Like Tree2Likes
Old 11-14-2012, 05:55 AM   #586
nrtv20's Avatar
Originally Posted by xevias View Post
I can't find a good balance between off power spin outs and on power push. Hoping adding weight will give me a wider setup window.
And since almost everything is legal here, any suggestions on treating the Pardus handout tires? Sanding? Softening?
Thanks everyone.
We run the Pardus tires as a spec tire on carpet and they seem to get pretty sticky using the SXT sauce. I didn't sand or anything prior, just a run to break them in. Also in my experience the fronts feel like they provide more grip throughout the day then the rears.
But good tires so far, can't beat the price!!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-14-2012, 10:08 AM   #587
Trader Rating: 21 (100%+)
Originally Posted by josecarlo1129 View Post
VERY NICE built sir. I just want to ask how you managed to have that matte finish on both the side pods platform. Thanks and Cheers!
+1. Looks incredible!
silencery is offline   Reply With Quote
Old 11-14-2012, 03:02 PM   #588
Bishy's Avatar
The side pods were finished from the outside with a matt black water based enamel that I mixed up here at work. I used a lot of hot weather thinners to get it to flow off the brush and applied three coats, you can't tell its brushed at all.
It has dried quite hard, if it does get a scratch it will show the shiny black from underneath but a touch up isn't hard to do.
At the end of the day it's a race car first, show pony second!
The main body is a gold metallic colour that I added black and red pigment to, so it looks cola coloured in the shaded parts but has nice gold highlights in the sun.
Go Lotus
"I'd rather a bottle in front of me than a Frontal Lobotomy"
TeamC TM2V2, TM4, T8EV3, T8V3, TC10, AE B44.1, B4.1WC
www.teamcracing.net
Bishy is offline   Reply With Quote
Old 11-14-2012, 03:41 PM   #589
Very nice...If you paint the rim up to where the wheel lip would normally be with that flat black it might even make the sidewalls look the right height. The Pit Shimizu rubber tires have part of the tire overlap that area to give the wheel/tire a more scale appearance.
Old 11-14-2012, 04:01 PM   #590
robk's Avatar
Trader Rating: 22 (100%+)
Hey Rob (and everyone else)
I've watched a lot of the videos on your rcf1 blog channel and have a few questions that others may want to know too.
Does your weight distribution for the F104 carry over to the F104v2?
Not really. The lead was really for a TCS spec car on Tamiya's original tires. The Pit and "TCS" tamiya tires are light years better, so the lead is not really needed. You can also help the rear grip by pulling out the center screw on a t bar car, which is illegal for TCS.
The V2 seems like it has some more side bite...but I have not run it a ton on asphalt.
Will more weight over the front axles cause mid and exit corner push?
It should help on power steering. It should also slow down how quick the car reacts. Maybe less rotation, more rear weight makes the car act more like a pendulum.
Why put 60g on rear chassis instead of the rear pod?
Its sprung weight that way, so you're not trying to control an extra 60g with the spring and t bar. Also, the car was really designed for NIMH cells, which probably weighed that much more anyway.
What are the two effects?
Not sure what you mean, I haven't watched the video in a while..
This is a reaction to Rsector releasing that metal pod and diffuser.
Reduce rear droop (~1mm) and keep front droop down as well (.5-1mm). You might want to motor boat the car, low rear ride height, high front.
Thanks everyone.
Hope this helps
Old 11-14-2012, 05:54 PM   #591
Professor's Avatar
v2 or v2pro
i'm looking to buy a new 104,as i have not had a 104 before i thought i would as the question, a v2 104 or v2104 pro ?.we mainly run on low to med grip outdoor surfaces with rubber tires,blinky 21.5 or 17.5
any advise or sugestions appreciated,thanks
prof
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 11-14-2012, 06:06 PM   #592
I believe there is only 1 release of the V2
Old 11-14-2012, 09:11 PM   #593
Professor's Avatar
i have misread something then,thank you for clearing that up
Old 11-14-2012, 10:43 PM   #594
josecarlo1129's Avatar
Originally Posted by Bishy View Post
Go Lotus
Thanks and cheers, sir. I'll leave mine then. Sounds complicated for me, haha.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 11-15-2012, 11:53 AM   #595
celt's Avatar
Default New Tamiya TCS rear tires;
Sorry if this were mentioned before, but I've seen conflicting procedures so I thought I would ask here.
The rear TCS tires (re-branded Shimizu's I'm told) comes with a tongue and groove foam strip.
Am I to just lay this in the tire loose or fasten the foam strip to the wheel before mounting? I've never seen a strip of foam like this before. The front TCS set has a more standard foam doughnut, so no questions there...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 11-15-2012, 12:29 PM   #596
nrtv20's Avatar
I used rubber cement to connect the foam ends together then laid a piece of tape underneath the splice to aid in keeping it together, as far as I can tell it never came apart.
Old 11-15-2012, 12:39 PM   #597
celt's Avatar
Do you then leave the strip loose within the tire carcass?
Stan Garvin
Old 11-15-2012, 01:14 PM   #598
nrtv20's Avatar
Yes
Old 11-15-2012, 03:02 PM   #599
Originally Posted by edhchoe View Post
So don't drill holes on the wheels?
Yes, for me don't drill holes. I've tested both with holes (tire grooved within 10 minutes) vs. no holes (tire wear is good, handling better).
Just be careful not to squeeze the tire as the air might escape and cause deformation. If so, let air back in, then re-seal the area.
Easy to try. Run it with the holes. Then seal the holes with tape. See which you prefer and go with that.
This is for Pit 575 rear tires.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 11-20-2012, 06:41 AM   #600
dfx
dfx's Avatar
For those who use Carbon Rear Bulkhead Plate #54375 - do You use 1,5mm shim when attaching rear wing? It looks there's no need to use shims but is there any difference in downforce when the wing is set backwards?
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
