Like Tree2Likes
Old 12-15-2012, 05:45 PM   #691
Originally Posted by Professor View Post
hi redbull
i notice in your post above (the one with the photo of the 104)the angle of the steering rods with the servo layed down on its back,with fitting the servo this way & being able to adjust it back & forth (before final mounting position) you can change the angle of the steering rods,is there any advantages to having them angled like yours as opposed to having them straight (which means the servo sits back a little further than yours) just curious as i have just purchaced a new 104 v2,as this is my first foray into f1 i have limited knowedge of them so i may be asking a few questions
thanks prof
The further forward the links are mounted in the centre the less ackermann you will have.
The vertical servo, so the servo horn is in front, keeps the links as forward as possible at all times, so you get less ackermann angle and the outer wheel turns more when the steering is on full lock. The smaller difference in angle between the two wheels gives you a more aggressive turn in to the corner and more steering at high speed, but will reduce steering exiting corners.
A low profile servo mounted horizontally so the servo output is on top will give you a greater ackermann angle when cornering. This will give smoother and more consistent steering. Moving the servo far back will give a huge ackermann angle, which will give you less steering
BTW Moving the servo forwards and backwards will make no difference at all to the bump steer, that's only affected by the link mounting height. The standard vertical servo position will give you a small amount of bump steering, but only in a straight line. When cornering the links are raised up just as high as using a low profile servo so you have no bump steer problems when cornering.
Personally I race on a tight carpet track so use the standard vertical servo to give me lots of steering in the tight hairpins and can carry a lot of speed through the sweepers. Running on lower grip surfaces or a more open track a horizontal servo should be easier to drive.
terry.sc is offline   Reply With Quote
Old 12-16-2012, 11:02 AM   #692
Today i had a great race with the V2, the car was great and handled awesome.
I TQ'd and won the race, i have converted the V2 to a wide version and it really is a great car to drive.
addicted2blue is offline   Reply With Quote
Old 12-16-2012, 02:36 PM   #693
Kappe's Avatar
Default Roll spring set and Pitch spring set
Hi, Who can tell me the correct hardness for color about roll and pitch damper spring set?
Kappe is offline   Reply With Quote
Old 12-16-2012, 05:34 PM   #694
Autocratic's Avatar
Trader Rating: 26 (100%+)
Is there any to make this car 200mm with the kit wheels?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-16-2012, 09:55 PM   #695
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Black-Hard
Gold-Med
Silver-Soft
Pink-Extra Soft
Same combination as front springs, but with an extra soft spring
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-17-2012, 10:01 AM   #696
JayL's Avatar
Originally Posted by celt View Post
I read somewhere on the "interweb" that there was a trick or fix to minimize the front spring compressing in the lower ball and sticking there.
Chassis doesn't do well when that happens.
Anyone experience this, or know what I mean?
Yes, had it happen.
I changed from the stock e-clip holding the spring on the bottom
to the original F104 c-ring #84171, works a charm!
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-17-2012, 02:24 PM   #697
celt's Avatar
Originally Posted by JayL View Post
Yes, had it happen.
Awesome, thanks...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 12-18-2012, 06:05 PM   #698
hi i have a problem with my v2 and when you slowly put power on it wants to spin out diff is set just tight enough to not slip any ideas guys im really stuck on this
tamiya-2012nz is offline   Reply With Quote
Old 12-18-2012, 06:42 PM   #699
Sounds like tires...what is your setup, what tires, and what conditions are you driving on?
Old 12-18-2012, 07:30 PM   #700
pit shimizu 575 rears and tamiya hard fronts we were trying to get the front to grip less in the heat we are having at the moment 45+ degrees on track and low traction dusty
Old 12-18-2012, 07:55 PM   #701
I'm pretty sure this is inaccurate, both pivot balls (Associated and Tamiya) are 5mm.
Certainly might make you feel better to replace the pivot balls, but I believe them to functionally identical.
hi guys...where can i get the ae pivot ball as well as the link...or do you guys have the item number for them..
Also, do you guys happen to have good setup for titc 2013?
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 12-18-2012, 07:57 PM   #702
You're from Invercargill, NZ, Cool !
Famous place
That is an odd tire combo
Have you tried 577Fr, with 575Rr, or 572Rr ?
Old 12-18-2012, 08:24 PM   #703
invercargill famous due to worlds fastest indian right???want some pics of the bike ?
Old 12-18-2012, 09:00 PM   #704
Heck yea !
Old 12-19-2012, 01:36 AM   #705
will sort out pics of the indian bike for you redbull,is it better to run rubbers or foams in low traction conditions and run it narrow(180mm) medium(190mm)wide)200mm) in low grip asphalt racing??
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
