f1 with other 3-4 pans cars. What a blast it was to drive and what a difference paragon fx2 makes. Went from babying it to half throttle in turns and full at exit...cant wait for more driving
This was with the very same hard pits tires that im having issues at another track
#889
Thanks roy.
And is it the basic and then use another tire additive on top of it or is this the only tire additive you need?
#890
2nd heat comes up without paying attention so I had only put the paragon fx2 for maybe 3-4 minutes on all 4 tires before I had to wipe it off and rush to track. Then I was oversteering and had tons more grip.
3rd I added paragon and put tire warmers, I traction rolled 2 times on outdoor asphalt.this is by far the best traction ive had until my lipo dumped because I forgot to charge it after the first 2 heats
#891
Here is a picture of the new F104 Ver.II PRO titanium version
#892
#894
The body is included and it's a lightweight version.
#895
Hey is the trf bigger shock or same specs? Do all the springs fit it or I need specific ones?
