Like Tree1Likes
Old 11-20-2012, 07:55 AM   #601
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
finally broke down for the savox low profile servo and im having a hard tine fitting it. It almost seems as if the holes that were drilled in the chassis for the front legs of the servo arm are too far in? The screws to bolt the servo arms go in at an angle instead straight up.
Also what spur in 48 or 64 pitch are you guys running with the stock diff ball or some different? I put the stock 93t spur that came with it and a 38 64 pitch pinion and they seem to mesh fine? That put me at 2.4fdr is this right or wrong?
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-20-2012, 08:24 AM   #602
nrtv20's Avatar
There are (2) different sets of servo mounts, a narrow for mini servos and a wide for standard size servos. I learned the hard way and ground down the narrow's haha!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-20-2012, 08:43 AM   #603
Mr.juarez's Avatar
I looked at the ones i pulled off and they are the same shit. They fit fine in the back but the front ones dont. Im going to go pick up a mini servo today and see
Whats your take on the spur?
Old 11-20-2012, 09:30 AM   #604
celt's Avatar
Default Tamiya spur adapter
It is my understanding that the spur gear adapter replaces the use of the bearing in the diff assembly?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 11-20-2012, 10:02 AM   #605
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
With a Futaba lo-pro servo
It fit's ok, but only with thin servo tape
At most of the tracks in the UF1 series we gear 93x31-35
That's with 21.5 Blinky
3mm Ceramic diff balls are the only thing I add to the stock diff assy
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-20-2012, 10:05 AM   #606
The servo is held in place by 2 plates on the sides that you servo tape the servo to. There shouldn't be anything that bolts to the servo ears.
Old 11-20-2012, 10:07 AM   #607
The servo plates bolt to the chassis, if the servo is too wide, the screws in the plate won't go in straight
So yes, you need to grind off any servo tabs
Old 11-20-2012, 10:09 AM   #608
nrtv20's Avatar
Do you like running without the damper? I would assume that helps rear traction?
Old 11-20-2012, 10:10 AM   #609
I borrowed the damper to run on my V2
Never raced the car without a damper
Old 11-20-2012, 10:24 AM   #610
Mr.juarez's Avatar
Correct the current hitec servo i cut off the ears off, this savox is a bit narrow and it wont fit that's without even the tape. This time im using the servo facing up instead of facing forwad like the manual calls.
Old 11-20-2012, 12:52 PM   #611
If the Savox is too narrow that is an easy fix. My Spektrum servo was a bit narrow as well so I just glued on a couple strips of Lexan with Shoe Goo to make the servo wider. I then glued the servo in on my F1R with Shoe Goo as well. The trick is to use something to make the servo wider then use servo tape or Shoe Goo to hold it in place.
Old 11-20-2012, 01:03 PM   #612
dfx
dfx's Avatar
...if the servo is too wide, the screws in the plate won't go in straight...
...this savox is a bit narrow and it wont fit that's without even the tape...
Exotek servo holder is a bit wider than the stock one, if it helps. It is possible to fit the low-profile Futaba with thicker servo tape...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 11-20-2012, 01:12 PM   #613
Bishy's Avatar
I bolted a Savox 1250mg servo in my 104V2 horizontally using the optional skinny mount in the parts bag, didn't even have to cut the ears off and it fits snug using only one layer of the kit servo tape.
"I'd rather a bottle in front of me than a Frontal Lobotomy"
TeamC TM2V2, TM4, T8EV3, T8V3, TC10, AE B44.1, B4.1WC
www.teamcracing.net
Bishy is offline   Reply With Quote
Old 11-20-2012, 08:17 PM   #614
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
What side springs do you guys who run carpet like to use. I think I ran a different set every run at IIC (Tamiya and AE), and never did find a pair I liked. To be honest I was breaking the cardinal rule and making 2-3 changes each time so I was probably shooting myself in the foot.
Thanks for any input.
Hobby Authority Distributions Marketing Director
** www.hobbyauthority-dist.com / www.maclan-racing.com ***
Sponsored By: Maclan Racing, XRay/RC America, J Concepts, Xpert R/C, G Force USA, X Factory, Boom Graphics, Hobby Authority
nikos2002 is offline   Reply With Quote
Old 11-21-2012, 07:09 AM   #615
robk's Avatar
Trader Rating: 22 (100%+)
I have been trying all the springs and for most carpet tracks I would say start with Tamiya gold.
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
