Like Tree1Likes
Old 06-02-2012, 09:32 PM   #46
A few more observations...
Ok the car IS light. 50g less than my 104 X1! That is using the same front end, same electronics, same rear shaft/diff assembly.
Next, the new top deck makes removing the battery way easier. One must be careful, though when putting it back in as it's easy to put it back slightly skewed. Make sure really back in place before tightening the screws.
The new shocks are very smooth and easy to build. they require oil much heavier than I expected, but are fine. Since they're a through and through design, they don't require a bladder and have no rebound.
The rear pod top deck is not so bad, flex wise, but the plastic left front post supporting it is truly bad. it's extremely flexy. had to replace it with a post from my 104 X1 and a few shims. Makes it much better.
Side links look flimsy, so I would probably stock on them as I don't have much faith in them surviving a crash. I may be wrong, though (I hope).
Not much else... Simple and elegant design. I believe it should be a very good car.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 06-02-2012, 09:40 PM   #47
Originally Posted by J-PaP View Post
What the steel shaft does is try make acceleration less abrupt, thus making acceleration smoother/easier to drive. The extra weight does help as well to give more rear traction.
I'd rather use the ESC throttle profiles or the radio's EXP on the throttle channel to smooth out the acceleration. As for the weight, I can always slap a few lead weights on the lower pod plate and get the same result if needed, but have the weight sitting lower.
But you're right, it's all personal preference.
Martin
Old 06-02-2012, 10:28 PM   #48
Martin Paradis
Thanks for the info. So you didn't use the new diff? Hopefully tamiya starts supplying some parts. The roll damper and the f104w gp t bar are still near impossible to get replacements.
I wonder if the F1r side links fit on. Mind telling me the length of the links?
How do you find side to side movement with the link chassis? Smoother than the t bar design?
J-PaP is offline   Reply With Quote
Old 06-02-2012, 10:59 PM   #49
robk's Avatar
Trader Rating: 22 (100%+)
The steel shaft also seems to help with adding some flywheel effect as well. I tried it with foam tires on carpet and it got the rear end overly stuck to the track. I would assume it has a similar effect on rubber, and is why the X1 came with it.
Carbon is always better for acceleration, but sometimes that doesn't mean anything if you can't hook the tires up.
Old 06-02-2012, 11:00 PM   #50
robk's Avatar
I would bet that the whole rear end is RM01.
Old 06-03-2012, 02:42 AM   #51
WildManDriving's Avatar
Trader Rating: 29 (100%+)
I keep checking this thread to see where might be selling these online that post to Australia and sell 417x lower chassis. Fingers cross it's not much longer now as I only have a 12th running right now that we don't race locally.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 06-03-2012, 02:48 AM   #52
malcnz's Avatar
Ha same...we need our American friends to jack some up for us..any takers?
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 06-03-2012, 07:25 AM   #53
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
madjack is offline   Reply With Quote
Old 06-04-2012, 01:01 PM   #54
The diff is the same as with F104 pro/X1/wgp...
Links are 65.5mm from center of the ball to center of the ball.
Side movement is much different. It's hard to express with words (English is not my primary language...), I'd say that even with the side spring tightened correctly, it feels different than with the high traction t-plate. roll seems much more constant, as with the t-plate, it would seem to me as if it gets stiffer as you roll more.
Martin
Old 06-04-2012, 01:03 PM   #55
Pretty much is, save for the lower plate witch is different than the one for RM01.
Martin
Old 06-04-2012, 03:02 PM   #56
robk's Avatar
I ran the X1 when I first got it back to back with my Exotek conversion. The link cars seem to feel smoother and easier to drive in a lot of situations.
If this car is similar to the Exotek, it will be very good.
Old 06-04-2012, 03:21 PM   #57
JayL's Avatar
Martin
I thought I read the diff was changed, 417 rings or something??
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-04-2012, 04:34 PM   #58
robk's Avatar
It is but the old one is compatible as well.
Old 06-05-2012, 04:25 AM   #59
dfx
dfx's Avatar
Here's a picture from the other thread that shows the change in design...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 06-05-2012, 10:31 AM   #60
JayL's Avatar
So the Diff rings are the only change? It is not adjustable without removing the rear tire like the RM01?
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
