Tamiya F104 Version 2
#826
Is there a chart that shows all the tamiya sponge foam tire part numbers and compund differences. I am wondering what a good starting point is for the foams for the f104 for carpet racing. thanks all
#830
It makes the wiring terrible the further forward you place the esc
#831
I am not really worried about wiring or weight I was more concerned with the balance. I ran at IIC and was taking steering away the whole the time, but I also new the car was a bit out of balance because I had a full pack in the car and the electronics on the "side wings". Now I have a shorty pack, an looking for better balance when I get to run the car again. Thanks for the input.
#837
The same thing happened to me last year.
I do recommend upgrading the Pitch damper on the F104v2 to the Tamiya RC TRF special damper, as on an outdoor track, the stock pitch damper has popped open after a few incidents - http://www.tamiyausa.com/product/ite...oduct-id=53901
#840
The problem is the m2x5mm cap screws for the links. 5mm is too short causes the links to break at the ball ends. I've replaced mine with m2x8mm screws and haven't had an issue since.
