Like Tree2Likes
Old 12-03-2012, 02:51 AM   #646
dfx
dfx's Avatar
Originally Posted by Mr.juarez View Post
Would it be a nice idea to put 2 solid links on the side instead of the plastics or are they supposed to flex? I have 2 small camber links that are aluminum and can mount them, just not sure if they are supposed to have give or not.
No need to flex but I'm affraid that alu links will bend easy...
Originally Posted by InspGadgt View Post
When you put the left side hub on put a piece of paper between the bearing and the spacer then tighten the hub. You want a very slight amount of play to make sure you don't bind the bearings.
Good point, I do the same...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 12-03-2012, 09:21 AM   #647
Send a message via MSN to jontang001
Originally Posted by RedBullFiXX View Post
Unfortunately, that is a tire issue, not a setup issue
Same experience with most who have run with that tire
Thanks for the answer!
Can you suggestion tire combination for outdoor racing? I tried 571/572 but not very satisfy for me when turn into the corner...still push.
Thanks for your help again!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 12-03-2012, 09:25 AM   #648
Trader Rating: 114 (100%+)
Awesome paint! Love it!
Nice!!!
Cant wait to run my too.
Hey dan quick q. Would it be a nice idea to put 2 solid links on the side instead of the plastics or are they supposed to flex? I have 2 small camber links that are aluminum and can mount them, just not sure if they are supposed to have give or not.
Chris Furman is offline   Reply With Quote
Old 12-03-2012, 10:02 AM   #649
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Could you post a photo of your car, with complete setup, motor, battery, etc ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-05-2012, 06:35 AM   #650
First run, car pushed like a truck on high bite carpet. Made some changes, maybe better next weekend. Links are definitely the weak spot on this car. Have some Associated links on the way.
Old 12-05-2012, 07:21 AM   #651
What is your setup/tires ?
Old 12-05-2012, 07:50 AM   #652
Pardus rubber tires from F1 Paintlab. High bite carpet... Rears are grippy, fronts are still kind of slick.
Changed from front gold to silver spring.
Lowered front ride height.
Now increased rear droop for more weight transfer to front.
Decreased front droop to keep front wheels on ground during acceleration
Changed roll springs.. From gold to black
Changed main spring from gold to black.
Car ride height is now level front to rear.
Hopefully these changes will help with the turn in-corner push.
Old 12-05-2012, 08:45 AM   #653
Pardus rubbet tires from F1 Paintlab. High bite carpet... Rears are grippy, fronts are still kind of slick.
looks like the right direction
Old 12-05-2012, 10:09 AM   #654
robk's Avatar
Trader Rating: 22 (100%+)
Battery all the way back, 3mm rear droop
Old 12-05-2012, 12:03 PM   #655
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Chris. We used those tires at IIC this year and the fronts didn't come in until they were well scuffed. I was actually taking a dremal to them to scuff them in. Once I did that they were much more consistent.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 12-05-2012, 12:17 PM   #656
I only have 4 heats on them.. I may sand them down a little then and see if that helps too.
Thanks.
Chris
Old 12-05-2012, 02:28 PM   #657
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Thanks.
Chris
My set up to try this weekend is really close to your new set up. You coming our this weekend to race ?
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 12-05-2012, 05:58 PM   #658
Not sure yet... Will know closer to weekend.
Old 12-05-2012, 06:59 PM   #659
WongTamiya's Avatar
Originally Posted by WongTamiya View Post
I'm running the F104 v2 at the Tamiya Track, in Aliso Viejo. Whenever I get on the throttle, it pulls to the left for no apparent reason. It's not because I'm pulling the trigger too quickly, because I have driven it before without this problem when I'm getting on the throttle much quicker. Do you think this is a setup issue? I seem to suddenly have gotten this problem when transitioning from asphalt to carpet and then back to asphalt. Do you think this could be a setup issue? I had just replaced the links with associated ones
Whoops sorry I only replaced the links. Not the balls. Is it required to put in the associated balls? I do have them.
Julian Wong
Why so serious?
WongTamiya is offline   Reply With Quote
Old 12-06-2012, 04:25 AM   #660
dfx
dfx's Avatar
First run, car pushed like a truck on high bite carpet...
Sorry for my bad english but what do guys mean when You say that car pushed? Some kind of understeer or ...?
...I only replaced the links. Not the balls. Is it required to put in the associated balls?...
Yes, Asso do have a slightly different size. You have better use Asso balls with Asso links.
Tamiya TRF 416 WE
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
