Like Tree2Likes
Old 12-08-2012, 02:26 PM   #676
Trader Rating: 114 (100%+)
Originally Posted by Professor View Post
hi redbull
i notice in your post above (the one with the photo of the 104)the angle of the steering rods with the servo layed down on its back,with fitting the servo this way & being able to adjust it back & forth (before final mounting position) you can change the angle of the steering rods,is there any advantages to having them angled like yours as opposed to having them straight (which means the servo sits back a little further than yours) just curious as i have just purchaced a new 104 v2,as this is my first foray into f1 i have limited knowedge of them so i may be asking a few questions
thanks prof
Changing the Ackerman position will adjust how much bumpsteer you may get under load. If the angle is great, usually gives you positive bumpsteer making the car easier to drive. Straight setup is more aggressive and harder to drive.
If this is your 1st F1... Go with the manual kit setup. Can't go wrong with that.
Chris Furman is offline   Reply With Quote
Old 12-08-2012, 08:59 PM   #677
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
hi redbull
thanks prof
Here is an article written for the VII by Tamiya
There is a video follow-up coming soon as well
http://www.tamiyausa.com/articles/fe...article-id=613
This is the same link as in my sig, F-104VII Info
Having the steering rods angled like that is all about ackerman, tire slip angles, and stuff
Hard to science out exactly how it all works for each track, tire, driver etc
For myself, and most who run Tamiya F1 cars, this setup is a very good all around ackerman setting
The kit setup with standard servo position has a lot of bump steer, my car does not have any noticeable bump steer, and I like it this way much better
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-09-2012, 12:47 AM   #678
Professor's Avatar
thanks for the reply's & info chris & redbull
ihave looked at the link in your sig briefly but now i will go back & look at it again to gain more from it
prof
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 12-09-2012, 03:17 PM   #679
Send a message via ICQ to JiuHaWong
Does anyone run a Speed Passion Reventon Pro in their v2? If so, what motor are you running with it? Any feedback appreciated!
JiuHaWong is offline   Reply With Quote
Old 12-09-2012, 05:32 PM   #680
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
I ran the Viper VST 21.5 at IIC -- but I do run the VST motors in everything
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 12-13-2012, 11:00 AM   #681
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Is it absolutely necessary to drill out the shock cap when using the kit damper? And if so, what size bit?
RCBuddha is offline   Reply With Quote
Old 12-13-2012, 11:05 AM   #682
It is to let the air escape allowing the shock shaft to move freely. I used a .8mm bit.
AreCee is offline   Reply With Quote
Old 12-13-2012, 01:19 PM   #683
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Hi,
This is my final purchase list for Christmas. Please let me know if I forgot something.
F104 Rear R1-Hard (1 pair) with inserts
Savox SC-1251MG Low Profile Digital High Speed Metal Gear Servo .09/125.0 SAVSC1251MG
Lotus Renault E20 Decal Sheet
F104 Front F3-Medium (1 pair) with inserts
Rigid Rear System RRS for F104V2/RM-01
Adjustable Metal Upright - F103 F104 RM01
Aluminum Servo Mount Set (2 pcs) (BK) for Tamiya F104 Pro / F104 V2
Roll Spring Set - RM01
Body Set Vodafone McLaren - Mercedes MP4-24
1/10 F104 Version II Chassis Kit
Actually I've ESC/Motor combo and need to know the proper battery (fitting, weight and capacity)
MiTaller-RC is offline   Reply With Quote
Old 12-13-2012, 05:20 PM   #684
RCBuddha's Avatar
Ok, thanks. You'll forgive me for asking, but do you drill all the way through? The instructions are not too clear as whether you do or not.
Old 12-13-2012, 07:29 PM   #685
golgi's Avatar
Trader Rating: 14 (100%+)
I've got a low profile digital metal gear servo .11 / 80oz at 6v. Will that be a decent one to start with or should I be looking at a different servo with more torque?
I'm going to be picking up the f104 v2 kit tomorrow and just starting to look at the various components to complete it.
golgi is offline   Reply With Quote
Old 12-13-2012, 08:03 PM   #686
That is plenty for a F1
Old 12-13-2012, 09:38 PM   #687
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
What is a good diameter for foam tires, front and rear
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-13-2012, 11:49 PM   #688
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
You just drill half way thru. You will reach a hollow spot where the shock shaft travels.
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 12-14-2012, 06:20 AM   #689
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by MiTaller-RC View Post
Hi,
Get shorty lipo and maybe F3-soft fronts
idbdoug
idbdoug is offline   Reply With Quote
Old 12-15-2012, 04:52 PM   #690
celt's Avatar
Default front spring compresses then sticks...
I read somewhere on the "interweb" that there was a trick or fix to minimize the front spring compressing in the lower ball and sticking there.
Chassis doesn't do well when that happens.
Anyone experience this, or know what I mean?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
