Tamiya F104 Version 2 >
Like Tree2Likes
Old 11-11-2012, 12:52 PM
  #571
Mechintosh's Avatar
Last night was the 1st time I really enjoyed my F104v2. I have been having issues in getting the Dif set right. Seemed like I had 1/32nd of a turn from to tight to too loose. Put in a the Thrust bearing Hop Up. Car no longer pushes, was a pleasure to drive. I should have done this a while back.
Mechintosh is offline
Old 11-11-2012, 04:33 PM
  #572
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Dan
Wonder how those compare to Shimizus
Yea I was hoping someone would chime in before I ordered them. Ill wait a few weeks more
Mr.juarez is offline
Old 11-11-2012, 05:47 PM
  #573
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
They look good, and the rims are reasonably strong (compared to the fairly brittle older Ride rims). The rears grip pretty well, but I'm getting understeer with the fronts and trying to improve it. Could be a function of surface and/or my setup, but a few people at my local track have had similar experiences. If you've got plenty of turn in at the moment, then give 'em a go.
The rears look as though they'll last longer than the 0572 Shimizus, so I've ordered a set of the silver F104 foam rims in order to have similar-ish wheels front and rear (I'm gonna try 0571 on the front and R1 on the back).
PDR is offline
Old 11-11-2012, 10:49 PM
  #574
edhchoe's Avatar
Trader Rating: 41 (100%+)
Hi.
I have a question. I used to have a F103 but I sold it because it was so difficult to drive. Are the F104 v2 a lot easier to drive?
There aren't any race tracks in my area so I just play in my driveway. The rear end traction was always too loose...
edhchoe is offline
Old 11-11-2012, 10:55 PM
  #575
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default First trip
Finally got my V2 on the track for the first time today.... on a new layout of course and all I can say Is WOW! this thing was a Rocket and with a few tweaks it was a pleasure to drive. All that is left is to learn how she drives a bit more as its oddly much more sensitive.
racer x 1 is offline
  #576
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by edhchoe
Hi.
I don't think the new cars are any easier to drive, but with the advent of new rubber tires in many combinations, one can make the VII into a cadillac for the driveway
RedBullFiXX is offline
Old 11-12-2012, 08:18 AM
  #577
edhchoe's Avatar
Can you suggest the tire combo plz? Also the inserts.
edhchoe is offline
Old 11-12-2012, 04:19 PM
  #578
Shimizu 577Fr, 575Rr
Use the included inserts
Old 11-12-2012, 05:45 PM
  #579
Just an opinion, if using the Pit 575 for the rear, my experience is the kit insert is too soft and will groove the tire quickly.
Solution is to have air inside the tire by sealing any holes. The air pressure will help support the tire and improves tire wear significantly.
rccartips is offline
Old 11-12-2012, 05:47 PM
  #580
edhchoe's Avatar
So don't drill holes on the wheels? Will the plastic rims that come with the kit fit the tires? Are those regular foam wheels?
edhchoe is offline
Old 11-12-2012, 05:54 PM
  #581
I would NOT recommend this
And yes, the kit plastic wheels are correct for Shimizu tires
Old 11-13-2012, 09:53 PM
  #582
xevias's Avatar
Hey Rob (and everyone else)
I've watched a lot of the videos on your rcf1 blog channel and have a few questions that others may want to know too.
Does your weight distribution for the F104 carry over to the F104v2?
Will more weight over the front axles cause mid and exit corner push?
Why put 60g on rear chassis instead of the rear pod? What are the two effects? This is a reaction to Rsector releasing that metal pod and diffuser.
I can't find a good balance between off power spin outs and on power push. Hoping adding weight will give me a wider setup window.
And since almost everything is legal here, any suggestions on treating the Pardus handout tires? Sanding? Softening?
Thanks everyone.
xevias is offline
Old 11-13-2012, 10:08 PM
  #583
Bishy's Avatar
Default Defector
Ok guys
I've had an F103 with carbon chassis etc for about 18 months here in NZ and have had a fair bit of success campaining it in club, regional and national events during that time - (current NZ#2).
We run primarily foam tyres on untreated asphalt and carpet with no additive, RS540J silver-can motors and unlimited gearing.
The F103 and F109 pretty much dominate over here with their wide setup and F104's are pretty hard to get into an a-main.
Well, my good friend who is a Tamiya stalwart convinced me that we both needed to get a couple of these V2 cars mainly because he is a scale-looks/concourse nazi and believes that Tamiya poops pure-white with no smell whatsoever.
Needless to say I was skeptical of these skinny cars as I also run a 235mm wide Pro10 and a 12R5.1 and reason that a car has to be almost as wide as it is long to be any good. I figured at best it would be an ok carpet car so went ahead.
Well I'm prepared to put my hand up and say that for the first time in my life I may have been wrong... I put this kit together (my first new build) over the space of a couple of weeks adding only the alloy motor mount, carbon brace and TRF shock... then I went to the final round of my clubs outdoor championships on Sunday and just dominated from the start. With a bit of tweaking and adjusting, I was down to almost matching my best lap times from my 103 within 1 day of racing. The car responds so well to adjustments and doesn't suffer from the vagueness of a t-bar car. It remained consistent through the whole day. The skinny track width doesn't hinder rear traction at all and in fact some other racers who sampled it at the end of the day reckoned they had never seen an F1 car so planted in the rear. Even spectators came up and said the thing looked like it was glued to the track!
I was running the steel axle, pink side springs with a bit of preload, an AE Green centre spring, Tamiya Black front springs, 10WT AE oil in main and side dampers, 2.0 degrees negative camber and no damper lube in the king pins. DIALLED!
Anyway, here's some pics. I even went as far as reshaping the rear wing to match Kimi's car
Attached Thumbnails Tamiya F104 Version 2-lotus3.jpg   Tamiya F104 Version 2-lotus5.jpg   Tamiya F104 Version 2-lotus1.jpg   Tamiya F104 Version 2-lotus2.jpg   Tamiya F104 Version 2-lotus6.jpg
Bishy is offline
Old 11-14-2012, 12:00 AM
  #584
josecarlo1129's Avatar
Originally Posted by Bishy
Ok guys
VERY NICE built sir. I just want to ask how you managed to have that matte finish on both the side pods platform. Thanks and Cheers!
josecarlo1129 is offline
Old 11-14-2012, 05:53 AM
  #585
nrtv20's Avatar
Any comparisons of the V2 to the Exotek car? Just curious, I'm still running a Pro
nrtv20 is offline
